Question about Keratin Complex Health & Beauty
Iron wont heat - Keratin Complex Health & Beauty
Half my flat iron will not heat up
i'm lookin gfor a solution too; mine was fine one day, now both plates wont heat, even though it says its gotten to the temperature i set. Someone else said the heating coils might've burned out and to get a new one?
Jun 26, 2012 | Remington Pearl Ceramic Ultimate Flat Iron...
Hi i have an old weller soldering iron and it wont light up, do i have to have the 2 slide controls in a certain position
A soldering iron is composed of a heated metal tip and an insulated handle. Heating is often achieved electrically, by passing an electric current (supplied through an electrical cord or battery cables) through the resistive material of a heating element. Another heating method includes combustion of a suitable gas, which can either be delivered through a tank mounted on the iron (flameless), or through an external flame.
Mar 24, 2011 | Milwaukee Tool Weller Pyropen Jr Cordless...
Brand new iron and it wont heat up over 140 deg F.
Contact B & D and they will probably replace it - they will need the receipt.
Mar 01, 2010 | Black & Decker Classic Metal APP F63D Iron
On my iron all of the lights come, but iron wont heat up
Short answer is yes...but you would probably have issues with other appliances also if you had a power surge...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Nov 24, 2009 | Euro-Pro Shark GI490 Iron
My rowenta stopped heating , mid-shirt!!......now it seems dead and wont heat at all !.........thanks !!!
The most likely cause is a broken wire in the cord. Replacement should only be done by a qualified electrical appliance repairer. Ask for a quote as it may be cheaper to buy a new iron!
Oct 04, 2009 | Rowenta Powerglide DM273 Iron
Wont turn on
I agree.
It is probably a loose screw (if you shake the iron, you may hear it rattle).. The iron is most likely good, just needs a 5 minute repair.
If you want to do it, or find someone to do it:
1. UNPLUG the iron.
2. remove the 4 screws from the back end of the iron.
3. Open the back plastic plate.
4. There will be a wire with a loose screw; tighten it.
5. There may be a broken wire near the screw; if so, remove the eyelet that is on the screw. put the screw back on and wrap the broken wire end onto the screw and tighten.
6. Replace the back plate.
7. Plug back in and use for a few more years.
Hope this helps!
Sep 04, 2009 | Rowenta Power Duo Iron
Wont heat as much and on steam setting it leaks
make sure you dont have the steam dial on self clean if it if is iron wont act right
Aug 13, 2009 | Euro-Pro Shark GI490 Iron
MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Jul 25, 2009 | Rowenta DX6700 Iron
Sunbeam steam iron 4239 adjustable steam iron won't heat up
POSSIBLE CAUSES:
1. Blown fuse
2. Broken thermostat
3. Broken power cords
4. Broken heating elements
first of all check FUSE.
good luck...
Apr 06, 2009 | Sunbeam Irons
The black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Mar 16, 2009 | Black & Decker ICR200 Iron with Auto...
Health & Beauty Logo
Top Keratin Complex Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Keratin Complex Health and Beauty Expert? Answer questions, earn points and help others
