Question about Exercise & Fitness
Rio body pro 12 manual - Exercise & Fitness
Yellow shadow
Hello Joseph,
Is it possible to print and scan your printer's built-in internal test card.
Then include a link to a good high resolution scan of the test card?
On the Rio, Rio 2, and Rio 2e, push the small button on the rear of the printer (with the lid closed, and dye film fitted). For the Rio Pro, on the front panel choose Menu -> Test Card - Yes (to confirm).
This will help identify the cause.
Exactly which model do you have? There were several Rio models. (the one in the picture is the original Rio). Later models were Rio 2, Rio 2e, and currently the Rio Pro.
Kind Regards,
MC
Apr 15, 2014 | Magicard Rio Card Printer
Flipper error
Hi There,
Only the Rio Pro model has a flipper fitted. If it is the Rio Pro, there will also be an error number at the end of the error (18:??).
Kind Regards,
MC.
Feb 25, 2014 | Magicard Rio Card Printer
Printing lines on cards
Hello Richard,
Sorry for the delay in replying to your request.
You may have already resolved your issue by now.
The advice below may help others with the same issue though.
In the case of a damaged (scratched) printhead, the lines always run along the cards longest length (landscape), and are always in exactly the same place.
They are normally White, and usually very thin (just a few pixels wide). You would also see the line on the used dye film too by unwinding some film from the take-up spool (at the front of the printer).
Sometimes in the case of older out-of warranty printers, it is easier / cheaper just to avoid that are of the card using the card design. The image can also be rotated 180 degrees in the driver's Printing Preferences. However, if the card design has a solid colour background, or the White line is in the centre of the card, printhead replacement may be the only option.
Depending on which Rio model you have (Rio, Rio 2, Rio2e, or Rio Pro), different printhead assemblies are available as a field replaceable unit. Part numbers are below;
Magicard Rio - FG/M9005-794
Magicard Rio 2 / Rio 2e - FG/M9006-630E
Magicard Rio Pro - FG/3652-0160
All are available from your local Magicard dealer / reseller.
Prevention is better than cure;
  • Replace the sticky cleaning roller in the cleaning cassette as regular as possible.
  • Only use good quality blank PVC card stock (no sharp edges, or burrs)
  • Clean the printer regularly using the appropriate cleaning kit;
    Rio, Rio 2, Rio 2e (Cleaning kit part number: M9005-761)
    Rio Pro - (Cleaning kit part number 3633-0053) *
    Rio Pro - (Sticky roller kit (5 rollers +metal shaft) - 3633-0054)*
    * A sticky cleaning roller is supplied with every new dye film
Kind Regards,
MC.
Dec 03, 2013 | Magicard Rio Card Printer
REMOVE THE ALTERNATOR IN KIA RIO 2003
The link is to the factory manual for a 2005, but it should be the same on the 2003 models.
http://ww2.justanswer.com/uploads/joecamel90/2010-12-29_153358_alt.pdf
Feb 04, 2013 | 2003 Kia Rio
2003 SUNQUEST PRO 24RS MANUAL TANNING BED
I Have a m2 24rs8 tanning bed. I loved it . I have moved it was in storage for 2 1/2 years. Moved to a new house. I hooked my bed up. the only thing it does kinda turn the fan on. what have I done wrong....It is on a 20amp bracker. Wire is 12 2 with ground. HELP PLEASE
Aug 25, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Rio pro error code 24:04
Hi Magicard Rio Pro message:
"General Error : Contact technical support, quoting error 24:04".
Somebody help me?
Jun 28, 2012 | Magicard Rio ID 2 Card Printer
Bottom Bolt size For Kia Rio Alt.
A bottom bolt is most likely going to be, metric because of the make, a 12 to 15 mm. I don't have a Rio to go look at and that type of information isn't in any of the repair manuals on the market.
Dec 12, 2011 | 2004 Kia Rio
What is the correct repair (chilton, haynes, whatever) manual for the 2003 kia rio (5/spd man trans,W a/c & p/s)??
I like Haynes better than Chilton and don't know the origins of this download but the price is very fair at ~$12 US. Not as convenient as a hard copy but your choices may be limited:
Kia Rio manual
Apr 06, 2011 | 2003 Kia Rio
I have a code on my 2004 KIA that reads po113 that says its a intake air temp cicuit ware is that on my car
The Intake Air Temperature sensor sends a reading to the main engine computer as to what temp the incoming air going into the engine is, for maximum engine fuel efficiency. On rio's, they often go bad due to their location in the intake manifold.. They are a bit tricky to get to, so take your time and use a 10mm socket with a 12-16" extension. They are located just to the right of the throttle body in the back area of the engine. Otherwise have a pro fix it.
Jan 25, 2010 | 2004 Kia Rio
Exercise & Fitness Logo
53 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
