Question about Goodman Heating & Cooling
Goodman wall mount heater not working
Thermostat not registrations heater burning at max
  • 20 Answers
What type of thermostat digital or manual, if distal try to pull off front cover n see if that turn it off if it does this means u have a bad thermostat n needs to be replaced. If it's a manual then try to disconnect white wire on w screw ,of course turn power off to heater , and see if that turn heater off if so replace thermostat. Hope this was helpful.
Posted on Dec 28, 2013
Nothing working when thermostat turned on.checked voltage at transformer 110 at top and 24 v at bottom,cant figure out whats wrong .any ideas
Be the thermostat. Kill the power to the air handler so you do not burn the transformer. Remove the thermostat from the wall. Twist the red and white wires together and turn the power back on to the transformer. The heat should come on. If it does, the thermostat is bad. If it doesnt, do the same thing but twist the red, yellow, and green wires together and power the transformer up. The air should come on in cool mode.If it does come on then we know what to check next
Oct 27, 2013 | Goodman Manufacturing Goodman GMS81005CN...
Wall heater will not work, even with thermostat in on pisition
Your thermocouple may be shot.
Have ya try to replace that one?
A simple thermostat now let me show ya a video of a man that has replaced his thermostat. Even though that gas valve is a bit different the thermocouple does the same function and that is hold down the safety magnet. Now watch:
Replace that thermocouple on your heater.
Feb 18, 2011 | Williams (5009622) Ceramic Gas Wall...
Just installed this DV210SG Wall mounted panel heater, works great but smells like burning rubber, there is nothing burning, but sure smells bad! HELP!
There are manufacturing oils remaining on the metal. Allow it to stay on for about 1/2 hour. Open windows and door to ventilate. Smell will dissipate with use.
Nov 20, 2010 | Empire DV-215-SG Wall Mounted Panel Heater
I have a Williams Ceramic Gas Wall Mounted Panel Heater, the pilot is on but the furnance is not working
Jump the two wires going to the thermostat, if it starts , you have either a bad thermostat or a broken thermostat wire. If it does not fire up, you will need to check for 24 volts AC going to the gas valve from the transformer. If you have voltage, you have a gas valve issue. If no voltage, check for a limit switch that may have overheated with an Ohm meter. If they all test good, replace the transformer.
Jan 22, 2010 | Williams 2509612 Ceramic Mid-Size Heater
What is easy way to replace the thermostate in
Hi, that thermostat should be a wall mount. This heater has only 2 wires and any "Heat only", "millivolt" thermostat will work. Remove the old T-Stat and mount the new one on the wall, only 2 wires and less than a volt so no shock danger, doesn't even matter which wire goes where. Good luck and comment back if you need any help.
Jan 09, 2010 | Cozy Heating & Cooling
We have a Williams wall heater that was gas/ converted to propane that is newly installed. The thermostat does not work. Any suggestions?
Assuming the pilot is lit, try jumping out the thermostat wires where they come into the valve. A paper clip would work. If it works, the problem is in the t-stat circuit.
Dec 30, 2009 | Williams 3003622 Ceramic Wall Mounted...
Need wiring diagram for a heat & air package circa 1970 shows model # PGB02408CAA cannot find manufacture name. Has a wall mount thermostat.
I think this is a Goodman unit. Check the yellow pages for a Goodman dealer. They can help you with that. The unit is pretty old but they might be able to find you one
Oct 30, 2009 | Heating & Cooling
Wall mount dyna glo model RMC-40NGT
I have the same one i am looking for the wall brackets, I lost mine. I also bought mine at a garage sale the people had it attached to the wall completely hooked up .they had no fire backer on it .They only took it off the wall when i purchased it
Nov 02, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Wall gas furnace
look inside the control panel of the heater. look for a 120 volt to 24 volt transformer.  There may be a fuse on the transformer secondary.  The thermostat switches a hot 24 volt wire so you won't find a common at the thermostat.
Nov 13, 2006 | Empire GWT-25 Wall Mounted Panel Heater
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
