Mitsubishi hs u500 vcr will temporarily load a tape, but then ejects it.
When a tape is inserted, the tape loads against the heads, runs for a few seconds and then the tape is retracted back into the cassette and the cassette is ejected.
4 Suggested Answers
  • 883 Answers
SOURCE: Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Posted on May 20, 2007
  • 579 Answers
SOURCE: vcr hs-u500
Typical belt drive failure. Take the cover off and turn the loading motor shaft with your fingers until the tape is ejected. Get a belt kit for this model and replace all the rubber parts in your VCR. Mitsubishi's are nice units and worth fixing. Check the little pulley under the capstan motor for cracks or worse.
Posted on Dec 31, 2007
  • 52 Answers
SOURCE: Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Posted on Feb 09, 2009
Mitsubishi hs m50v
I forget exactly how this goes but there are two posts on either side of the mechanism that read a light signal and a center pole that goes through the round hole on the cassette that gives the light signal (no tape-end of tape). Put a piece of tape on the two side posts and see if that changes anything. Be careful: the tape now knows where end of tape is - do not fast wind/rewind to the end! The loading motor may have failed or a rubber belt has slipped off or is too loose or broken.
Oct 20, 2013 | Mitsubishi HS-U445 VHS VCR
E-2 error what does that mean
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
May 09, 2011 | Mitsubishi HS-U575 VCR
Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
Cannot load tape. keeps ejecting tape when trying to load.
Remove the top cover from the VCR. If you have children in the house, look for any object lying in the mechanism. If this is clear, insert a tape slowly into the carriage & watch carefully if the cassette tape flap raises up & allows the tape to be lowered down into the mechanism, if not the flap lever at the side of the carriage may be broken. If the tape does lower into position, look to see if the tape is being pulled out by the guide arms, (normally 2 white poles) one of these may be broken. Check the half loading arm is also not obstructing the tape. If any of these parts are broken a new deck mechanism would be required.
Jul 06, 2009 | Mitsubishi HS-U530 VHS VCR
JVC SR V101US won't load tape
most likely problem is defective loading motor. p/n VEM0427.
Jun 27, 2009 | Panasonic AG-1980 S-VHS VCR
Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
Mar 10, 2008 | Televison & Video
Vcr hs-u500
Dec 30, 2007 | Televison & Video
Dec 19, 2006 | Mitsubishi HS-U760 S-VHS VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
