Question about Vehicle Parts & Accessories
Indicators blinking indicator of my bmw 325i 2007 is flashing faster. it works when engine is cool but flashes faster soon as i start driving
    New Friend:
    Problem Solver:
  • 14 Answers
Could be air bulble in rad,block,or hoses
Posted on Dec 28, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Cooling fan/ Radiator indicator
I would recommend first to check the coolant level. If the coolant level is too low it can cause the fan to run if it detects too low of a coolant level. Also, the low warning can be a result of a low level. Make sure to check the level with the engine cold, and not running.
Sep 12, 2017 | 2006 BMW 325i Ci
Tip
How To Check & Reset Your 2002-2006 Nissan Altima Service Engine Soon (SES)...
The following directions will help you decode your 2002-2006 Nissan Altima's Service Engine Soon (SES) light and reset it.<br /> <br /> <span style="font-weight: bold;">Obtain The Trouble Code</span><br /> <ol> <li>Turn the ignition key to the ON position and wait three seconds.</li> <li>Put the accelerator pedal to the floor and release it five times in less than five seconds.</li> <li>Wait exactly seven seconds. Put the accelerator pedal to the floor for ten seconds until the SES light flashes.</li> <li>Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.<br /></li></ol> <ul> <li>Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates a zero.) </li> <li> The next three digits blink faster (0.3 second) and have a 1 second pause between digits.</li> <li>The ECM code repeats until you turn the ignition key to the OFF position.</li> <li>You can look up the trouble codes in the Service Manual.</li> <li>If you get four blinks of ten, or 0000, the ECM indicates no malfunction.<br /></li></ul> <br style="font-weight: bold;" /><span style="font-weight: bold;">Clear The Trouble Code</span><br /> <ol> <li> Clear the code and the SES light by holding the accelerator pedal down to the floor for 10 seconds or more while the SES light is blinking.</li> <li>When the pedal is released, the ECM will erase the trouble code(s).</li></ol>
on Feb 15, 2011 | 2002 Nissan Altima
How to reset engine lite in dash
Check engine light comes on and off, these are indication that there is some error code stored in your vehicles ECM. The engine module computer needs to be scanned. These will give the code and as per the error code the further problem can be detected and confirmed. The engine light indicator blinks or remains steady on dash when engine computer noticed any problem with any engine electrically operated components.
For more help, I suggest you to refer the help links provided below. These will let you know more about which areas to look, check, when there is engine light coming up on dash panel.
Click the link below: -------
Check Engine Light Reset Procedure?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
Check Engine Light ON?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-on.html
Intermittent Check Engine Light?
http://whoisbyme.blogspot.in/2012/06/intermittent-check-engine-light.html
WHY Check Engine Light On car?
http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
Check Engine Light, VSC light and Traction Control Light ON?
http://whoisbyme.blogspot.com/2012/06/check-engine-lightvsc-light-and.html
Check engine light flashing?
http://technoanswers.blogspot.in/2012/02/check-engine-light-flashing.html
Service engine soon Light Turned OFF after Jump Start?
http://whatisbyme.blogspot.in/2012/06/service-engine-soon-light-turned-off.html
After replacing throttle body the Check engine light starts blinking?
http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
2005 Chevy Impala: Service Vehicle Soon Warning Light?
http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html
Malfunction Indicator Light ON
http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
Check power-train message with orange engine light came on?
http://howtobyme.blogspot.in/2012/02/check-power-train-message-with-orange.html
2007 Toyota Highlander Hybrid: Yellow Check Engine Light ON dash?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
1999 Toyota Tacoma: Check Engine Light Read Code P0171?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-tacoma-check-engine-light.html
Car Runs Fine But Check Engine light is ON?
http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Vehicle smog test failed Due to NO MIL/check engine light?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Car jerks while going uphill and Check engine light is ON?
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
Toyota Camry Check engine light flashes while driving?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
These details will help.
Thanks.
