Question about Ovens
Looking for cooking instructions for the Jumbuck pizza gas oven model number HS-PZ001
Any cooking instructions at all
4 Suggested Answers
SOURCE: a loud buzzing when Lincoln 1456 impinger pizza gas oven fires.
this sounds like the gas solenoid valve you may need to change the coil on the solenoid valve
Posted on Aug 21, 2009
SOURCE: Lincoln Impinger pizza oven Need manuals
i need a part for a ovencan yoy help me
Posted on Sep 03, 2009
  • 523 Answers
SOURCE: Oven takes forever to preheat
check to see if both broil and bake elements/gas works
Posted on May 27, 2010
When cooking Pizza at 220c the top burns-even though the element is on the top and the pizza in the bottom third of the oven, and the base is uncooked - this also takes 30 minutes to cook?
you are using the broiler to cook it,the upper element is the broiler,the lower one is for the oven,turn on the oven so that the bottom element is on,if it doesnt work,then that is the problem
Jul 19, 2015 | Ovens
Gas Pizza Oven - Heat issues
Many of the Pizza ovens require ceramic plates that line the bottom surface of each oven. These ceramic plates absorb the heat and retain the temperature. I never used our ovens with a bare lower surface, always applied the plates for even heat and distribution.
Mar 05, 2014 | Ovens
Pizza scorching on bottom
This may sound simple but....Do you know for sure the oven temp is 550 (use a thermometer on the stone to be sure) The thermostat may be set at 550 but could be running hotter? I have had this problem in the past with ovens.
Mar 29, 2012 | Blodgett 911-DOUBLE Gas Oven
How do I start the oven? I want to cook a pizza
Open the oven and make sure it is empty nod one rack is near the middle level. Turn the knob that says OFF to BAKE. Then turn the knob with all the numbers to the temperature that Theo Sri toons on the box tell you to use. Allow the oven to heat up for 10 minutes. It may beep when it is up to temp or a red light will turn off to let you know it is ready. Put the pizza in the oven on middle rack. Take it out according to box instructions ( usually 8 to 15 minutes). That pizza out by sliding it onto a plate. Turn off the oven and eat the pizza. If it is not done completely, leave it in longer next time. Enjoy
Jul 08, 2011 | Ovens
MICROWAVE OVEN HOW TO USE POWER LEVEL AND COOKING TIME. For example a want to cook pizza what will i use?
We probably need a little more info on your particular oven before suggesting what power levels and times. Do you know the wattage of it i.e 900w?
Does it have presets on it? Your manufacturer may have put auto programs on it to reheat, cook from frozen etc.
Final hint: If you are buying things such as frozen pizza, microwave dinners, the microwave instructions are usually on the box with a recommend time for a particular wattage oven.
May 04, 2011 | Ovens
Why does food get hard after cooking or reheating in a microwave
It's basically a loss of moisture during the cooking process, to avoid this in a standard oven cook on a lower temp for longer and cover with foil....in the microwave, drop the power setting and always reheat or cook with the food cover with a microwave safe cling wrap or microwave specific cookware with lids.
Hope this helps.
Sep 08, 2010 | Whirlpool Ovens
I tried to cook a frozen pizza in my Tappan electric range last night (which required it to be preheated to 400 degrees) and it would not preheat at all, even after about a 3 hour wait. I just turned up...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153992&diagram_id=1251523#d1251523
your looking for part number 67 on that part breakdown
it is the bake element and if you inspect it im sure you will find it cooked or broken
befor you actually order the part take the unit out
unplug it
and inspect your wire connections to both sides of the element
Oct 17, 2009 | Tappan 30IN ELEC IGNa Oven
Cooking
A good pre-heated pizza stone will help cook the crust better when the pizza is placed right on the stone. As for the cheese burning, check the actual temp. of the oven with a good thermometer.
Feb 07, 2008 | Blodgett DFG-100 Gas Single Oven
Only half cooking
Theres a handy conversion table here:- http://www.hintsandthings.co.uk/kitchen/oventemp.htm Regards
Sep 26, 2007 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
