Question about Hoover Vacuums
Dismantle a hoover xarion
Complete o pensino procedure power cord internal malfunction
Replace power cord on Hoover windtunnel vacumm
There are many different models of Hoover Windtunnel so I can't be specific to your model, you will need to determine where the cord enters the unit and how to gain access to the internal wiring. Disconnect the old cord and attach the new cord using the proper connectors.
Apr 02, 2017 | Hoover Vacuums
I have a Hoover Rewind, the plug always got hot, tonight it just stopped working, I know it is not expensive and older but I really don't want to buy a new one if I can avoid it at this moment
I am not sure of the motor wattage but it is unlikely to exceed 2kw and is probably much less so that sort of load being plugged into a power outlet capable of safely delivering a much larger current is unlikely to cause heating of the plug. That the plug did become hot indicates a poor contact between the supply cables and power outlet, between the power outlet and plug or what seems the most likely, between the plug and the power cord.
Given that the plug has been getting hot and that most breakdowns of portable appliances including vacs are internal breaks of the power cord usually at or somewhere near the plug, so that would be a good place to start testing...
Mar 02, 2017 | Hoover Vacuums
How do I replace a severed power cord on hoover windtunnel upright bagless model U5280900?
Hi there! We recommend taking your vacuum to a Hoover authorized service center to have your cord repaired. Follow the link to locate the nearest service center to you. Thanks! Service Center Locator
Oct 13, 2014 | Hoover Windtunnel Supreme U5280-900...
Power intermittent: when cable is touched power returns
You have a broken power cord. Hoover is notorious for power cords. I'm speaking from personal experience. Replace/have the power cord replaced.
May 08, 2012 | Vacuums
How do I get the u5290-900 apart far enough to remove old power cord and plug in a new one?
First you need to remove the Dirt Cup followed by the front cover / handle. Page 4 1-6 of the PDF Manual below shows how to do this.
http://static.fixya.com/Manuals/H/Hoover/5288_900_prg_B4F5E4DE0DB02590E2525C367EFB5C4C.pdf
This should then give you access to remove the internal cover and replace your cable.
Jun 26, 2011 | Hoover U5290-900 Upright Vacuum
How to replace Hoover PowerMAX power nozzle cord?
You can get the new cord at your local vac shop or you can take the power nozzle to the shop and have it repaired
Apr 27, 2017 | Hoover Powermax S3601 Bagged Canister...
Hoover wiring
hello lukeplayer,
Based on your description, ( first disconnect the plug from the wall recptacle).You will need to open up the Hoover Vacuum Body to gaion access to the internal wiring. In order to better assist you, please provide me with the specific hoover model. In general though, you will need to see where inside the Hoover that wire became detached and then rerun it. Since your cord is already broken, you may be able to strip back more of the outer cord insulation to expose the internal conductors and then route, cut to fit and reinstall them. Hope that helps.. If not, send model details,,,
Regards,
Rick
Nov 26, 2008 | Hoover Vacuums
Replace interior hose for cleaning attachment for Hoover Steam Vac Agility
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=632107
Replace interior hose for cleaning attachment for...
Posted by castcomm on May 29, 2008
How do you dismantle handle to replace aforementioned hose?
Swing arm on unit goes all the way to the floor. Is this normal? Is there a "stop" broken that caused the hose to stretch, and ultimately break?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There are handle screws that you can get into the handle and then you can back track the replace the interior hose for the cleaning attachment. There should not be a stop that caused the hose to stretch ad break. The hoses after a while do get old crack and break due from normal use or if the bend @ sharp angles, this is common among all vinyl vacuum cleaner hoses. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Vacuums Logo
53 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