Nov 28, 2012 | 1999 Acura CL
I drove the jeep the day before and it was fine the next say i get in and the check engine light came on and was flashing and it was idleing (shuttering) what could this be?
To confirm the exact fault,the error code stored in engine computer module has to be retrieved.
But as why check engine light came up,for that issue there are few help link with solutions to correct the issue.========
Click the link below:---
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
------------How to Read Codes from Check Engine Light? http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
------------Check Engine Light Reset Procedure? http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
------------- Check Engine Light ON? http://whoisbyme.blogspot.in/2012/06/check-engine-light-on.html
----------- Intermittent Check Engine Light? http://whoisbyme.blogspot.in/2012/06/intermittent-check-engine-light.html
---------- Service engine soon Light Turned OFF after Jump Start? http://whatisbyme.blogspot.in/2012/06/service-engine-soon-light-turned-off.html
---------- 2005 Chevy Impala: Service Vehicle Soon Warning Light? http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html
--------- Malfunction Indicator Light ON http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
--------- Car jerks while going uphill and Check engine light is ON?
Toyota Camry Check engine light flashes while driving? http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
----------1999 Toyota Tacoma: Check Engine Light Read Code P0171?
2007 Toyota Highlander Hybrid: Yellow Check Engine Light ON dash? http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
--------Check engine light with codes P2195 and P2197? http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
---------Car Runs Fine But Check Engine light is ON? http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
----------After replacing throttle body the Check engine light starts blinking? http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
---------OBD Code is cleared but check engine light will not RESET? http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
--------These will help.Thanks.
Nov 22, 2012 | 2002 Jeep Grand Cherokee
Replaced Aprilia rs50 2006 indicators with LED ones + LED flasher relay though they light up but DON'T FLASH?
I am not a electronic wizz but i believe the led's will light up but do not have enough resistance to cause the internal breakers to work.
I found this.
The post that had the link said that it fixes fast blink and no blink conditions. http://www.greggscustoms.com/instruc...istor_Inst.pdf
Oct 13, 2012 | 2007 Aprilia RS 50
My 325i shut down on the interstate. The oil light had been on so i assumed that may have something to do with it? As soon as i pulled to the shoulder, it started smoking. Help please!
Not good-two things you cannot ignore on any engine is the temperature gauge and the OIL LIGHT-at the very least, you need to let it cool down, and check your oil level-if it is outside the hatch marks that indicate normal range, fill it and start it up, listen for anything unusual. If it seems alright, gently drive it and have it checked out for leaks, or damage-or, you might just have it towed to a good mechanic since, if this was due to low oil pressure, you may end up needing a new engine-good luck.
May 31, 2011 | 2003 BMW 325
BMW 325i 2001. Hi the flashing indicators work on both sides but no noise or light from the dashboard regards Kenny
Yes prob solved. When the battery went low the transient generated when I tried to start it caused a glitch in the computor management system and I reset it by removing and reconnecting the battery. All now working.
cheers
Kenny
Nov 12, 2009 | 2001 BMW 325
2001 325i. Hi, my batt went low as usual(too many starts and short runs) and wouldnt start( clicking relays and headlights come on). I charged the batt in-situ , now the flashing indicators work but no...
Battery should not go DEAD,have charging system tested with car running should have at least 13.2 volts at the battery. get back to me if you need more help Thanks Ray
Nov 09, 2009 | 2001 BMW 325
CEL, flashing cruise control and vehicle dynamics controll OFF lights on Subaru Tribeca
It is safe to drive your car. What happened was you have a Check engine light on indicating a problem with the emission diagnostic system. This also makes your cruise not work, and the light to blink. Take your car to your dealer at your convienence and have them diagnose it.
Nov 04, 2008 | 2007 Subaru B9 Tribeca
BMW 325i right turn indicator
Turn indicators blink a lot faster when a bulb is blown or a wire is diconnected. Check front and rear signal lights to make sure they work after you turn on right turn indicator.
Oct 16, 2008 | 2001 BMW 325
Vehicle Parts & Accessories Logo
23 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
