Question about Toshiba Tecra M2-S730 Notebook
My toshiba will not see the hdd i suspect the hdd
My toshiba tecra m2 will not see the hdd i suspect the hdd ribbon connector where can i buy this ribbonpls help.
  • ologbojo May 18, 2009
    i change the hdd by removing the ribbon that attached the hdd casing to the laptop
  • Bastian Farkash
    Bastian Farkash May 11, 2010
    Internal HDD right? If so why do you suspect the Ribbon cable, have you removed the HDD to may times?
    I thought HDDs connect by a connectors, male and female instead of Ribbon Cable.
    Does the BIOS see it?
I have a cracked screen (toshiba tecra m2) and have an opportunity to buy a replacement screen from a tecra m2 S630 that is broken. Are the screens interchangeable?
Can't answer your screen question, but I can propose a workaround - your Toshiba laptop has a
monitor port on the back - you can plug in a standard monitor, and ignore the cracked screen
temporarily until you can replace it. hope this helps
The monitor port is the 15-pin analog VGA D-shell (female) port.
The online User's Guide for your Toshiba Tecra m2-S630
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=596874&rpn=PTM20U&modelFilter=M2-S630&selCategory=2756709&selFamily=1073768664
Apr 17, 2011 | Toshiba Tecra M2-S630 Notebook
The keyboard is not working
Connect an external USB keyboard, if there's no problems with it then remove your laptop's keyboard. First: Disconnect the ribbon connection and reconnect again
Second: If that doesn't fix the problem
Third: Buy a replacement
If the external USB Keyboard doesn't work you may have some software issues
Jan 25, 2011 | Toshiba Tecra M2 Notebook
Drivers for TOSHIBA tecra m2 ptm20u
Hi!
You can donwload free drivers from the following link---
Drivers for TOSHIBA Tecra m2 ptm20u
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Toshiba Tecra M2-S730 Notebook
Drivers
You can download them from Toshiba here
You'll have to have the complete model number of your Tecra M2-???? to find the correct set of drivers.
If you have questions about installing updated drivers, please consult this excellent tutorial on updating your drivers: XP or Vista
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 31, 2009 | Toshiba Tecra M2 Notebook
Driver required NETWORK CONTROLLER for Toshiba tecra m2
i can not find the wireless lan driver for tecra m2
Oct 05, 2008 | Toshiba Tecra M2-S730 Notebook
Video Controller for Tecra M2
download the drivers here
moz-screenshot.jpghttp://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=856523&moid=555698&BV_SessionID=@@@@0479891764.1177854602@@@@&BV_EngineID=cccfaddkklfiidjcgfkceghdgngdgnn.0&ct=DL
Sep 21, 2008 | Toshiba Tecra M2 P-M 1.7Ghz, 512MB, 60GB,...
Network Card Not working
Ok go to www.google.com and type the model of u r Laptop i.e,
TOSHIBA TECRA M2. and tell drivers for that laptop in the search box of google .com u get lot of links from thereu can download
Jul 31, 2008 | Toshiba Tecra M2 Notebook
SCHEMATIC OF HDD CONNECTOR Toshiba Tecra 730CDT
Which part of the connector is broken? on the drive? on the system board?
Nov 26, 2007 | Toshiba Tecra 730CDT Notebook
Toshiba tecra m2 bios missing sections of video
get to the mainboard
there is a jumper near the cmos battery usually shows the
word (jbat) near it , try to change its position for some
seconds while power is off , this way will clear cmos and set the
mainboard bios to default settings.
start the system hit delete or F2 to enter setup then exit saving changes.
Nov 08, 2007 | Toshiba Tecra M2 Notebook
Toshiba Tecra M2-S730 Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
