Question about Magic Chef CAV4000AWW Top Load Washer
22 mins stop - Magic Chef CAV4000AWW Top Load Washer
Washer stops at 23 min. Error code f1.Must restart til timer passes 22 min.
Check the air dome transducer hose first,
(the clear plastic tube that goes from the control board to the right side of the outer tub connection)
for kinks, clogs, twists,etc.
If the hose is OK,
Yes, you will need to replace the control board.
Here is the control to order.
Dec 02, 2012 | Kenmore Washing Machines
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag performance series washer model mhwe500vp stops mid cycle
having the same problem found in side a small black hose with a small hole in it but have no idea what this hose is for. may be it is connected to some water sensor.
Jun 27, 2009 | Maytag Performa PAV2200
Help me with a code reset panasonic fp7713
Press paper tray, zoom down key, and #1 keys simultaneously. "F1" displayed. press 8, start,then 09, start. DV will run auto for 3 min. hit stop/clear. F7-22 to clear PM count.Press stop/clear until F1 displayed. Press paper tray, zoom down, and stop/clear to exit maintenance mode.
Sep 08, 2008 | Panasonic FP-7735 Black and White Copier
When using and setting the timer (i.e. 2:00 mins), microwave would stop after 25 seconds and no heat. Please help. Thanks!
I bet it's 22 seconds. The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | Panasonic Microwave Ovens
Magic Chef CAV4000AWW Top Load Washer Logo
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
