Question about Uniden BC60XLT-1 (30 Channels) 2-Way Radio
Programming Can a Uniden Model: SMS 835TS and SMS 825Ts be used in a conventional channel instead of trunking? Thanks,Jim.
5 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: Motorola mts 2000
MTS2000 software will operate on Win98 and possibly XP, depending on the revision number you have. Yes, you can clone if the model number is the same. It will clone the entire codeplug of the radio. (Note: you will not have 2 same serial numbers. These are unique to the individual radio.)
Posted on Aug 17, 2008
BillB-SA
  • 2761 Answers
SOURCE: How do I program conventional frequencies into my
Just go to Bank C or anything after that and start entering -- one channel, one frequency. It's kind of cumbersome to do by pushing the keys, but it works. An alternative is to use the BuTel software. It will simplify programming and give you Virtual Control of the scanner through your computer.
If this helps, please give us a rating. A "very helpful" would be greatly appreciated.
Posted on Nov 22, 2009
BillB-SA
  • 2761 Answers
SOURCE: I need help programming my uniden bc278clt for
To program a known frequency into your scanner:
- Power the unit ON.
- Press MANUAL to stop scanning.
- Enter the number of the channel that you wish to program, followed by MANUAL -- OR -- press the up or down arrow key until the desired channel number appears.
- Enter the desired frequency, including the decimal point.
- Press E to enter the data into memory.
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC278CLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Posted on May 04, 2010
  • 14 Answers
SOURCE: i just have Uniden Por510XL (used) but don't know
well a GP2000 has a Frequency range of 136 - 174 MHz, 403-440 MHz or 435-480mhz
a uniden pro 510XL is a 27 mhz radio as far as i know...
Posted on Jan 04, 2011
I need a manual for a Uniden SMS 825ts
Go to this site and you should be able to download your manual for free.
Aug 21, 2014 | Uniden 815t/sms 825ts Service Manual...
Free download manual book uniden sms 825ts
http://www.fixya.com/support/p3162828-uniden_815t_sms_825ts_service_manual_ccs/tags
Jan 03, 2013 | Uniden Sps 310t/320ts Radio...
Need hep programming a new uniden bcd396xt scanner
Unfortunately, you didn't specify if you needed assistance with programming digital or conventional radio systems.. but here is the info for conventional systems. Since a conventional system is really a collection of frequencies, the first thing you need to know is the frequency for each channel you want to program.
  1. Go to the Program System menu and choose New System .
  2. The scanner will prompt you for the System Type. Select Conventional .
  3. When the scanner prompts you confirm, tap YES .
  4. The scanner creates the system with a default name. Select Edit Name if you want to change it.
  5. If you need to change any of the system properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel group Each conventional system can contain up to 20 channel groups, and all systems must contain at least 1 channel group.
  1. On the Program System menu, select the system you just created.
  2. Go to the Edit Group menu and select New Group .
  3. If you need to change any of the channel group properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel in each group Each conventional system can contain up to 1000 channels in each group, and all groups must contain at least 1 channel.
  1. On the Edit Group menu, select the channel group you just created.
  2. Go to the Edit Channel menu and select New Channel .
  3. Input the frequency for this channel in MHz.
  4. If you need to change any of the channel properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Mar 04, 2011 | Uniden BCD396T Handheld Scanner
How do you start to program a bct8 800 mz scanner
Programming conventional frequencies into the scanner's PRIVATE bank is simple, but programming trunking systems is a detailed process that will take some research and probably some practice. The best instructions for both types of programming are found in the factory operating manual that you can download and print, at no cost, here:
http://www.uniden.com/pdf/BCT8om.pdf
For a comprehensive database of active frequencies and trunking systems in your area, and a lot of other useful scanning information, visit:
Bill B.
Listening in since the 60's
Jan 11, 2011 | Uniden BCT8 Base Scanner
Trunking no longer works on my BCD996T scanner, Conventional work
Hi Mike,
Try updating the firmware and see if this solves the problem. While I understand that it "worked before", some of the programming software has been updated to work only with the newer firmware. Also, the newer versions of programming software are required when importing systems directly from radio database sites (such as radioreference.com).
