Question about Intel DH55HC Motherboard
Display issues the computer isn't sending info to the monitor
    Problem Solver:
  • 5 Answers
Do you have graphics card? installed does the motherboard has integrated graphics?
Posted on Dec 28, 2013
My Dell s5000 stoped sending signal to monitor tested vga and monitor both are good. could this be a driver issue? if i cant see a monitor to re-install drivers what can i do?
i had a similar issue and found that the displays were fine it was just the size of the display via the graphics control card that needed changed after an update, if you need any further help or instructions just give me a hauler
Jan 07, 2017 | Dell Computers & Internet
Led will not show.comes on for a second then blank
James, sounds like a power supply issue.links below to shed some light on your issue.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
How to Fix LCD Monitor Power Problem
MOST COMMON REPAIR FOR LCD NO POWER
Fix Malfunctioning LCD Power Supply
How To Test Computer Monitor That Won Display Or Is Not Working
Feb 15, 2016 | Computers & Internet
Dell monitor blue light on no display
Hook it up to a different computer or laptop. If it still has issues then change out the cable. Add more info: has it ever worked? When was the last time it worked.
Apr 14, 2014 | Dell 22" SP2208WFP Widescreen Flat Panel...
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
I have a Dell 2007WFPb 20
If your LCD monitor displays your desktop fine as it boots up and then goes blank after a few seconds, but you can still faintly see your desktop then this may seem like a brightness issue but it's not. The picture displays very faintly, this is because the LCD backlighting isn't working properly. Which in turn is either because (most likely in cases like this) the inverter circuit has failed or the cold cathode tube has blown. If you're new to the electronics business and are not sure how to solder and connect circuits then this is the job for a qualified repair technician. So i suggest you head on down to your local PC store and have a technician take a look.
If you want to try it youself go here to order some spares.
If the monitor switches off and you can't see your desktop faintly then this may just be a power saving issue. Yo fix this check out my other tip here.
If your monitor is less than a year old then I suggest you take it back to where you bought it and have them send it in for repairs or swop it out with a new one. LCD monitors usually have at least a 1 year warranty sometimes it can even be up to 3 years if you register yours when you purchase it or if it's a really expensive screen.
If the monitor is a good 4-5 years old then it may not be worth fixing or may be too expensive. I suggest you invest in a newer widescreen option. LCD monitors have drastically come down in price over the years and you can easily get a wopping 23" for as little as $180.
Dec 14, 2011 | Dell 2007WFPB LCD Monitor
My moniter comes on then goes straight into power save
It probably isn't gettting a signal from the computer, if you have one try another monitor with the computer if the other monitor does the same thing then its the computers issue, if its the computer's issue you probably need a new video card.
May 12, 2011 | Computers & Internet
My monitor is very blue suddenly. Is this the monitor issue and how do I fix it.
That could be the monitor or the video card, or even the cable connecting them.
If the RED signal dies, you are left with green and blue - so everything goes green/blue.
Check the connections at the video card and at the monitor.
Either try another monitor on your computer, or try your monitor on another computer to determine which is at fault if the cable isn't the issue.
Apr 26, 2011 | Xerox XR619DW Monitor
Turns on fan runs but no info to the monitor doesnt seem to boot
If the Monitor is displaying no infomation at all, your display signal from the PC to the monitor has failed.
1: Check the cable between the monitor and PC
2: If you are using onboard graphics then that display port is faulty.
3: If you are using a graphics card then remove it and try the onboard graphics.
4: Your monitor maybe faulty aswell so test it on another computer to be safe.
Its more likely to be option 2
Jan 15, 2010 | Gateway GT5220 PC Desktop
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Jul 12, 2008 | NEC MultiSync 1525X 15" LCD Monitor
Intel DH55HC Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
