Question about Sony KV-36FV26 TV
SONY KDF-E55A20 5 red blinking lights on power button
Power light comes on green, pic & audio comes on for 10 seconds, screen goes black, power light remains on, tv comes back on after 20 seconds, repeats process. Turn unit off and on - power light blinks red 5 time interval, hit "on" again, power light turns green, tv comes on & goes off as above. Picture very dull-almost looks blacks & grays, audio good. On Sony Blink Code explanations it states 5 red blinks is associated with the AKB circuit, but repairman tells me this is if tv has picture tube (ours doesn't). Done a lot of research, can this be the projection lamp needs replaced? Manual says there's a light that indicates when lamp needs replaced, but it isn't blinking, only power light. It looks like we can replace it ourselves - if so, should we buy one with the housing or just the bulb? Finding them on line for approx. $115-$150, Serviceman wants $200 for bulb & $200 labor! Help!!! thanks so much for your expertise! Dana
  • 1 more comment
  • dana_s_muell May 18, 2009
    I don't know where that Model # came from but my model is a KDF-E55A20 - it says in the manual it requires a XL-2200 bulb. Big thanks for your assistance!
    What is the correct bulb number for the KDF-E55A20 Sony TV? I saw in the book it listed XL-2200 but Sony Accessories Store doesn't have that one listed - what's the diff between the XL-2200U and the XL-2200. Also, if searching websites, there are alot that state GENUINE part and are cheaper than the $200. thanks Dana
    EXCELLENT WEBSITE! HIGHLY RECOMMEND - TECHS MOST KNOWLEDGIBLE! THANKS FOR SAVING ME $400! DANA
  • 10,594 Answers
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
Posted on May 18, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics May 18, 2009
    A1085447A is Sony part number of XL-2200 lamp.
    Genuine is only available with Sony and few good part stores.
    XL-2200 and XL-2200U are same, XL-2200 is came with TV and XL-2200U is replacement lamp. No difference at all.
    How about rating this solution?
    Thanks for nice comments.
My Sony KDF-E55A20 stopped working abruptly a few nights ago. It is almost 5 years old and now when I try to turn it on nothing actually comes on, not even the fans the only thing that happens is the power light blinks green 5 times. I have read online that 5 red blinks on the power light means that the lamp has failed, so I ordered a new lamp and replaced it. However, this did not change anything. The power light still only blinks green 5 times and then nothing else happens. Does anyone have any insight as to what the problem could be. Thanks.
Posted on Jun 24, 2010
2 Suggested Answers
SOURCE: wrong model showed up on my question - need new reply about part
ORDERED SONY PROJECTION REPLACEMENT LAMP - SHOULD ARRIVE IN ONE MORE DAY - KEEPING FINGERS XXX'D THAT THIS WILL RESOLVE THE PROBLEM - BUT THE TECH WAS EXCELLENT RESOURCE! I'M CONFIDENT IT WILL FIX THE PROBLEM AND THRILLED WE CAN DO IT OURSELVES AND SAVE $200! THANKS !
Posted on May 19, 2009
Snx 32gt1 internet tv wont come on
Probably a failing power supply
Jan 14, 2017 | Sony Televison & Video
I have a Sony Wega KDF-E55A20 rear projection LCD TV. The screen stays black when pressing the Power On button. When the Power on button is pressed, a GREEN blinking light (5th light in a row of 5) comes...
It sounds that the SCL ' SDA signal path has some short. You must have thorough knowledge in electronics to follow. Checking I2C bus signals is a skilled work. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy.
Apr 21, 2013 | Sony KDF-E55A20
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Screen went black no sound no picture when i turn the power on power light comes on green i hear a click and then it goes blinking red
How many times red light blinks? It is error code of problem in TV.
There would be pause of 3 seconds between blinks so count from pause to pause and let me know to find out solution.
Aug 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Wrong model showed up on my question - need new reply about part
May 18, 2009 | Sony KV-36FV26 TV
Green standby/power light bilnks and pic goes out
you have defective power supply! at the hot side section!
Oct 08, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KV-36FV26 TV Logo
2,598 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
