Question about Garden
I need to replace the bolt/rod holding the sprocket onto the clutch assembly on my Poulan chainsaw
I have a Poulan Pro PP4218AVX, and I watched one of my employees take it apart to clean it, and the rod/bolt that holds the sprocket piece onto the rest of the clutch just sheared off. It looks like the end of the rod just broke off clean, and it was not my employee who did anything with any force to cause this. It just basically fell off. I have another Poulan Pro for parts, but I can't figure out how to remove that rod and install it on the other saw. I figured out everything there is to know about removing the clutch and replacing it, but the rest of the clutch here is fine, and there is very little information about whether or not you can replace that rod/bolt.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Sorry but from what I am seeing and reading, the clutch screws onto the crankshaft then the clutch drum slides onto the crankshaft and an E clip holds it in place... if that rod is broken this means your crankshaft is broken meaning throw it away
Posted on Dec 28, 2013
dennisgladx
  • 52 Answers
SOURCE: Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Posted on Nov 08, 2008
SOURCE: Poulan Pro Clutch Removal
Yes there is a special tool to engage on the clutch. You can get it from the Poulan web site - I think it is part number 31112 - cost about $5. Maybe you can get by without it, by using a screwdriver and hammer, but the tool was easy and risk free. You also have to stop the piston, as the previous poster said. I Googled how to do this, and the consensus seemed to be that it's easiest to stick rope down inside the cylinder, avoiding pusing it through the exhaust port. That worked like a charm. I used a hammer to hit a wrench on the clutch tool to break it loose.
Many thanks to the original answerer for getting me on the track to solving this.
Posted on Dec 17, 2008
dontbother10
  • 2220 Answers
SOURCE: Chainsaw pull cord wont tension up
Its almost certainly made by Poulan.
This may help you find an IPL at Sears, they are available:
http://www.searspartsdirect.com/partsdirect/modelHelp.pd?modelNumberId=29
This lists all Poulans. It will be difficult to find your saw but it is here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
It sounds as though the starter spring is broken.
This thread explains how to reinstall the spring.
http://www.fixya.com/support/t1839024-broken_recoil_spring
The IPL for your saw shows all the parts and provides an idea of how they fit together. GL
Lou
Posted on Sep 08, 2009
dontbother10
  • 2220 Answers
SOURCE: installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Posted on Sep 14, 2009
rwvanlue
  • 486 Answers
SOURCE: Need to replace drive sprocket on Poulan 2150
Outboard drums (drums on the outside of the clutch) are held on by a nut or e-clip.
Inboard drums are held on by the clutch which is threaded onto the crankshaft. And there is the challange.
***NOTE all chain saw clutches have LEFT hand threads, so, rightey loosey, lefty tightey. (just backwards from everything else)
*** NOTE #2: DO NOT USE AN IMPACT GUN
this will most certainly shear the flywheel key or damage the flywheel !!!!! (after 35 years, you can ask me how I know that, LOL)
1) Use a piston stop to hold piston from moving: THIS IS A MUST !!!
Ok, so you do not have one, let's make one.
a) remove the spark plug
b) insert a piece of recoil rope into the cylinder hole, leaving a tail to remove it by. (rope, large shoe string, anything that is soft, that is aprox 1/4 to 5/16 in diameter to place into the spark plug hole to help the piston to stop it's travel by filling up the empty space. Just make sure you can remove it later)
c) secure the saw (extra set of hands may be needed) and with a suitable wrench on the clutch center, rotate the clutch to the right until piston comes to a stop. With a hammer, tap the wrench to aid in rotation. This can be very difficult, and may take several taps.
d) after removed, inspect and grease the drum bearing before re-assemlby.
e) upon re-assembly of clutch, tighten by hand only, NO hammer required. The force of the chain will tighten the clutch.
f) remove the rope, and re-install the spark plug.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 19, 2009
Can I get a replacement clutch cover for Poulan Pro model PP4218AVX
Yes, Just use the one from the PP4218AV PN 545012003. I just can not tell if the adjuster assembly comes with the cover or is need to ordered separately.
Jan 24, 2015 | Poulan Pro Pp4218av 18" Gas Chain Saw...
How to install clutch on poulan pro 42 cc
Remove the clutch hub and sprocket, then using a Poulan clutch tool, unscrew the clutch assembly and replace.
