Question about Casio FX991ES Scientific Calculator
How to calculate present value factor of annuity in fx-991es
SOURCE: how to calculate log value in calculator with different base value
In any scientific calculator log2(n) can be  calculated with either ln or log function as follows
Log2(n)= ln(n) / ln(2)
Or
Log2(n)=log(n) / log(2)
both will give nearly the same answers
Posted on Apr 24, 2009
SOURCE: Inputing factors on a casio fx-115es calculator
Unless I am failing to understand your problem, just combine like terms to get:
9x^2+2x+4 and then enter those coefficients into the quadratic solver.
That will get you the two answers -- both of them will be complex.
If you wanted to turn those two answers into factors (complex) of the original equation simply
change the signs on each and put an x in front.
Of course, the quadratic formula would also work.
CG
Posted on Apr 28, 2009
  • 8064 Answers
SOURCE: mode change
Just so that we know what we are talking about. The natural display is the display mode in which fractions appear on two lines, radicals appear as radicals, log can be calculated in any base, etc. If that is what you understand by Natural Display, we are in agreement.
To set this mode, you turn calculator ON and press [SHIFT][MODE] (setup). The option is called MathIO, and it has the number 1.
Thus [SHIFT][MODE][1:MathIO].
Hope it helps.
Posted on Oct 13, 2009
  • 8064 Answers
SOURCE: how can I calculate a large factorial using casio
There is a function to calculate them for you.
In CAS, or Algebra or Tutor Modes, use the x! option
In Run-Math, press [OPTN][F6] to pan right, then [F1] to access the (PROB) menu then enter option number corresponding to x!
The way it works is as follows
number ! [EXE].
Due to memory limitations, you can calculate factorials of numbers up to 69.
Hope it helps.
Posted on Nov 13, 2009
Testimonial: "Thanks. Ended up finding it after searching around for 20 minutes. Appreciate the help though!"
SOURCE: how can we do linear interpolation in casio fx-991ES calculator
how solve interpolation by casio fx 991 ex
Posted on Nov 28, 2010
How to do interpolation in Casio f2f-4800p?
Interpolation mannual in fx-4800P - Fixya
www.fixya.com/support/t22818601-interpolation_mannual_in_fx_4800p
Jan 11, 2014 - interpolation mannual in fx-4800P - Casio Rare Vintage Scientific question. ... SOURCE: how can we do linear interpolation in casio fx-991ES ...
interpolate how can interpolate linear regression by casio ...
www.fixya.com/support/t22818666-interpolate
Jan 11, 2014 - interpolate how can interpolate linear regression by casio fx-4800P -Casio ... SOURCE: how can we do linear interpolation in casio fx-991ES ...
how to perform linear interpolation manually and on casio fx ...
? 6:39
https://www.youtube.com/watch?v=rCVM6RWMjQ4
Jan 7, 2015 - Uploaded by Yabets Jab
In this video you can simply understand how to find a value of a given missing number in a table on Casio fx ...Missing: 4800p
Linear Regression on a Casio calculator - YouTube
? 6:25
https://www.youtube.com/watch?v=OGmHagjZPjg
Oct 31, 2012 - Uploaded by cpobyrne1
How to perform a linear regression on a Casio scientific calculator. Example uses a ... A Casio fx-83WA calculator is used for the demonstration. .... Lagrange Interpolation Easily Explained on Casio fx-991ES Calculator!Missing: 4800p
Jan 05, 2016 | Casio Office Equipment & Supplies
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
Calculators fx algebra
The FX-991ES Plus barely handles simple operations on matrices of dimensions up to 3X3. It cannot find eigenvalues or eigenvectors.
Oct 24, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
Save equation fx 991es
In table Mode you can enter the formula for a function and generate a table of values. For a 991ES Plus you can enter two functions. However if you change MODE everything will be erased.
In EQN (equation) there is a certain number of built in formula types you can choose. You will be asked for the coefficients which will be used to solve the equation selected. However if you change MODE your lose what you entered. So basically you cannot save formulas to use as a memory aid (if that is what your intention is.) Sorry.
Jul 19, 2013 | Casio FX991ES Scientific Calculator
PRIME FACTORIZATION USING CASIO FX-991ES PLUS
If it does not have the FACT key, you must factor by hand: Divide by 2, then by 3, 5, 7 etc.
Apr 24, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
How i can get infinity symbol in casio fx-991es plus calculator
why cant they include infinity symbol ? sometimes i feel my calculator is so dumb !
Nov 16, 2012 | Casio Brand New-Fx-991es Plus - Scientific...
Can casio fx-991es factor?
No it cannot factor. It does not do symbolic manipulations.If you know a bit of theory of polynomials you can find the roots of the polynomial equation. The calculator has a Solve utility. Once you have the roots, you can use your knowledge about polynomials to carry out the factorization procedure.
Aug 31, 2011 | Casio fx-300ES Calculator
HOW TO RESET MY CASIO
Turn calculator ON. Press [SHIFT] [9] (CLR) and select
  1. Setup,
  2. Memory, and
  3. All.
  4. Then press [=] to execute the reset.
Note: The choices of reset options are those available for the FX-991ES. But the procedure is similar.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Dec 01, 2009 | Casio fx-300ES Calculator
NEED INSTRUCTIONS
Since you're looking for so much, it sounds like you do not have the users manual for the calculator. You can download it here:
http://safemanuals.com/user-guide-instructions-owner-manual/CASIO/FX-270W%20PLUS-_E
John
Jan 19, 2009 | Office Equipment & Supplies
Casio FX991ES Scientific Calculator Logo
370 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
