Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite he5t washer
It seems as though clothes especially towels and washcloths have an odor to them after they have been washed.  It's almost as if they are mildewed, but they have just come out of the laundry. I am using HE detergent, didn't know if I am not using enough detergent(I am following pkg instructions), maybe overloading the machine, or maybe I should just be using fabric softener, but I am thinking that might just cover up the odor.  I never had trouble before the new washer, and generally don't use fabric softener, have kids with skin allergies.You don't notice the odor really until the towels are wet. Like when you are drying off, or using a wet wash cloth. Any information would be appreciated.
  • 5 more comments
  • Anonymous Feb 06, 2008
    Mildew smell when washing clothes. Not sure where to find sourcew of problem. I am aware of the socks in the rubber gasket area and leaving the door open. Trying the bleach method now. However, this problem is relatively recent. No problem with water supply.
  • Anonymous Mar 12, 2008
    My Kenmore washer front loading really stinks inside even if I leave the door open to dry out. I have tried doing a cycle with just bleach to kill anything but it doesn't seem to help.
    Robin
  • Anonymous May 07, 2008
    I have a Kenmore Elite he3 and the washer has a mold/mildew smell. It really makes towels smell moldy. What can I do to fix this problem?
  • Anonymous Sep 10, 2008
    yes! I've had customer service out numeral times and they say "it is what it is" I even exchanged it for the top of the line model, spending another $1,000. Same problem. It's only the towels, and I've tried both baking soda and white vinegar. I clean the gasket in the door after each wash. I wash down the drum once and week, and every 4-6 weeks, run the clean cycle.
    I am so sick of this problem, I'm ready to blow a gasket myself.
  • sandy dee Nov 04, 2008
    I have a Kenmore Elite 4Ht that is 2 years old and I have the same problem with mold. From the research I have performed so far, it looks like this is a DESIGN FLAW with the washer and that Sears should have this machine RECALLED.
  • dezhome Nov 25, 2008
    I have the same problem. All of my clothes now smell moldy when they get warm or wet. I've wiped out under the rubber ring, washed with bleach, leave the door open when empty. Help!
  • deebarr May 03, 2009
    I too have the same problem with my Kenmore Elite HE. It stinks like mold, mildew and I can not find my owners manual to clean this. Where can I repurchase a manual
I too have a HE4t washer. When I bought it, the Sears sales man said that after doing the wash for the day, you have to always wipe out the insides of the rubber gasket. If you do not do this, you will get mold build up. I an anal about doing this and for 6 months now have had no mildew smell. However, I went on a trip for 2 weeks and when I got back, there was an awful mold smell. I checked the gasket and sure enough, there was gunk build up. Needless to say hubby and kids did not do the maintenance. I had to wipe it up several times with bleach to remove the mold spores. Then I ran a sanitary cycle with pure bleach. Smell is gone thankfully.
But don't you think it's ironic to have a $1500.00 machine that needs to be babied after the end of the day?
Posted on Feb 11, 2008
  • 3 Answers
STOP USING TIDE. I had the same problem. Stop using Tide and any other detergent they make. Tide in there attempt to go green, removed some chemicals that worked. They changed it for the worst just to make the tree huggers happy. I switched to Cheer and problem solved. I have the Kenmore Elite HE5t steam.
Posted on Oct 31, 2009
  • beachgirl160 Feb 01, 2011
    I've had my machine for 2 years and have never had a problem with mold or smell either in the clothes/towels or in the machine itself. I do not leave the door open and I have never run it through a clean cycle or bought any special washing machine cleaner. I wipe out the rubber seal every once in awhile but I HAVE NEVER USED TIDE or any other laundry soap from the grocery store like All or Cheer. >>>I have only ever used ECOS natural detergent (www.ecos.com Phone 1-630-595-1900 ) from Costco in the wash and white vinegar instead of fabric softener. I also add a small scoop of plain baking soda (or once in awhile oxiclean) in the cup marked "oxi/color safe bleach" when I wash towels, sheets, socks, underwear and anything really dirty or smelly because baking soda conditions the water and helps the detergent work better.
    I recently had to call repair because water started pooling in the washer if I didn't use it for a day or two (still with no odors!) and found out I have been using way too much detergent. The tech told me to never use more than 2 tablespoons of soap because this machine uses so little water that if you use more soap the machine has to work harder and I damaged the valve by using too much soap. Hope this helps all of you who are so disillusioned by this machine...I still love mine and want to buy them for my next house!!!
