Question about PNY Electronics - Others
What is the speed of PNY 64COMHHHJ-HS memory?
This DDR3 RAM does not say what speed it runs at
  • 176 Answers
SOURCE: Bios reports incorrect memory speed
try to update the BIOS ! ... it may correct the problem ...
http://www.epox.com.tw/eng/support.php?ps=424&type=1
when using only one module at a time, doest it work on the correct speed 800Mhz ?!
the system will be working on the BIOS declared parameters, at 677 !
Also read all the indications in the motherboard user manual, regarding memory (supported brands, speed, slot allocation .... )
thought i hope the BIOS update will do the trick ...tell me if it worked ...
Posted on Jan 25, 2008
shugster
  • 93 Answers
SOURCE: PNY memory problems
sounds like its a ram frequency mismatch to be honest
altho they are both 200mhz there is a mismatch occurring
Posted on Mar 25, 2008
wayneard
  • 1901 Answers
SOURCE: WHAT IS THE SPEED OF THIS PNY 64AOTFTHE-HS MEMORY
This is a PC2-5300 module, which is DDR2 667MHz.
Thanks for using Fixya.
Posted on Oct 25, 2009
darkdragons
  • 835 Answers
SOURCE: how can i know my RAM TYPe and speed ??
The best way to know what you need is to search for it on the web type in "Thenameofyourcomuter""specs"
if your comptuer is the Lenovo ThinkPad R400 notebook
then your specs are
RAM Configuration Features 1 x 2 GB Memory Specification Compliance PC3-8500 Technology DDR3 SDRAM - 1066 MHz Installed Size 2 GB / 4 GB (max) Form Factor SO DIMM 204-pin
Witch means its only upgradable to 2 gigs.
to see what is in thier now start your computer up, Go to my computer, right click on it and go to properties. Under that it will show information about your comptuer.
Posted on Dec 20, 2009
SOURCE: Can you tell me the specs on the following memory.
upgraded memory in computer, now video doesn't display.
Thanks,
Richard
Posted on Jun 23, 2011
Will PC2700/pc2100 work in my dell n5010
no it cannot work
Dell N5010 is a DDR3 memory
Correct spec speed is
DDR3-1066/PC3-8500
Sep 12, 2015 | PNY Electronics - Others
Does PNY DDR3 work in HP Pavilion C6537c-b?
Consider downloading a manual for you model for the answer.
what type was in it before? IT wil require the same type but it has space limitations.
www8.hp.com/us/en/home.html
Jul 05, 2014 | PNY Electronics - Others
Does 1rx8 ram go along with 2rx8?
Look at your motherboard manual, it tells you what kind of memory, which slots to use for number of sticks.
Your statement makes no sense, 1r, what is this ?
There is speed and size of memory.
DDR-, DDR 2 or DDR3, then speed, DDR3 2000 which each speed has a corresponding number.
DDR3 2000 is called ( PC3 16000 )
The chipset of the motherboard dictates what size and speed of memory that it can use.
Dec 05, 2012 | Biostar Computers & Internet
Ram memory does not work in my computer
ram does work in your pc. it works in every pc. Now the type of ram that works is the root of the problem. Basically your looking at 3 types of ram and really only 2 probably unless your pc is a dinosaur. They are DDR II and DDR III Make sure your PC uses the type you purchased. Also, make sure you have the system requirements to run that large of Ram.
Oct 24, 2012 | PNY 8GB Kit 2x4GB PC3-10666 1333 MHz DDR3...
Model type & number of 512mb or 1gb ram memory for
There are many different specifiactions for RAM.
Firstly is it Desktop or Notebook RAM that you are looking for.
Below is a list of RAM specifiactions:
DDR
DDR2
DDR3
Now these RAM specifiacations run at different clock speeds.
For example:
DDR 400MHz
DDR2 800MHZ
DDR3 1333MHz
What I need you to do is to tell me the following:
What is it to be used for, Desktop or Notebook/Laptop?
What is written on the RAM modules? You may need to remove one from your computer or use a software program like CPU-Z to check what it is you are running in your computer.
Reply via a comment to this post!
Take care!
damnor01
Sep 13, 2011 | ASUS Computers & Internet
Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
You may have tried to put too much memory (RAM) onto it.
That models maximum spec is:
Memory upgrade information:
  • Four DDR3 DIMM (240-pin) sockets
  • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
  • Supports Dual channel memory architecture
  • Supported speeds
    • PC3-10600 @ 1333 MHz*
    • PC3-8500 @ 1066 MHz
      *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
  • Non-ECC memory only, unbuffered
  • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
  • Supports up to 4 GB on 32-bit PCs
You can find the specs and troubleshooting help files here
Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
I have a m4a78lt-m motherboard will kingston ddr3 1600 4gb khx1600c9d3b1k2/4gx memory work with 32bit os I am putting a system togather have purchased the mother board and memory now i am questing if it...
This motherboard uses DDR3-SDRAM, ECC and non-ECC, unbuffered, PC3-10600(1333mhz) or PC3-8500(1066mhz), dual channel architecture (two sticks at a time), and a max memory of 8Gs.
This are the specs for your ram: 4GB 1600MHz DDR3 Non-ECC
(Kit of 2) Intel XMP HyperX = DDR3-1600
Default = DDR3-1333 CL9-9-9-27
CL9-9-9 1.65V
1.5V
In other words, Yes! This should work just fine. The ram will just run at its default speed of 1333mhz.
Jan 28, 2011 | ASUS M4A78LTM LE Motherboard
I dont know wat sort of ram to choose for this board because i am wanting to put in x6 4 gig ram ddr3 memory modules
running triple channel memory with more than 3 DDR3 1600 sticks installed (4-6) cuts the memory speed in half. you have to run with 3 sticks at a time in triple channel mode or you will see a reduction in ram speeds.
OCZ is making some good 4 gig ram sticks. they have a 12 gig triple channel memory kit with 3x4gig sticks. you could get 2 of these kits and have your 6 sticks- 24 gigs total, but your memory frequencies will be lower- your ram access will be slower.
Oct 28, 2010 | ASUS P6X58DE Desktop Board Intel Chipset...
PNY memory problems
Mar 25, 2008 | Gigabyte GA-K8VM800M Motherboard
Electronics - Others Logo
543 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
