Question about GE Overature Vintage GE Portable Radio P1905B AM/FM 1966
My radio has a port for an external power supply. I do not recognize the plug type and + and - are not labeled. Works great with 6 d cell batteries. Would like to be able to plug it into the wall. Thanks
  • Chris Chandler
    Chris Chandler Dec 28, 2013
    Thanks - it is helpful - not quite a solution - but that is more about my confidence - and desire not to damage the near perfect vintage device. thanks so much for the prompt reply.
  • repairyes Nov 29, 2016
    6 batteries, is 9 volts. You can use a wall wart adapter, but I'd need to see a photo of the type of plug it uses. To find out which is pos or neg, open the back and see where the wires are going that are on the plug. Usually but not always, the outer sleeve is negative. I know this is an old post, but please join our facebook page Vintage Transistor radios and I'd be happy to help.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Good luck... you will need to find an OLD repair facility or do some serious ebay searching. you can however open up the unit and see which would be positive or negative
Posted on Dec 28, 2013
    Don't need to find an 'old' facility, these items are still available. Maybe not the factory adapter, but one that supplied the voltage needed. Then need to see what kind of plug it uses. Again, probably a common item at suppliers like Mouser.
I have a 2004 freestar s with a factory am/fm radio. i installed an am/fm/cd radio. it will not recognize cd's in the player. tho original radio has only 1 plug port, the new radio has 2 ports. is the...
is it a new cd/radio ? the wiring is the same for a radio with or with out a cd player , the cd should work once the radio is connected , the other port you mention may be relevent as the original radio was a factory installed , these are usually designed to be useless to be used in other vehicles as a theft deterrent , i would remove the new radio and have a good search in the radio space as there may well be the second connector you require , be very carefull as there are many sharp edges and the apeture is not very large , the second connector , if there, will most likely be taped to another loom so as to keep it away from touching other parts so a good torch and have a search , keep me posted if you wish
Mar 11, 2015 | 2004 Ford Freestar
Can I power a small appliance with my dewalt
This is what dewalt is saying...The Dewalt 12V/20V MAX work-site charger/radio functions as an AM/FM radio and recharges your 12V/20V Dewalt batteries (batteries not included). The 3-stage charger can recharge your batteries in as little as 1 hour, and the radio can run off 12V/20V batteries for cordless operation
  • 2 AC power outlets offer more versatility for jobsite power
  • Auxillary & USB ports allows for connection to CD, MP3, portable satellite receivers, and other digital audio devices.
  • USB port allows device to be charged via USB when radio is plugged into a wall outlet
  • Class D amplifier, woofers and tweeters provide full range of high and low sound for optimum sound quality,( hope this helps)
Aug 06, 2014 | Dewalt DCR015 MP3 AUX USB 12V/20V MAX*...
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
Harley Radio aux port not working?
The problem is you have a bad aux plug for repair info you can email HRmotors@aol.com- Thanks
They usualy ware after time and start making bad connections
Jun 26, 2009 | Harley Davidson 426290 AM/FM Radio
I need to add and auxillary input to my 2003 chevrolet silverardo bose radio. how can i wire one in?
THE GM12-AUXV2 by P.I.E. will work for you.
It plugs into the factory radio changer port.
With this device installed, you will have created an auxiliary audio input to your factory radio, which will allow you to plug in any external audio source, like a portable MP3 player, satellite tuner, DVD player, or iPod, and play the audio from that external audio device directly through your factory radio. This is a direct connect device and NOT an FM Modulator. An FM modulator requires you to tune to an FM radio station in order to listen to the audio from the external audio device. While this is a direct connect interface, it is only an audio connection and does not allow you to control the external audio device that is connected to it.
Jan 19, 2009 | Car Audio & Video
Pioneer inno radio-doesn't work in car
When its in the car dock, the Inno sends an FM signal to the car radio. It does not receive a signal from the car radio. You must have the external antenna correctly installed outside the vehicle for the Inno to work. The built in antenna is disabled when the device is placed in the car dock. Make sure to test it outside, since garages or car ports will block the signal.
Dec 03, 2008 | Pioneer XM2go Inno Satellite Radio...
Delphi MyFi SA10113 XM Radio
try doing away with the external fm transmitter and use the one thats built in to the delphi you just go into settings and set it to a station that has no channels and tune it in
Jun 13, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
Help
This model doesn't charge through the USB port. It needs charging with the external power supply.
Dec 12, 2007 | Philips HDD082 MP3 Player
GE Overature Vintage GE Portable Radio P1905B AM/FM 1966 Logo
250 people viewed this question
Top GE Overature Televison & Video Experts
Are you a GE Overature Televison and Video Expert? Answer questions, earn points and help others
