Question about RCA P52926 52" Rear Projection Television
RCA Projection tv has great picture but no sound. Model #P60812BL
I have just gotten a RCA rear projection TV from a friend, Model # P60812BL SK# PTK195AC
Looking at the boards inside, I can see nothing out of the ordinary as far as any loose connections or burned chips. everything "looks" fine. speakers are fine. checked the settings in the menu and they are all correct as far as I can tell. I'm thinking the audio processor or the eeprom needs to be replaced. But I'm not the expert so don't quote me on that. If there are any ways to test certain things before taking it apart, direction would be much appreciated. Thanks! If you need anymore info feel free to ask.
  • Rommel Cana
    Rommel Cana May 11, 2010
    are you having problems with the audio? or video?
  • 67 Answers
Normaly the audio ics go bad cap or 2 make sure audio sing is present on input of aud ic if so chk opt if opt bad replace ic and capacitors around ic good luck this should fix ur prob parts nte semiconductor.com 25.00$
Posted on Aug 30, 2009
  • SHAN BAILEY Aug 30, 2009
    normaly the audio ics go bad cap or 2 make sure audio sing is present on input of aud ic if so chk opt if opt bad replace ic and capacitors around ic good luck this should fix ur prob parts nte semiconductor.com 25.00$
I have an RCA rear Projection TV model # p60812BL manufactured in 1998, no sound is coming from the tv when watching cable TV via a digital box. When the mute button is pressed and unpressed you can hear...
Tries tv and cable box unplug,replug it back like about an hour.For the tv resetting itself and the cable box to upgraded it softwares.Go into the tv menu go to Audio SETUP.Go down to audio ressetting,these steps should solved ur problems,but not call ur cable companny replaced the reciever box,it have problems.
Mar 16, 2011 | RCA P52926 52" Rear Projection Television
I'd like to know where I can get a replacement wire to connect the lamp ballast to the J4 input in my rca HD61LPW42 rear projection TV. I've gotten no response to an email I sent RCA a week ago. These...
hey mcd5brady, what was the solution to your last problem w the tv? ( replaced bulb and ballast but still no picture) my tv has same problem and dont know what to do next. any info on a solution would be greatly appreciated! post back or email. dellbino@aol.com
thanks
Jan 09, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
RCA model P60812BL 10 years old picture goes fuzzy once on
Your convergence amplifiers are begining to malfunction. This is not expensive However I would advise that you get a qualified TV technician to work on the set due to a chance of damaging you TV if you install the amplifiers incorrectly.
I hope this helps
thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 24, 2009 | RCA D52W19 52" Rear Projection Television
Tv picture goes off but still have sound.
Resolder all poor connections on power supply board and this should fix your problem.
Feb 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture no sound
If you will look I bet you'll find a switch on the back of the TV for internal or external speaker. It's probably gotten switched to EXT. somehow.
Dec 27, 2008 | RCA P52937 52" Rear Projection Television
Rca tv no picture
you need a cable spliter coming from the wall and two cable boxes
Sep 05, 2008 | RCA P52926 52" Rear Projection Television
RCA 46 inch convergence problem
AM sorry, but can you provide your model number TV and chassis please?. I will tell you location parts. Thank you
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
TV won't turn on.
Samsung Projection TV Model # is PCK5315R. It displays a light on the "timer" indicator on front of the TV but the TV doesn't respond, no picture or sound.
Mar 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA P52926 52" Rear Projection Television Logo
294 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
