Electronic seals Is electronics seals really effective in case of the protection, I doubt if they are perfect and if it really work then where can i find the best one in the online?
Ecu can it bee swapd over from other golf
As long as they are the same models then yes you can do that swap out, but really doubt the ECU is the problem, failure rate is less than 2% for electronic controls units.
Nov 22, 2016 | Cars & Trucks
HGMI are not working after the storm
Probably due to a power surge. Manufacturers do not build any extra tolerances into today's electronics, so they won't hold up against even the slightest out of tolerance issues. It keeps their costs down and ensures that these devices won't work much longer than their warranties. Standard surge suppressors don't cut it with these devices either. Your best bet to protecting your home theater and computer electronics is to use an UPS. They regulate voltage and protect the equipment against surges and more importantly, brownout conditions that can really damage equipment (something the surge suppressor cannot do).
Nov 27, 2015 | Panasonic Televison & Video
I have an Eagle Ultra Plus Fish Finder( SERIAL # KU-037-4801) that I purchased in 1989 from Bass Pro. The unit's front plastic seal go cracked somehow and now the finger touch screen selections(...
Hi
I think your best bet here would be to contact the manufacturer directly on this one. (link below)
The trouble is... is the unit worth putting $ into or would you be better off buying a newer model.
You MIGHT get lucky and find a similar unit on ebay, but unless you're REAL handy with electronic repair I doubt if you would get any joy.
Welcome to the world of disposable electronics
-Steve
Service Info
Feb 23, 2015 | Eagle Boating
Sharp er a470 was changing faulty power cord and disconnected the keyboard, now after I put everything back together it won't come on. Checked power with multimeter, everything seems to be fine
Did you wear static protection while you were working inside? That's not for YOU, it's for the electronics. They're wicked sensitive to static.
BUT... it might also be the case that you just didn't plug everything back in perfectly. Go back inside, wearing static protection, and doublecheck every connector inside. EVERY connector, even if it's on the other side of the board.
Jul 26, 2014 | Computers & Internet
Effects won't work stuck on d2
Hi, did you find a solution for this problem? I have it too.
Nov 16, 2013 | Behringer EURORACK UB2442FX PRO Mixer
I have a Nikon P90 that was droped and the digital screen cracked and is non-functional. The camera still operates perfectly utilizing the viewfinder. I would like to replace the damaged screen. A...
You could try to look for video instructions on youtube, but I would not recommend if you don't have mechanical experience or experience with electronics, since the screws are really small so you need really small tools and the electronics are delicate and small too.
Apr 23, 2011 | Nikon Coolpix P90 24x Optical Zoom Digital...
F8 on Ge JTP27 Whats wrong?
The reason to get F8 is that the component failure that occured within the Electronic Range Control (ERC) effecting temperature processing circuits. Th perfect fix for this problem is to replace Electronic Range Control (ERC).
Sep 04, 2009 | GE JTP27 Electric Double Oven
Wp-dc8 waterproof case Silicon grease where how much
Don't be cheap with the silicon grease. In the same respect don't make a mess. Apply a liberal amount to any seal and area that can leak water, and there is really no over kill when it comes to protecting your expensive Canon and photos.
Apr 05, 2009 | Canon WP-DC80 (0778B001) Marine Case
Tracking problem
Suggestions: 1. Do a "reset" by unplugging VCR for 30 seconds or so. Doubtful to fix- but worth a try. 2. Pull the top cover, load a tape and play. Does the tape seem to wander up and down across the video or control heads? If so, this is a mechanical problem- perhaps a tape guide is broken. 3. Electronic problem: If this is the case, probably trash the unit unless unit is a high dollar ($250 or up). VCRs (like most other consumer electronics) are throw away items these days.
Feb 18, 2007 | Samsung SV5000W VHS VCR
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
