Question about Gateway FPD2275W LCD Monitor
Problems with Samsung 2026BW monitor
Pressing the 'Auto' button bottom rhs of screen puts message on screen:
"Auto adjustment not available"
Have just bought it and all else seems to be OK. Is this a fault?
many tks
  • ianclewes Oct 18, 2007
    Mant thanks! Typically, just after I posted  I realised that similar monitor in PC world was connected to Analogue signal; mine now on DVI as you suggested! So no problem but tks for prompt reply.
  • 4,889 Answers
  • eagle338
    eagle338 Oct 18, 2007
    You are welcome..And please rate this thread as a personal favor...
I have a Samsung 920NW monitor. We moved office and after the move the screen shows "auto adjustment locked" after I put my computer on. I have noticed that the keep getting this message when i...
Hello sadiek, in the moving processs some one must of press one of the setting buttons at the bottom right in front of the screen if you press the first ont from the left "MENU" you will find in that menu a page to "unlock" the auto adjustment
Hope this helped, Pierre
Aug 03, 2011 | Samsung SyncMaster 920NW Monitor
I was cleaning the bottom of the screen and hit the color. Now it is blue and very hard to look at. I am at work, so I need this fixed
There should be a button that pulls up a menu to adjust color/contrast/ bright, etc. Press it and go through the menu options by either repeatedly pressing the menu button, or by using up-down-right left arrows. Adjust your colors using these options, or if available, try "auto" adjust.
I don't know this particular monitor, and am no "expert", but these options should be available on virtually any LCD monitor. A final option, if adjusting these does not help, look at all the menu - settings. If you see "recall" or "restore" or "default" anywhere, try selecting that option.
Good luck
Dec 08, 2010 | 3G Technology 726A (Black, Silver) 17 in....
Need to get screen size to show all . cant see
Things to check: Are your display settings set to "native resolution" of your screen. The native resolution is the actual dimensions (in pixels) of your flat-panel screen.
Looks like the Dell E153FP 15" has a native resolution of 1024x768. In windows, go to your control panel, in display settings, and ensure the resolution is set to 1024x768.
If that does not work, you can try the "auto adjust" feature on the monitor. On many Dell monitors, you can get this by pressing and holding the + button (on the monitor). You'll see the words "auto-adjust" appear on the screen if this works. If that doesn't work, you may be able to find auto adjust by navigating the menues in your monitor's menu, which you can get to by pressing the "menu" button on your monitor (sometimes this looks like a little rectangle icon). If it's an alignment problem, this should fix it right away.
If neither of the above work, it's probably your video card. Make sure your video card drivers are the correct ones for your card and OS, and up to date. You can also mess with display options under Control Panel > Display, under the "settings" tab, and at the bottom click the "Advanced" button, and it will bring up the advanced settings for your videocard.
Apr 23, 2010 | Dell E153FP 15" LCD Monitor
"auto adjust blocked" message recors
there is auto button on the screen as well try from there
Feb 11, 2010 | Samsung SyncMaster 171S 17" Flat Panel LCD...
How do I change the setting on my Syncmaster monitor if I can't see anything but the message box..."Not Optimum Mode recommended mode 1280x1024 60 hz?
You could try pressing the auto adjust button (simply says 'Auto'), and see if that changes anything...don't know if this will work, but it is a start.
Sep 29, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
Depends of what seems to be a problem.
If you want to get rid of that message box, appearing by itself, then probably you need to take front panel PCB with buttons and replace "Auto" one, 'cause it's stuck.
If you want to unlock an Auto Adjustment and other functions in your monitor, then press and hold 'Enter' button for 5 seconds.
Sep 14, 2009 | Samsung SyncMaster 17" LCD Monitor
Auto adjust doesnt work
try to push the menu button for 5sec, maybe it will be solve the problem..
Jul 11, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
Auto Adjustment won't work on Samsung 2253BW 22" LCD monitor
I looked up your monitor and that resolution is not supported. Which means auto adjustment will not work.
The video card will compensates for that, and resizes the picture for a display resolution that shows the picture anyway, (if it can) but isn't what you wanted. Your best bet is to use resolutions that are compatible, or get a (different) monitor.
Feb 10, 2018 | Samsung SyncMaster 913N 19" LCD Monitor
Auto adjastment locked
Samsung implements protection into their monitors, which allows to block all settings except brightness and contrast. This "Locked" mode turns on by pressing and holding 'Menu' button for 5 seconds, and turns off by pressing and holding 'Enter' button for 5 sec.
Mar 02, 2008 | Samsung SyncMaster 193V 19" Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
161 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
