Question about Jaguar 1994 XJS Convertible
I have a jaguar xjs 1994 and my engine light came on it says FF 14 when I turn it off
alicantecoli
  • 22156 Answers
SOURCE: 1994 Jaguar XJS Turns over, but won't start
fuel pump
Posted on Jan 10, 2009
SOURCE: FUEL FAIL 14 CODE 14
this is the most common error code, just means the one of the nods in fuel pump misfired, on every model other than the ones for usa market, after clearing the error code on vcm the check engine light would reset. for our cars its programmed to stay on.
also get fail 17 fuel 17 same thing
it will not effect the running of the car or its performance
may run a little rich
Posted on Jan 16, 2009
  • 61 Answers
SOURCE: fuel pump replacement instructions for 1994 xjs jaguar
Drain the tank as much as you can and put the gas into a 5 gallon bucket or a gas can, then you need to drop the gas tank down, after you do that you can take out the screws from the pump and it will out.
Posted on Mar 25, 2009
  • 5 Answers
SOURCE: Check engine light VCM code "FUEL 14"?
my manual says fuel fail 14 deals with yourr coolant temperature sensor is no in operating range
Posted on Apr 14, 2010
pctech1
  • 1940 Answers
SOURCE: where in the car do I find the radio code for a
http://www.radio-code.com/Jaguar-Pay-Page-radio-code.htm
You will need the Serial # found on top of the radio, along with your VIN #
Posted on Jul 10, 2010
Qhere do i find the coolant temp sensor an the map swnsor
Jaguar Sensor, XJ6, XJ8, XJS, XK8, S-TYPE, X-TYPE, XJ40 ...
www.jagbits.com/jaguarsensor.php
FITS: 1993-1994 6.0 XJ12 AND 1989-1993 V12 XJS FROM VIN 157118 ON, 1994-1996 6.0 V12 XJS FRONT DAMPER .... LNA1622AA - MAP SENSOR ... C42166-USED - USED SENSOR COOLANT TEMPERATURE FOR FUEL INJECTION
Sep 25, 2015 | Cars & Trucks
Where is the fuel filter location for a 1994 jaguar XJS 6,0 V12?
next to the tank at the top of the body under neath. or on the updated version engine bay follow the fuel line and it goes into a contaner with 2 pipes on it that is the filter.
Oct 16, 2013 | Jaguar XJS Cars & Trucks
How to remove a fuel line from the fuel tank on a 1994 jaguar xjs convertible
under the drivers side rear of car there are 2 quick disconnect lines you push and turn and they pop loose
Aug 06, 2013 | 1994 Jaguar XJ6
Where is the key code on a 1994 Jaguar XJS located?
use the vin number and go to a jaguar dealer it will cost you about 65.00 I had the same problem. The vin number is on your title and your registration
Jul 22, 2013 | Jaguar 1994 XJS Convertible
How to remove fuel tank on a 1994 jaguar xjs?
remove covers in boot behind seat there are mounting brackest there hopfully not rusted take off bolts remove brackets remove filler pipe but getting it out is a carry on as its a tight fit may need to remove back seat as well
Aug 17, 2012 | Cars & Trucks
1994 jaguar xjs 4.0----need to know where the vacumm line that feeds vac to cruise control eminates from--yea i know, from the engine----but where ,specifically, on the engine ?????
On my 90 and 92, I have a vacuum line from the driver side intake manifold at about inline with the # cylinder. It travels to the firewall between engine and firewall to a connection underneath the battery.That line goes through the firewall and connects to other lines roughly above your feet if you are sitting in the passenger side of the car.
Jun 10, 2010 | 1994 Jaguar XJ6
1994 Jaguar XJS CLUTCH
hi mate cet the number for gmf car spares they will help general motor factors
Jun 12, 2008 | Jaguar XJS Cars & Trucks
Jaguar 1994 XJS Convertible Logo
Top Jaguar Heating & Cooling Experts
rdjagger
 Mikey
Mikey
ray gallant
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
