Question about Toshiba SD-P1200 Portable DVD Player
Repair of my dvd player
The lens of my dvd player is defective needs to be replaced. a technician who checked my dvd player told me that the lens needs replacement. where can i bring my unit for repair here in the philippines. I am residing in guimba, nueva ecija. Thanks
  • 4,889 Answers
Screen says it is loading the dvd, but then wont play. Eventually says cannot play dics. Tried several discs.
good day sir
that is a common problem of all DVD...there's a D.I.Y. for that,, try to clean the lens by using cotton buds and remember don't any chemical compound just cotton buds only
or you can use a CD cleaner to clean the lens,,
and the last is when cleaning is not effective it means the DVD lens is defective need to replace a new one if you will
or give to the expert technician because replacing the lens is very difficult because it have a proper alignment...thank you and good luck
Apr 04, 2011 | Sony DVP-FX750 Portable DVD Player
My kid broke the blue optical lens in Sony DVP-FX930 Portable DVD Player. Can i replace the optical lens part from any other dvd drives or is it unique to sony. Please advice.
Portable DVD players are made up of the dvd mechnism, control motherboard and LCD panel. You can buy a defective Sony unit on ebay for parts and replace the dvd mechanism assembly.
Most defective portable dvd players are defective on the control motherboard, just read the defects disclosed on ebay items to decide which one to buy to fix yours.
Oct 19, 2010 | Sony DVP-FX930 Portable DVD Player
Incert dvd read out sats NO
Hello
This usually happens when the DVD or laser lens pick-up has become dirty.All you need to do is
1. Check the disk for scratches.
2. Make sure the disk you are using fit the correct format specified by your DVD player.
3. Clean the laser lens with a DVD laser cleaning disk.
4. Insert a correctly formatted undamaged disk into your player,listen to see if it begins to read the disk,if it continues to make no sound.
5. Open the DVD player carefully and clean the lens with isopropyl alcohol and cotton swab.
6. If none of these solutions works out then a professional repair technician will be able to tell you if fixing your DVD player is worth the money.
BEST OF LUCK
Jul 13, 2010 | Toshiba SD-K760 DVD Player
I get a no disc error and so far blowing air in it has not helped
It sounds optical laser lens is dirty and need cleaning.
Put lens cleaning disc in player and press play, disc will spin and might clean lens to solve the issue.
If that does not fix the problem, unplug player from wall socket, take off top cover and clean lens with good quality cotton bud gently and then check does it play disc. If problem still exist then optical lens got defective and need to be replaced. Local tv repair shop will replace it but replacement would cost you much.
Hope these info will help you.
Thanks.
Jun 09, 2010 | Philips DVP642 DVD Player
I have a Zenith DVP615 Portable DVD Player when i put a disk in it says check disk but will not play, the disks are fine but no play.
Hello
In this case maybe you have defective Ribbon wire or defective Lens,.
ok Please clean the lens with 100% cotton first, if not reading after you clean the lens, kindly replace the ribbon wire, then test run, if not reading again replace the lens you have defective lens..
Thanks
Angel...
Sep 19, 2009 | Zenith DVP615 Portable DVD Player
Rca portable dvd player model drc6318e doesnt not load dvd. says no disc. how do i fix that?
first you must check if your portable loads cd or mp3. If it loads cd or mp3 the defect is lens and this should be replace by an expert. If both cd,mp3 and dvd didn't load you check first the ribbon wire for signs of disconnection and foldings and then replace it. If still your portable didn't work the most probable defect is MPEG board.To distinguish if MPEG or lens defect in lens shows malfunction such as not reading dvd but reading mp3 or cd, unwanted stop of play even with a good dvd.
Jul 11, 2009 | RCA DRC6318E Player
My daughters GoVideo DVD player always says CHECK DISC!
If no disk is detected it means that the lens are dirty or defective.
If the lens cleaner disk, or using Qtips and alcohol did not work, then the lens pickup or the disk drive must be replaced. this involves precision soldering and must be done by a technician. Regards.
Jul 04, 2009 | GoVideo Televison & Video
Just bought a Audiosonic KM2201DVD 22" LCD TV WITH DVD PLAYER. The DVD Player comes up with BAD DISC error no matter what DVD i place in it. Is there a factory reset on this device or a reagon...
Is there no factory setting on that unit sir,in that case the bad dics error is need to repair or fix some a technician.there are 3 different type or deffective parts to replace it.first type the MODULE of the dvd player ,is need to re-heat the parts of the module by using a hot-air or soldering iron,second loose connector or cable between the module and lens, and third look the lens if lights up while loading the dics which means the lens is good,if theres no lights up or lazer,the lens are deffective.
kira_ryuk99@yahoo.com
Technician
Jun 29, 2008 | Televison & Video
Toshiba SD-P1200 Portable DVD Player Logo
138 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
