Question about Amana ASD 2624 Side by Side Refrigerator
Husky hus-cnsil bar fridge freezing up
Interior warm due to back wall freezing up
2 Suggested Answers
SOURCE:
sdmc73
  • 121 Answers
SOURCE: warm fridge
check the fan in the frezer and check the defrost
Posted on Nov 29, 2008
Fridge is not getting cold, fans are running and outside casing feels cold to touch but internal warm think faulty compressor how can check and how easy to chnge
If fans are running and compressor is not check to see if the unit has a starting capacitor for the compressor - check it for capacitance value and change if necessary. If still nothing, using a voltmeter check to see if current is reaching the starting windings of compressor. If nothing, then maybe the thermostat is defective. But if current appears at terminal and the start capacitor is good, then the motor has definitely gone to heaven.
if compressor is running and refrigerator is warm, either the self defrost mechanism is not working or perhaps you may be in need of refrigerant.
To change unit you need vacuum pump, solder and soldering equipment, schrader valve, refrigerant scale and refrigerant, gauges, rags, emery paper, etc.
Aug 28, 2015 | Husky HUS-CN15 Wine Chiller
Set the temperature
I can't get my temps to adjust
1 stay warm
1 stays cold
Jun 11, 2014 | Husky HUS-CN15 Wine Chiller
Very noisy fridge, back wall freezing up
Possible bad freezer fan motor. I need more information such as brand and model number
Mar 10, 2014 | Samsung RS2630WW Side by Side Refrigerator
Husky cn15 88 problem
First things first, check the power supply. If there is power at the pluf then I would look at the temperature control. Check to make sure it is closing and calling for the compressor to be coming on, that will also control the condenser fan motor. Good luck
Sep 08, 2012 | Husky HUS-CN15 Wine Chiller
I have a maytag fridge (freezer on bottom) the fridge is not very cold. freezer has started to get ice near the door opening in the last week.
if you see ice near the door the door muat not be closing all the way or the gasket could be ripped,ice will form where warm and cold air are mixing together,did you remove any of the shelves or baskets in the freezer or in the fridge?i've seen people clean out the fridge and the shelves weren't put back in correctly keeping the door open,check that or food packages that might be hitting the door,when the warm air gets in it usually freezes the air ducts,this is why the fridge is warm,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer into the fridge section and then it returns through other air ducts so if warm air is getting in it will freeze up the air ducts,you can try shutting down the machine or unplug it,remove the food from the freezer and with a hair dryer hit the back inside wall of the freezer,blow the air up into the vent holes in the back wall,if you see water dripping down through the slots you have ice up in there,keep blowing the hot air up into the holes until you don't see any more water dripping,if you can remove the ice maker and remove the back inside wall of the freezer would be better.first check the freezer back wall to see if there's any frost or like snow on it,if so you could have a defrost problem,bad jazz board,this is the computer board that's behind your digital controls in the fridge section,bad defrost thermostat or heater,also do you mean the floor of the freezer has ice on it,you could have a blocked drain in the freezer.write back with more info and let me know what you find and hopefully i can help you better.
Sep 05, 2012 | Refrigerators
The fridge back wall inside above the top 2 shelves are freezing over also the black cover on back of fridge one bit of pole going into the motor seems warm [is this normal ]
Your defrost system has failed. Defrost timer. defrost heater. Defrost thermostat. Without a model number I can not be further help.
Jun 07, 2009 | Refrigerators
Ice build up condensation will not drain down the tube to the catch pan under the refiridgerator. As much as 3 inches of ice will build up between the veg bins, causing mold builup in fridge, Model 550...
I had the same problem but fixed it recently. The problem originates with the drain trough mounted on the back interior wall of the fridge that slopes down into the middle. The drain tube is attached at this point and runs to the pan under the unit. This drain trough is screwed to the interior and sealed with silicone caulking. Over time the caulking breaks free from the interior wall of the fridge allowing the defrosted water to leak past the trough, collecting in the bottom of the compartment under the veggie drawer. It freezes there building up an ice ***** that eventuallly wraps around the drain tube. Any water that now runs into the tube freezes in place over time forming an ice plug preventing any drainage at all. Now the defrosted water begins to flood the interior of the fridge eventually leaking out which it did in our situtation.
There are two solutions. One is to take off the drain trough, clean it up and the interior wall of the fridge. Also thaw out the ice plug in the drain tube and make sure it is clean and drains freely. I used hot water and a syringe to inject it into the tube until the ice melted. Dry everything off. Reattach the drain trough using silicone caulking approved for kitchen/bath use. You may have to shut down the fridge and warm it up to meet the application temperature limit of the silicpne. The other solution is simpler. After cleaning and drying the drain trough, I applied an adhesive backed closed cell foam rubber gasket (3/16" thick automotive) to the back surface of the trough that sits against the interior wall of the fridge when in place. When screwed back in place, the gasket is compressed preventing water from leaking past. The fridge does not have to be warmed up for this fix. It has been in place for a few months now with now problems.
Feb 17, 2009 | Sub-Zero Bottom Freezer Refrigerator
Kelvinator F/Freezer not working. Not fuse
Sounds like gas is out.Probably leaking Contact the dealer where you bought it,Should still have guarantee.Jan
Feb 12, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Amana ASD 2624 Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