Jul 25, 2014 | Poulan Garden
Broken crankshaft on Poulan PP4218AVX Chainsaw
YES IF SAME MODEL AND SIZE, MAY BE IT WORKING PULL OUT THE DEFECTIVE ONCE AND REPLACE OR SWAPPING BY THE OTHERS SAME IN SIZE AND MODEL. I THINK ITS GUARANNTY WORKING..
Dec 28, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Model # pp4218avx chainsaw ;The safety back bar will not move. I replaced the plastic cover and braking device ( part # s 30071893 )with new one and it will not move back either.
It is important to engage the hand guard into the brake mechanism before tightening the screws, if the brake is aready on prior to fitting you will need to remove the sprocket and possibly the clutch to get the brake onto the machine, as the band will be smaller than the drum, once on and engaged into the mechanism the hand guard will pull back to the top handle and load the brake, you can then refit clutch and sprocket.
Jul 01, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i replace the drive mechanism for a poulan pro model pp4218avx
Ok, start by removing the side cover, there will be a large plastic nut with a flip up lever, undo the nut anti clockwise, now remove the guide bar and chain which are now free, there will be a c clip and washer holding the clutch drum on, remove the clip witha suitable screw driver, remove the large washer, the clutch drum will now just pull off, there is now a small washer to remove, you will now see the clutch, there is a special tool required to remove the clutch, it fits into the two half circle cut a ways in the clutch centre, the clutch is threaded onto the crank with a left hand thread, once the tool is fitted you put a 19mm spanner on the tool and jar it off against compression. The special tool is part no. 530031112.
Feb 19, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Is there a replacement clutch cover for the Poulan PP4218AVX?
Hello Dave;
If a Poulan PP4218 your answer follows; if not post back with the correct model number and we can replace that too.
Poulan “PP4218AVX” IPL (exploded parts list)
We are going to replace this page 1; item 47
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2010/NIUS2010_545103408.pdf
Poulan “PP4218AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4218AVHD-Gas-Saw-Type-2/75.PP4218AVHD-Gas-Saw-Type-2.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 44; Clutch Cover Assembly; $9.50.
You also need;
• Item 43; Bar Mounting Nut; $0.56 each (need 2) and
• “Engine Assembly” print; Item 44; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
You will need retain the original model number IPL, there may be internal differences.
Down loadable PP218AVHD IPL
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2006/NIUS2006_545014325.pdf
Poulan “PP4218AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047503.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
May 16, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Yes i cracked the oil housing for my poulan pp4218avx 42cc chain saw and I was wondering if they sale a replacement housing to repair the saw.
A Poulan PP4218AVX Gas Saw link follows:
http://www.ordertree.com/modelinfo/PWE/PP4218AVX-Gas-Saw/75.PP4218AVX-Gas-Saw.1.59.1.html
See the "Handle, Chassis and Bar Assembly" print, item 38. Is this what is broken? If yes it is possible to replace it, it is not terribly expensive, it is a great deal of precision work. I hope you already removed the clutch (left handed thread). I would probably keep this for parts and purchase a PP4218AVHD Gas Saw Type 2 as a replacement. HTH
Lou
Feb 23, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The back post that holds the bar has come loose and turns
Provided your saw is a PP4218AVX, tThe bar studs are item 41 on the "Handle, Chassis & Bar Assembly" here:
If not an AVX the correct IPL can be found here:
Poulan.com
The dash number of your serial number is the type.
The tank is usually split to install a new bolt. Please read some of the repairs here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Sealing the new bolt to the fuel tank is the hard part.
Good Luck
Lou
Jan 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poland wildthing chainsaw
Take the screws out of the cover to the recoil. After removing the bar and chain, take a racthet with the correct size socket which should be a half inch; put ratchet in tightening position. Attach a pair of vise grips to the inner piece of the clutch just outside of the threads that screw onto the engine shaft. You may need to grab the grab the vise grips with a crescent wrench as close to the clutch as possible. Grab the crescent wrench and the ratchet firmly and turn, that baby should come right off. I just took my clutch and sprocket off of a poulan model 2055 a week ago and I am getting a new assembly tomorrow from poulan.It's not really hard to do, you can do it. Hope I was helpful!
Apr 26, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
