Question about 2001 Audi A4 - Sedan, chassis code B5 - Anti Roll Bars
Ihave a phillips cineos pixel plus2 hd tv and idonot know what the code is that unlocks all the tv channels
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Eibach Master
  • 1,632 Answers
Admin
Posted on Dec 28, 2013
My cineos 42" TV has lostall channels; it was piuxillatring for three days and gradually the number of channels reduced until today there are none. What do I do?
you need to replace the tuner module. Is it under warranty? if not face down remove the back and tuner module is in the lower right side
Jan 11, 2015 | Televison & Video
Hi, ihave a plasma TV, sometime ago and it has only been since we moved houses, our TV goes pixelated and then we get No signal on 1-2 channels, and now we have no signal full stop, i have a booster...
You have antenna issues. Try raising the antenna some more or relocating to another spot where the signal strength is greater. Pixelation is a sign of a weak signal -
Jul 02, 2017 | LG 42PC3RA 42 in. HD-Ready Plasma TV
I have a 47 inch Philips HD TV. I switched to FioS and for some reason, some channels come in very choppy or pixelated. It is not consistent but by analog TNT is fine but my HD TNT is pixelated. But my...
Long story short, it is not your fault. Your provider will blame you, TNT, will blame your provider, and both are wrong.
The most likely cause is HD TNT is not a "real" HD channel. It is probably an SD recording TNT is upscaling from SD to HD. This can occasional create a dirty HD signal being broadcasted. Some TVs have trouble decoding this signal and end up with pixelated images because the image has been pre-stretched to fix the format.
Temporary solution would be to change the resolution of you TV for just the TNT channel. Some TV will let you select a preferred mode for a channel. If you can do this, set it to 720p instead of 1080p or try 1080i for TNT to see if this improves the image.
Also make sure that only one tuner is altering the images you are receiving if you have a FIOS box. If it is processing the image image in any way (color correct, resolution, etc.) turn those features off and let the TV do it.
Apr 27, 2011 | Televison & Video
Pixelation of TV channels via Settop box
Pixelation is caused by poor signal strength. Check the signal strength in the setup section. Unfortunately some boxes and TVs don't handle poor signal as well as others. It might be worthwhile trying a signal amplifier
Jun 12, 2010 | Televison & Video
Panasonice TV freezes and stutteers off of cable when in HD
if the picture keeps breaking up and pixelating it is normally a reception issue rather than a problem with the tv.
Nov 28, 2009 | Televison & Video
Vizio pixelation in hd nt all channels
Usually a TV that pixelates only on some channels is a problem with the signal levels coming into the TV or the cable box. If you are using a cable box then definatley the signal is the issue..
Nov 11, 2009 | Vizio VA26L 26 in. LCD HDTV
Zenith TV
automatic code search. this may take a while to do but it works. hold the directv button and tv power until the red light stays on. while its on press the channel up button (this will search for a code). release and test with the tv power button. if the tv does not turn off, press the channel up button again and test with the tv power. when the tv finally goes off, press the enter/last button (bottom right corner of the remote) to store the code
Aug 31, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Digital tv
Is this a HD channel? This is usually caused by a hiccup in the streaming of HD from the cable/sat company. How long has this been happening?
Mar 01, 2008 | Televison & Video
Pixelation on Local HD Channels Only with or without cablecard
This is caused by one thing, poor signal strength.
Mar 01, 2017 | Televison & Video
2001 Audi A4 - Sedan, chassis code B5 - Anti Roll Bars Logo
47 people viewed this question
Top Eibach Vehicle Parts & Accessories Experts
Timllfixit
 Mikey
Mikey
ray012965
Are you an Eibach Vehicle Part and Accessory Expert? Answer questions, earn points and help others
