Question about Pioneer Audio Players & Recorders
Pioneer vsx-d503s powers up but no audio output
4 Suggested Answers
SOURCE: pioneer VSX-D503S receiver-no sound coming
it might need to be rregrounded
Posted on May 27, 2008
  • 4 Answers
SOURCE: Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Posted on Aug 12, 2009
SOURCE: pioneer vsx-d814 will not power on after power surge
I pressed the front Enter and Advanced Surround for 2 seconds on my VSX-D814 and that worked. Thanks.
Posted on Feb 07, 2010
I have a pioneer vsx d503s and the standby light is on. But the receiver will not come on
I sounds like you may have a problem in either one of the Regulator circuits, or, one of the Power Amplifier outputs. If the protect circuit detects DC or Low Impedance on one or more of the speaker lines, it will not fire up the high power section of the power supply. Further troubleshooting will require some working knowledge of power amp and power supply circuits. I've got a .pdf copy of the Service Manual if that will help you.
Please let me know what your level of troubleshooting ability is, and whether the manual will help you.
-Petra
Apr 30, 2015 | Pioneer Audio Players & Recorders
What is a power module on a pioneer receiver vsx-d507s and what do they look like?
The power supply module or the power amp output stage IC PAC007A
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcRzmIk0t8CwAVNbqkM6uzwlEtAqBvsGTa-LIkk-N0ATyNkJ1bMRk2udyXI0
PS on pg 3
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-11_RRV1966.pdf
Aug 13, 2014 | Audio Players & Recorders
Pioneer av no hdmi output after power surge
internal fuse was blown check motherboard if you know how to open panel if niot take to technician
Feb 26, 2014 | Pioneer VSX-821-K - 5.1 Channel A/V Home...
Optical inputs
You have to re route the sound from the samsung to the optical output. You do this is the audio setup section of the setup menu.
Jan 23, 2014 | Pioneer VSX-D498 Receiver
My component pioneer vsx-518 has no power, what is the main reason and which item will i check?
• If you have a multimeter, check for DC outputs on the power
supply regulators, there could be some
• Or check for cold solder joints (if you can't find any)
diodes, capacitors or regulators
on the power supply.
• These could be just a power supply problem, main amp or both
Let me know if you need further assistance!
Sep 13, 2012 | Pioneer VSX-518-K Receiver
No sound from Pioneer VSX-37TX
check the caps and output transistor the power ones and resistors
May 31, 2012 | Pioneer VSX-37TX
No audio output
THE FIX - to audio problems that persist with the VSX-29TX and others using the AWX7272 DSP board is to replace the ROM on the DSP. My unit started failing on and off after 10 years of use! The intermittent DSP board is an Extremely Common and irritating Problem for this model! The replacement IC,(2) resistors + shipping and handling totaled $49.65 and my unit is finally fixed correctly! Don't believe other posts that you can get away with re-soldering; it will continue to fail again and again! Details of fix are:
Replacement for the old Pioneer ROM located at location IC 9374, should be done with the part PD6381A from Pioneer Electronics. You will also need to move (relocate) the 2 resistors (0 Ohm resistors) located at R9372 and R9371 to locations R9374 and R9373.
This component update applies to DSP boards marked as AWX7433, AWX7272.
This fix is validated (from Pioneer) on the VSX-26TX,VSX-27TX,& VSX-29TX it might also work in the VSX-908, VSX-908RDS and others as long as the same DSP board was used.
Let me caution and stress that surface mount soldering skills ARE REQUIRED to do this update! It also doesn't hurt to have excellent vision and/or an eye loop or microscope to check your work. Original ROM's were subject to timing changes internal to the part as a result of HEAT. This model does get HOT! The program was also modified as a further safeguard to re-occurrence.
Jan 30, 2010 | Pioneer VSX-29TX Receiver
I have a motorolla DSR505 sattelite receiver that I want to connect to my Pioneer VSX-1019AH-K audio/video receiver. The sattelite receiver has a DVI output jack so I have a DVI to HDMI cable to connect it...
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Sep 18, 2009 | Pioneer VSX-1019AHK A/V receiver
Sibilant output from Pioneer VSX 1018 AH-S
Suspect a DTS board capacitor failures the ESR characteristics.
To troubleshoot connected any available device to RCA stereo connections at input to multi channel in. Test input to the corresponding speaker output confirming audio quality. This circuit bi-passes the DTS function and connects to the power amplifier for the speaker.
Connect any audio amplifier from the preamp out and confirm the quality of the audio.
I suspect that the pre-amp out will contain the distortedf noise. If the distrotion appears in all the channels it is most likely the DTS.
These are repairable.
Hope this helps?
May 09, 2017 | Pioneer VSX-1015TXK Receiver
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