If this does not work, try to enter system data by hand rather than importing. If trunking works then, it sounds like a software problem with your programming software versus the radio itself.
Hope this helps!
Feb 13, 2010 | Uniden BCD996T Base Scanner
Manual Programming of the Uniden BC95XLTB
1. The scanner automatically selects the band, you just program the frequency.
2. Your scanner does not have the traditional channel/frequency layout that you may be used to. Rather, it uses a system called DYNAMICALLY ALLOCATED CHANNEL MEMORY, which organizes frequencies into groups and systems, and enables the scanner to cover a wide variety of conventional and trunked radio systems.
The manual for the scanner goes into detail on the various systems and programming methods, and you can download/print the full manual here:
http://www.uniden.com/pdf/BC246Tom.pdf
If it seems a bit overwhelming you might want to join a scanner group on line or in your area and draw on their experiences with the 246. You can also pick up a lot of useful information on the scanner, and access a comprehensive database of active frequencies/systems in your area by joining
To simplify the programming process, you can join the Radio Referenc group and purchase programming software from BuTel (http://www.butel.nl/) Their program for the BC246T will allow you to access the RadioReference database, select what you want to monitor, and import/program the information to your scanner.
Sorry, but the days of the Bearcat III with it's manually selectable bands and 8 "rocks" are gone, and today's complex radio systems require complicated scanners to keep up with them. As more and more areas upgrade to trunking systems, machines like the 246 will become the norm.
Dec 21, 2009 | Uniden BC246T Handheld Scanner
How do you program the bc350c scanner
Conventional frequency programming is fairly simple, but programming trunk systems is more detailed and can't be adequately covered in this forum. Please follow the link below - it will allow you to download/print the manual for your 350c, and the manual will walk you through the programming steps.
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies and trunk systems in your area, visit
I hope this helps, but if you have any more questions, please contact us again.
Dec 09, 2009 | Uniden BC350C Base Scanner
How do I program conventional frequencies into my Uniden BC898T? I have Motorola TypeII Digital Tunking frequencies programed into Bank A and EDAC Digital Trunking frequencies programed into Bank B
Nov 22, 2009 | Uniden BC898T Base Scanner
What Type Of Scanner Do I Need?
Well, the above answer is somewhat correct, but could use a little clarification.
A radio that transmits in a P25 format is digital. Digital transmissions can be trunked, but don't have to be (as is the case here). In the case of scanners, every major brand scanner out there that works on digital transmissions will decode trunked of conventional digital and analog transmissions.
The current digital models run anywhere from $399 to $599. Radio Shack has 2 newer models out that will do digital...the PRO-106 (handheld) and the PRO-197 (base/mobile). These have been on sale recently for $399. Uniden also makes digital trunking scanners..the latest models being the 396 (portable) and the 996 (base/mobile). While the 996 has the capability to be used with a GPS in a mobile setting, this feature isn't really worth the added cost, especially when compared to the feature rich PRO-197.
There are older model digital scanners, such as the Radio Shack PRO-96, PRO-2096 and the Uniden 250D and 796D. While these receive digital transmissions, the newer scanners have upgraded digital decoding algorithms that provide better audio quality and intelligibility. Also, the older scanners may not be able to decode the 700 MHz public safety band, which is becoming increasingly more popular since the 800 MHz band is quickly filling up.
One word of caution...be sure that the agency you are trying to monitor is not using encrypted transmissions. If you don't know...look up the system on radioreference.com. Channels that are encrypted usually have an "E" designation under the "mode" column. These transmissions CANNOT be decoded by any of the scanners currently on the market, even if you do have the encryption key.
I hope this helps you with your buying choices. Good luck!
Sep 11, 2008 | Uniden BC72XLT Handheld Scanner
Uniden BC60XLT-1 (30 Channels) 2-Way Radio Logo
174 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
