Question about Flat Panel Televisions
Conection Samsung LCD to sony home theater
Recently i bought LN3242 samsung 32"LCD. And now i ve an problem to connect with the sony home theater system. How to connect and which cables n wat r the input n output. Can u advice me Please
2 Suggested Answers
SOURCE: Input/Output Cord
Posted on Dec 17, 2008
  • 14 Answers
SOURCE: connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Posted on Apr 05, 2009
0 characters
1 Points
How to connect sony home theatre with sansui lcd connection with tatasky hd.
It is better to go through the operation manuals and follow guidelines step by step.
Aug 17, 2012 | Sansui HDLCD3210 32 in. LCD TV
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
No audio from tv to home theater
at the back off tv there is a connection labelled audio output you need to connect that to any available iput of your home theater receiver then use that for tv watching
Nov 12, 2008 | Vizio L32 32 in. LCD HDTV
Samsung LN37A550P3F shadow image
It seems new TV.
But that kind of problem is related LCD panel.
If you can replace LCD inverter first.
then not working need to replce LCD panel.
Jul 22, 2008 | Samsung HP-P3761 37 in. HD-Ready Plasma...
Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Feb 24, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
No sound from TV only when playing DVD
Check carefully the RCA conections or others.Sometimes this conections break inwards end cause this problems.Check also the lead and the Set up from surround sound.Verify if the TV has settings for this kind of operation. A strong hug !!!
Jan 16, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Can't use "plug&play" from TV menu
I can switch between shop mode & normal by holding down the menu key on the side of the screen, just press it till it changes.
Jan 07, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Home Theater - sound
If it is a new set up, make sure properall connector are properly connected. Have you tried removing the Bose just to isolate the trouble, just to pinpoint the source of that HUM. The sony is amplifying some unwanted signal.
Dec 21, 2007 | Samsung LN-T4665F 46 in. LCD Television
Flat Panel Televisions Logo
634 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
