Question about Cell Phones
Micromax x282's clock is fast running whats the problem ?
How do I adjust the clock when it's running slow?
If your cuckoo runs too fast or slow, the best way to correct this problem is to set your cuckoo to an accurate watch or clock. After 24 hours, record how many minutes your cuckoo is running too fast or slow. Then adjust the bob up or down the pendulum stick to change the pendulms effective length. You'll need to take an educated guess as to the distance. Reset the cuckoo minute hand time to your watch or clock again. Repeat this process every 24 hours, recording the results, and readjusting the bob until you are within 3 minutes of the correct time. Then, switch from recording every day to recording every week. Use the same process described, recording the time difference, adjusting the bob up or down every week, until the cuckoo is accurate within approximately 3 minutes per week. Remember, mechanical cuckoo clocks are not as accurate as quartz or electric clocks! A three minute error per week is not bad. Maybe you can do better. What you are attempting to do is to obtain is the best timekeeping possible from your cuckoo clock. Afterwards, you will still need to sychronize the cuckoo (coo coo) clock minute hand to an accurate clock or watch, each week or as desired.
Feb 14, 2016 | Audio Players & Recorders
When we reset the clock after a power outage, the clock runs fast now almost a minute in 30 seconds. Bosch HBL5750
Advise manufacturer; may give you a warranty on this part even after it has expired because of nature of the problem.
Mar 08, 2015 | Bosch HBL5750UC Electric Oven
My clock is running fast and I can't figure out why?
With the new digital clocks, there is really nothing you can do to fix this. The clock running fast is due to a faulty electronic or electric component that is out of tolerance. US electricity runs at 60Hz, which is 1 cycle per second. Clocks use this to advance the seconds on a clock. Too fast means the 60Hz on the AC power input is not being properly used and is running the clock at something less than 1 cycle per second.
Jan 27, 2015 | Audio Players & Recorders
Frigidaire clock runs fast
Assuming you're using it in the US and it's not set via the controls for operation on 50Hz, then it may just need a hard reset.
To do that, you would unplug it for about 2 minutes, plug it back in, and try it again.
Jan 09, 2013 | Frigidaire PLMV169DC Microwave Oven
After a short power outage, I have clock issues.
this a problem with the clock , but the microcontroller can be defective by the power outage, see the diagram . how the microncontroller has the control for any equipment.
IN SHTE M.CONTROL BOARD CAN BE DEFECTIVE. go to the repair shop Tv FOR FIX IT. God bless you
Jul 19, 2012 | Microwave Ovens
Why do my clocks run fast when my Briggs & Stratton 15kw generator is running?
Electric clocks use synchronized motors that run on 60 Hz AC. The power company provides AC power with a precisely regulated frequency of 60 Hz. That means that the voltage jumps back and forth (positive to negative) 60 times per second. Your generator would do the same thing if it could run at precisely 3600 rpm (that's rev's per minute) - but it can't, because the engine is not that precisely controlled. In your case it tends to run (on average) a little fast. I hope you found this helpful. By the way, in Europe 50 Hz is the norm. If you run a clock designed for 50 Hz on 60 Hz power, it will run 20% too fast! Al K
Jun 20, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Want to by micromax touch screen phone.. in 4500 ruppes.. plzzz suggest me....
Thanks for posting on fixya and we are pleased to help you at the earliest . I would suggest you the new Micromax X550 which is an upcoming Dual sim GSM mobile phone featuring large Touchscreen display.It sports 2 mega pixel camera and up to 8 hours of talk-time.You can also browse fast Internet with the pre-loaded Opera mini browser and WAP/GPRS.Micromax X550 Qube is running the 3D Cube user interface.
Hope it helps you. Great time. I appreciate your valuable feedback
Nov 03, 2010 | Cell Phones
2008 Pathfinder LE clock runs fast
No solution yet... mine keeps running slow - supposedly there is a disc that the dealer can put into the CD player to fix some clock problems, otherwise you have to take out the whole unit & replace it, is what I'm told - people on the phone keep ducking the question & directing me to a dealer 500 miles away.
Apr 13, 2010 | 2008 Nissan Pathfinder
Cell Phones Logo
43 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
