Question about Behringer B215D Powered Speaker (550 Watts 1x15 in)
Speaker wont power - Behringer B215D Powered Speaker (550 Watts 1x15 in)
Behringer B112D wont power up until 10 minutes after switching on
This will be a power supply problem. Take it in to your repair shop for service.
May 07, 2016 | Behringer Eurolive B112D Powered PA...
Peavey pvxp p-12 speaker wont power on
RFeplace the fuse, then call Peavey Ciustomer Service.
May 12, 2015 | Peavey Music
No noise coming from right speaker
Change the volume control potentiometer.
Jan 31, 2014 | Alesis M1 Active 320 USB Speakers
My Yamaha psr-500 wont turn on. When I push the on button the speakers make a popping sound and when I hold the on button down I get static through the speakers along with 3 notes one after the other
Is this on mains or battery? This keyboard must be nearly 20 years old, it's done well! If you have batteries in but are using mains power, the power adaptor could have failed and not enough juice left in batteries to work. Try new batteries and try without any.
Aug 09, 2013 | Yamaha Music
Jbl eons 315 wont turn on
Check fuse located inside and let me know the result to help further.
Jan 24, 2012 | JBL EON315 15" 280 Watt Powered PA Speaker
I have the power 8030 that I bought in London. I've been using them with my step up & down transformers. I moved to another studio and a kept the same configuration but now the wont power up using...
Compare the power inout voltage listed on the BACK of the speaker and compare that to your current power supply. You have not told us wheree you are or what your power there is... or the voltage listed on the back of your speakers. Giv us this info so we can better help you. These are expensive speakers to get things wrong...
Sep 12, 2011 | Genelec 8030.LSE Power Pak Active...
Im useing the Yamaha MG24/14FX mixer, and ATM Kustom KSE215 speakers, seems like there isint enough power Granted these speakers are 300 or so watts, had a few problems with these speakers with my old...
The MG24/14FX is a mixer only, with no amplifier built-in. It can't drive speakers directly. You'll need powered speakers or separate amps and speakers.
May 16, 2011 | Music
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
My boss amp is on protection mode and it wont work its a 3500 watt chaos idk what is wrong with it
Likely one of the power amps has failed component(s) and does not achieve electrical balance which then goes to protect mode to prevent damaging your speakers.
You will need to have it serviced.
Dec 25, 2009 | BOSS AUDIO SYSTEMS Music
Behringer B215D Powered Speaker (550 Watts 1x15 in) Logo
49 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
