Question about LG EzSign TV 42LN549E Digital Signage Display 42" LCD
FIRMWARE 42LN549E MY LED IS 42LN549E I NEED FIRMWARE FOR UPDATE SOM OF POCIBILITY DOES NOTWORK AND DIGITAL TUNER SO
Where do I find the Firmware update for the TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
I need the Firmware update for the TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR as well. Can anyone out there be of any help?
Apr 26, 2014 | Computers & Internet
I just bought a sony bravia led kdl46nx800 tv. love the picture, but the thing makes a hoorible crackling noise after the set warms up for about 15minutes. the noise persists intermittantly long after set...
This problems are not tv firmware.Firmware is for basic updating software,never cures hardware problems.This problems is the tv Tuner signal board itself,exchange it to another tv or ask for warrenty repair,just make sure they change the whole tv Tuner signal board.This problems could be anythings in tv Tuner signal board circuitries causing this problems.
Dec 29, 2010 | Sony BRAVIA NX800 KDL46NX800 46 in. HDTV
Can not get all my chanels
Replace the tuner with a good one. That is pocible couse, "bad tuner"!
Apr 21, 2010 | Philips Magnavox 42MF521D/37 Television
The remote only turns t.v. on and off doesnt turn satellite or tuner on any more does remote need to be reprogramed
Hi. I would try updating the firmware and updating the remote.
1. Connect the remote, and click 'Downloads' in the software.
2. Click 'Firmware'.
3. Update the remote.
Apr 08, 2010 | Logitech Harmony 890 LCD Remote Control
I have a Philips TV, model HD2717 C101. All channels do not display--Why? It skips quite a few channels on scan, the only to get them is to actually select the channel individually.
Hi are you running it off of an antenna or cable?
Assuming you have a digital tuner and are selecting the proper type of channel search Ie: cable or air it could be that the tv needs a firmware update to the tuner.
I have experienced similar issues with several TV's I had an Olevia 37" HDTV that required a firmware update to get the tuner to properly decode channels.
I also have seen lots of cases were people have cable hooked up without a cable box and receive "mixed" channels.
I currently have Comcast and have 6 TV's hooked up 3 with cable boxes and 3 directly off the line. According to Comcast I should not be getting anything besides "basic" channels without a box but using the digital tuner in the TV's does pickup most of the channels and even some HD channels that are not there using their boxes.
Interestingly enough none of the TV's tuners decode the channels into the same "channel." As an example HGTV on 1 TV shows up as 84.4 but then 86.1 on the second and something like 84.11 on the third.
My recommendation run the auto program again then go through channel by channel and see if anything needs to be manually entered or deleted. I know this is a pain in the **** and takes about 20 minutes per TV but hopefully that will tell you if your TV tuner is relocating the channels to another channel.
Lastly if your tuner is not digital or if the tuner can't be updated you may have to use a secondary tuner such as one in a VCR to get the channels you desire.
This whole Digital Conversion that we have undergone has brought to light for me at least that our government and corporations don't care about the real world impact on the ordinary person.
Sure they made money on reallocating bandwidth and sure tons of new HDTV's and digital products (including digital cable) have been sold but I haven't come across anyone who feels they have benefited from the conversion forced upon us.
Hope this helps sorry about my rant.
Dec 28, 2009 | Philips Televison & Video
Is there a firmware upgrade for the 32dw6834 tv to improve digital signal reception?
this TV Tuner is analog Tuner, dont have any digital tuning, only control and process is digital, so not have any possibility a firmware for tuner, only for boards of control and process video/audio
Nov 22, 2009 | Philips Televison & Video
My sony bravia digital channels always drop out of signal. Sometimes a channel has no signal for a couple of weeks. Could that be a fault with the tv?
For tuner problems, especially the digital channels, you should check for a TV firmware update at www.sonystyle.com. I was having some strange loss of digital channels on our 40" Bravia, starting with channels only appearing for a second before the screen produced a 'No Signal' message. After we tried the automatic retuning, then we could not even get the one second signal. None of this appeared on the description of the download. However, we downloaded the patch to our PC, loaded the file (19 MB) onto a small flash drive, which we then used to upgrade the firmware in the TV. All our digital tuner problems disappeared!!
Oct 16, 2009 | Sony Televison & Video
42 in hd flat screen
If your TV was "Built" prior to November 2006 it does Not have a Digital tuner and you need a converter box (if you are using an off-air antenna) Hope this helps
Jul 07, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Screen got freezed
Try resetting the player....
Resetting the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. Slide the Power switch up then release to turn on the player.
Try it twice atleast.
If the above doesn't help, then you may have to update the firmware....
Click here to follow the instructions: Updating Sansa Clip's firmware
Feb 19, 2009 | SanDisk Sansa Clip MP3 Player
CAN'T FIND THE FM TUNER IN THE MENU
  • The player may have to be formatted, which will erase the contents of the player. If you would like to manually update the firmware, please see below.
  • Please note that some firmware updates may format the player. Please read the installation notes for the firmware update before downloading it.
The MP3 Player Recovery Tool can be downloaded at www.creative.com/mp3playerrecoverytool.
Jun 20, 2008 | Creative Labs ZEN Vision:M Digital Media...
LG EzSign TV 42LN549E Digital Signage Display 42" LCD Logo
41 people viewed this question
Computer Repairing
Computer Repairing
