Question about Ricoh Office Equipment & Supplies
Ricoh ft4615 e 11
Machine shows error E11 on display
4 Suggested Answers
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
  • 165 Answers
SOURCE: HOW WILL I SOLVE PROBLEM OF E5 ERROR MESSAGE IN
e 5** fuser related temperature over/under
e1** optics related
both need service engineer
Posted on Nov 05, 2010
  • 504 Answers
SOURCE: Ricoh ft 4022 photocopy machine displaying error code E-3.
cleaning requird clean properly with any quality cleaner then rty
Posted on May 17, 2012
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
E11 code on the dispay
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Oct 20, 2012 | Washing Machines
Display reads E11
E11 error code means that the dryer thermostat is faulty.
Apparently it overheats if you use it too much or the motor of the fan (blowing hot air in the tumble) got stuck.
Check it and keep us updated.
Apr 18, 2011 | Hoover Washing Machines
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Buttons:
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
Jan 16, 2011 | Washing Machines
Error E11 in the machine Candy Alisé GO W 264 D, could you please tell me what this error means, and how to solve it? Thank you! Manuela
Open top cover of the machine. From the back on top there are 3 screws, remove them and slide back top cover to remove it. You will see a metal part with 2 thin red wires(sensors) atached. One is probably loose and the machine shows error code e11 and will not centrifuge. Make sure it holds and try to run the machine again.
Jan 08, 2011 | Candy Washing Machines
Error code E11 on hoover washer dryer vhw854d
Nov 12, 2010 | Hoover Washing Machines
I have 3713s and has e11 error. i have already reseted but still the e11 is coming out. i need help
e 11 is the lamp error. check if the scanner lamp comes on or not when the machine is on.
Oct 23, 2010 | Ricoh FT3713 Copier
HOW WILL I SOLVE PROBLEM OF E5 ERROR MESSAGE IN RICOH 4018 AND E11 ERROR MESSAGE IN RICOH 4622 PHOTOCOPIER
e1** optics related
Oct 04, 2010 | Ricoh Office Equipment & Supplies
Ricoh copier 3813 - error e
E codes are displayed in the copy counter.To display both digits of the E code press the enter key.
E11 exposure lamp error.Possible causes exposure lamp open thermofuse open.
E12 exposure lamp error Ac drive board defective or main board defective.
Oct 26, 2009 | Ricoh Aficio 450 Copier
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
