I pad will not turn on - Televison & Video
    New Friend:
    Problem Solver:
  • 12 Answers
Check battery or ckeck battery charging indicator is working during charging time,if found ok and problem the same ,call qualified technician.
Posted on Dec 28, 2013
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
Nov 05, 2017 | Audio Players & Recorders
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
iPad just stopped working will not turn on Fully read the thread I have attached, there is a lot of useful info that may help assist in resolving your issue.
Feb 20, 2014 | Apple Ipad I-pad
Touch pad turn off
Hey Harvery,
To turn off the touch pad on your system you can right click on the touchpad properties and choose touchpad properties located on your taskbar to the right. Once you have it open you will see where to turn the touchpad off.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 02, 2013 | Dell Vostro 1015 Laptop
No pad sound
Not sure what module you're using this with, but I'm familiar with Roland electronic drum pads and modules, and guess the following would stand true for any pad / module combo....
I would check the following:
  1. Is the cable correctly connected at the pad?
  2. Is the cable correctly connected at the module?
  3. Is the module sound turned up?
  4. Are your headphones / speakers turned on & up
    (do other pads sound)?
  5. Is the fader for the specific pad (or pad group) turned up?
    (On a Roland module, where the pad is AUX1 to 4 - the 'fader' button needs to be pressed in order to operate the AUX slider).
    The next couple of things are less likely, but possible.
  6. Does the pad have a polarity switch on? - try switching it.
  7. Has he correct pad type been assigned in the module?
  8. Has an instrument been assigned to the pad
    (Roland: Press INSTRUMENT, hit the Pad, select a sound)
If you get no joy with this - please drop me a message.
Dec 30, 2012 | Alesis e Practice Pad Electronic Drum...
Editing Problems
You have Pad Chase turned off. Turn it back on.
Mar 11, 2012 | Roland Spd-S Sampling Percussion Pad...
My toshiba satellite A355D touch pad is not working. my husband told me that probably my kid turned it off. if that is the case... how can i turn it on?
Sounds like your touch pad may need to be replaced.You can't really turn off the touch pad.Even if your child managed to uninstall the touch pad it would load back the drivers at next startup.Chances are the touch pad will have to be replaced.Its possible the touch pad may be disconnected from the motherboard but not very likely though.
Aug 24, 2010 | Computers & Internet
Just taken the old brake pads off the car and the pistons wont move in order to get the new pads on
With the new pads in place, loosen the bleeder valve a few turns while applying pressure to the pads. A small amount of brake fluid will likely spray out as the pads and pistons move, so have a pan or a rag ready. Once the pads are flush with the edges of the caliper, retighten the valve - making sure that the pads don't move.
Nov 08, 2009 | 2004 Jaguar X-Type
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
BRAKE LIGHT
This light should turn off if you replace the pads with pads that have the indicator wire on them. The light truns on when you wear the pads down to the wires and the wires break and cause an open circuit that turns on the light. If your new pads have the wires and are installed correctly, the light should turn off by itself.
Sep 30, 2008 | 2003 Audi A6
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