    Problem Solver:
  • 8 Answers
Hi! I have Kenmore Elite 4t and had this same problem: Musty, Moldy smell in washer and on clothes. The Sears Technician suggested that I use a half a cup of Clorox Liquid Bleach and put it in the tub (not the dispenser). NO CLOTHES! Use the longest hottest setting and when it's done clean the inside (underneath rubber tire thingie) and the undernath part of the door with a papertowel. And to always leave the door open. I did what he said with the bleach and it worked. I didn't want to leave the door open because I have 2 cats & was afraid that they would want to go in it, but ended up repeating the bleach thing again because a few days later the horrible smell was back. I leave the door open all the time now and the cats never go in it. They've watched laundry spin around, so I guess they're smart enough to not want to go in it. I have not had this problem again since I always leave the door open and I did this over a month ago. I hope this helps!
Posted on Jan 18, 2008
My husband and I have the Kenmore Elite HE5 washer and dryer. A Sears tech suggested that we clean the washing machine regularly with a washing machine cleaner. I couldn't remember the brand he suggested, but Tide makes one and our towels smell extra fresh. Hope this helps.
Posted on Jun 25, 2009
We were having the same problem with clean towels smelling once they got wet. Started adding a half a cup of vinager to the wash. No more stinking towels. Add when the water is at full level. Joe
Posted on Aug 16, 2008
  • 290 Answers
The first thing to do if you have had the machine a few months is to check the pump drain trap for anything that might have made it's way into it and is growing bacteria. Your owners manual gives instructions on how to do this. Also look inside the rubber boot in the door for stray socks.
After you have cleaned the trap, run the washer through a "clean cycle". I think your book will describe this also, but if not, use the sanitary cycle with a full cup of chlorine bleach poured in where you normaly put the detergent. Run empty through the cycle. This should kill any mildew or bacteria growing inside the machine. This should be done about once a month, more often if you don't use chlorine bleach in your normal wash routine.
Washing in cold water and using color safe bleach has become the normal way to wash and save energy, however it doesn't kill a lot of the germs that cause odors in fabric and washing machines.
Also you may want to get a brand new towel and wet it in hot water from your sink, then let it air dry. If it ends up smelling the same, you have a water problem.
You may also be over loading so that the clothes aren't getting as clean as they should.
Post back to let me know how it comes out and if you need any help.
Posted on Oct 18, 2007
  • Michael  Lindley
    Michael Lindley Oct 21, 2007
    Just wanted to follow up on your washer and see what you found out.
    Thanks/Mike
I've used vinegar too, it helps
Posted on Dec 07, 2009
Corbin31... you must take a dump anywhere you please, and don't give a **** who steps in it... the only thing in the world that matters is you...
Posted on Dec 22, 2009
Get rid ofan odor in my washer
Run a cycle with some bleach.
Feb 24, 2015 | Kenmore Elite HE5t Washer
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
F20 message on washer kenmore elite HE5t
http://www.fixya.com/support/r3608632-f20_error_code
Feb 28, 2010 | Kenmore Elite HE5t Washer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes smell from Kenmore Front Loader
run 3 cups of bleach on high water setting with hot selected as water temp, repeat as ness to eleminate odor
Sep 11, 2009 | Washing Machines
The towels and wash cloths have a metalic smell
Despenser is not releasing bleach and washer has odor as well as clothes.
Feb 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer he5t error codr f21
remove bottom panel 3 screws 7mm get bucket and alot towels, turn pump filter clockwise and remove all debris from inside pump now close it up nice and tight should solve youre problem
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
Laundry
Same problem with my front loader. You have to make sure to clean out the rubber trap in the front regularly. it seems to collect alot of hair and plug the drain hole. also it helps to leave the door open when you finish washing to further reduce the stagnant water smell. Use fabric softener for the towels!
hope that helps.
Aug 02, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Washer Odor
Meoser,
I've been selling the only available all natural washing machine and towel mold and mildew remover online at smellywasher.com since 2006.
It's now also available at Ace, Tru Value, Hardware Hank and Do It Best hardware stores. One bottle provides 24 treatments and guarantees to remove mold, mildew, or any odor from your washer. After the washer is cleaned it also safely and easily gets rid of the mildew smell from any towel or clothing that the odor has transferred to.
The dark, moist environment of your clothes washer is the perfect place for mold and bacteria to grow. See: http://www.cbsnews.com/video/watch/?id=5408971n
We can't change that environment but we can stop the food source for them to grow buy reducing the amount of detergent used and stopping fabric softener use. Go to the blog page at smellywasher.com to read advice on the cause of and cure for washing machine and towel odor.
Nov 06, 2007 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
5,866 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
