Question about Trophy Music Melody Harp By
I have a Bontempi lap harp with no instructions or music sheets. How do I tune it/play it?
I do not know what strings are what notes so that I can tune my lap harp. The harp has sixteen strings and is badly out of tune.
2 Suggested Answers
SOURCE: how to tune (what key) my daughter's new trophy music melody harp
It is tuned in C or G major:
It is has F natural in both octaves, if you want to use the Melody Harp songpacks.
The notes are: GABCDEFGABCDEFG (2 octaves).
Lowest note (longest string): G below middle C. If you want to use the Music Maker Songpacks, you need to change the F notes to F sharp:
GABCDEF#GABCDEF#G
Posted on Feb 08, 2009
How do i adjust intonation on a peavey predator plus exp?
To adjust the intonation on a guitar you need the following. ..
a electronic tuner
and a small philip screwdriver
when you tune a string say low E you play the note open and adjust tell it's in tune
then to intonate play the low E at the 12th fret
producing a Harmonic, view the tuner it will be sharp or flat,
turn the small philip screw on the bridge adjustment
it only takes a small turn one way or the other so go slow
once the string is tuned at the harmonic note check to see if it's in tune played open, keep tuning and adjusting tell the strings are in tune open and at the 12th fret on all six strings
once intonation is set properly the guitar will sound better
really hope that helps?
Mar 15, 2015 | Peavey Music
Tip
How to string an electric guitar
I'm writing this tutorial to help new guitarists string their electric guitars.<br /><br />The first step is to purchase some strings from your nearest music store, depending on the type of music you want to play the string gage will be different. If you want to play heavier music such as metal then I suggest using a heavier gage of string. If you want to play calmer music such as indie, or maybe soft rock I suggest a lighter gage.<br /><br />Next make sure and remove <span style="font-weight: bold;">ALL</span> existing strings. The best way to take off the old strings is to simply loosen them up then cut them right in the middle with wire cutters. Then just pull the left end through the tuning knobs, and the right end through the back of the guitar (Note where the strings come out of the back).<br /><br />After you have removed all the strings its time to put on the new ones. Start with the string closest to the top of the guitar. On your string package you can reference by color which string is which. Find your string then run the sharp end through the back of the guitar in the hole relative to the string you are putting in (These holes in the back are the same holes the old strings came out of). Run the string all the way through so that it is pulled tightly into the back. Now place the sharp end of the string through its relative tuning knob at the top of the guitar. You should pull enough through so that when you pull the string up off the neck there is a gap of about one foot. Now turn the tuning knob clockwise until the string is relatively tight against the neck and it has wrapped around the knob 3-5 times. Now cut the excess string that is coming out of the tuning knob but leave about 1 inch in case you want to lower the tuning. <br /><br />Do the same thing for all your strings, then tune them with either a digital tuner or by ear if you can. You can purchase a cheap digital tuner for around $20 at your nearest music store.<br /><br />Enjoy!!
on May 16, 2011 | Yamaha Electric Guitar
Value of kimble grand serial 383273
this is a musical instrument to entertainment the people The first stringed instrument was the harp, on which the strings are plucked. The harmonic curve caused by the varied speaking lengths of strings dictated the shape of the frame of the piano and broadly follows the shape of a harp.
The monochord is simply a sound box with a single string stretched over a movable bridge to the position required, which is determined by a scale marked by "0" on the surface. The bridge is moved to each marking to give you a new note. It was plucked, and would now be referred to as a tone metre.
Mar 01, 2015 | Grand Music
Lap harp from first act booklet
All strings on First Act lap harps are electric guitar G strings with the gauge being .016. These may be found at any local music shop or music retailer. The manual can be found at this link- First Act Discovery FG500 Reference Manual Page 2
Feb 02, 2015 | Music
Broken string repair how do i put in a new string on my paraguayan harp?
First thing you do when learning how to play a instrument is how to maintain your instrument or find someone who can maintain it for you.
Jul 09, 2014 | Music
Melody Harp Tuning wrench LOST !
There's a little brochure that comes with each music pack that has an order form for extra tuning wrenches, sheet music, etc. It lists the standard tuning wrench at $0.95 and the deluxe tuning wrench at $3.95, plus $3.00 shipping and 7% sales tax if you're in Ohio. The address is
Upbeat Marketing 3800 Kelley Avenue Cleveland, OH 44114
"Allow 2-4 weeks for delivery."
Hope this helps!
Feb 08, 2010 | Trophy Music Melody Harp By
How to play minor chords on Bontempi MS40?
easy:
- the lowest key gives the chord C for C major (do majeur)
- add a key on the right (up) for exemample D or E or (it doesn't a matter) gives you the minor chord.. (here Cm = do mineur)
- add a third one ( always on the right side) gives you the 7 here C7 (do septieme)
enjoy!
what a pity we can't easily disable this auto chord function in orfer to get real notes for the left hand!!!
Jan 22, 2010 | Bontempi Toys
How to tune (what key) my daughter's new trophy music melody harp
GABCDEF#GABCDEF#G
Dec 25, 2008 | Trophy Music Melody Harp By
The melody harp my daughter received for Christmas is completely out of tune. We own a keyboard, but aren't sure just what note to tune it to. That is to say, does the c on the melody harp coincide to the...
the harp is tuned to the piano
middle c is the first key to tune then each string up or down accordingly
it is a stringed instrument just like a guitar
Jan 13, 2018 | Trophy Music Melody Harp By
Trophy Music Melody Harp By Logo
128 people viewed this question
Top Trophy Music Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Trophy Music Toy Expert? Answer questions, earn points and help others
