Question about Asko Dishwashers
Asko D5223 troubleshooting
How to troubleshoot asko D5223 dishwasher that won't start
  • 55 Answers
SOURCE: Asko 3350 Dishwasher
The "F7" code means that the drain is blocked. To remove items from the drain: 1.Turn power to unit off. 2. Remove the "Coarse Filter" by squeezing the tabs together and lifting out. 3. Remove the "Fine Filter" and "Main Filter" by removing the screws around the filters and lifting them out. 4.Remove the small black adapter piece and check the sump area for debris. 5.Wash the filters out gently with hot, soapy water. DO NOT RUN THE UNIT WITHOUT THE FILTERS IN PLACE! 6.Replace the black adapter piece to its original position FIRST (Important!). 7.Replace the filters in reverse order of removal and turn the unit back on. The error code should reset and work normally. *In areas with hard-water, the filters should be removed every 8-12 months and submerged in a chemical solution (CLR or LimeAway) to remove mineral deposits. Hope this helps...
Posted on Sep 04, 2008
jonniewalker
  • 1029 Answers
SOURCE: Asko door latch stuck
The only way is to pull out the dishwasher ,unhook the latch and then unscrew the door panel.your dishwasher is installed with 2 screws to the underside of your countertop. its tricky but youll have to remove them adjust to leveling legs down this will give you more room to get some head bit in ther to remove the screws if its out then slide the d/w foward ,remove the strike plate door will open then you can get your dishes out first
Posted on Sep 20, 2008
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
SOURCE: Asko D3100 dishwasher wont drain completely
I think I see the problem based on "futureloginn"'s highly rated solution. You have a dishwasher. You need to stop washing clothes in it.
Posted on Aug 21, 2009
SOURCE: Asko D3121 Dishwasher - won't dry dishes
Has anyone found a Fix for this one yet????
I have the same problem Dryer fan (Turbo Fan) in the door not working.
Posted on Mar 17, 2010
Asko dishwasher troubleshooting
Change the water level sensor
Jul 25, 2014 | Asko Dishwashers
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
Asko 1385: 13 year old dishwasher stops during cycle. If you push on the middle of the door it starts again. It is like the latch is not working properly but by all appearances the latch works fine....
when you latch the door it closes the circuit.
you may have to open the casing of the door to access the switch. it may be stuck or defective.
May 15, 2010 | Asko 1385 Dishwasher
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Asko dishwasher problem
Hello, What you are describing is called an overfill. Sometimes programming, soap usage or installation can cause this. ASKO Customer Service will be able to give you troubleshooting tips and will most likely be able to fix this issue right over the phone as this is typically an easy fix. You can contact the ASKO Customer Care Group at 1-800-898-1879. They are open 24 hours a day, 7 days a week for your convenience. Sincerely, AM Appliance Group
May 28, 2007 | Asko 1595 Dishwasher
Dishwashers Logo
344 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
