Question about GE JASRM24912 Remote Control
Noremotemoddxt9950 digital stream technology inc. mod#dxt9950cat#15-150 also need manual
I have a Sanyo HDTV I got on CL, It came with a Direct TV remote that will power up and off the TV and the volume works too. However I cannot get this remote to do anything more. I've tried the codes but nothing happens. Any thoughts?
Posted on Jan 27, 2014
I need code for digital stream box for a trinatron tv
Faq - digital stream technology, Inc. ( digital stream ...
www.dsconverter.com/index.php?p=5
Can I use my Universal Remote Control to operate the converter box? ... Do I need a special antenna to receive digital or high-definition TV? .... Note: If you want to reset the remote back to the beginning of the TV code list, clear the memory by ...
Installation - digital stream technology, Inc. ( digital stream ...
dsconverter.com/index.php?p=3
Connecting the DTV Converter Box to your Analog TV Set with RF cable · - Connecting the DTV Converter Box to your Analog TV Set with Audio/Video cable
Digital Stream Analog Pass-through DTV Converter Box
www.amazon.com/Digital-Stream.../B001TO3L8Y
Amazon.com, Inc.
Rating: 3.4 - ‎131 reviews
Digital Stream Converter Box Remote DTX9950 ... RCA DTA-800B1 Digital To Analog Pass-through TV Converter Box ... I think the bad capacitor is something like a 16 Volt capacitor, and you have to replace it with a ... remote(I was able to find the code for my old JC Penny TV), a seperate button for channel signal strength, ...
Amazon.com: Customer Reviews: Digital Stream Analog ...
Amazon.com, Inc.Digital Stream Analog Pass-through DTV Converter Box ... the code for my old JC Penny TV), a seperate button for channel signal strength, ... My brother somehow found out that there have been many of these Digital Stream boxes that were .... button that you can program into your tv (mine is a 1990's 11" Sony Trinitron).
Jan 14, 2016 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I need a manual for Diamond Audio's D971 component speakers, I need the thiele small parameters of these speakers
General •Speaker type car speaker Manufacturer Diamond Audio Technology Inc. Features •Amplification type passive •Driver configuration 2-way •Woofer size (inches) 7" m, 30mm m •Nominal (RMS) output power 200 Watt •Max (RMS) output power 400 Watt •Response bandwidth 35 - 30000 Hz •Input impedance 4 Ohm •Sensitivity 92 dB •Connectivity wired Compatibility ' Accessories •Included accessories mounting hardware Cutout & Mounting Dimensions •Diameter 6.3 in •Depth 2.7 in General •Manufacturer Diamond Audio Technology Inc. Thiss should help you out.
Jan 05, 2015 | Diamond Audio Car Audio & Video
Need codes for converter box,:model name dtx9950
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Codes to check are: 009.003.006.019,072,087
Apr 13, 2013 | Televison & Video
My wifi will not use my wifi router after upgrading ubuntu to ver 11.10 it worked before and i can use different wifi routers lspci 00:00.0 Host bridge: ATI Technologies Inc RS690 Host Bridge 00:01.0 PCI...
first make sure your wireless adapter is not disabled you can check it by running rfkill list in terminal if it is type sudo rfkill unblock wifi [second you can try activating and deactivating by typing sudo ifdown wlan0 and sudo ifup wlan0 me personly have kept to 10.10 the 11.04 seem to have a few glitches you can also check for additional drivers
Nov 27, 2011 | Canonical Ltd. Ubuntu
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
Need owners manual for dxg didg. camera mod- 506v
http://www.dxgusa.com/CustomerService/Manuals/DXG506V.pdf
Dec 31, 2010 | DXG Technology DXG-506V Digital Camera
Drove a few minutes, parked the next day it would not move, charged batteries, still nothing it is giving code 8
According to the owner's manual, you have a motor problem. To further diagnose and verify the problem you would need a digital voltmeter to check the motor. An experienced technician can do the necessary checks and order/replace the motor if necessary.
8 Flashes
• Indicates a motor voltage problem.
• Your scooter will not operate until the problem is corrected.
Remedy: Contact your authorized Golden Technologies, Inc. dealer.
Hope this helps.
Dec 22, 2010 | Golden Technologies Companion II Travel...
Who makes the apex television?
search webside : www.apexdigitalinc.com About Apex Digital Inc. Headquartered in Walnut, CA, Apex Digital Inc., is one of the country?s leading providers and marketers of consumer electronics of High Definition LCD and Plasma Televisions, Home Entertainment Media Devices, Solar Powered Lights and Digital Set Top Boxes. Apex Digital is recognized as one of the fastest growing companies in consumer electronics history. Founded in 1997, privately held Apex Digital?s products are carried in hundreds of retail outlets nationwide. From the beginning, Apex Digital has embraced a total value philosophy, in which lower product costs do not compromise quality or superior customer relations. The company not only responds rapidly to customer needs, but it carefully listens to consumers to better anticipate their future requirements. Growth is driven not only by demand, but also by the introduction of new technologies setting in motion a new revolution in digital information. Apex Digital is moving ahead and further securing its already well-established leadership role in consumer technology. Look for 2009 to be a record year for Apex Digital, with the introduction of expanded product categories in digital media, high definition blu-ray DVD players, accessories, antennas designed with Smart technology and more. Stay tuned! Key executives: David Ji, Chief Executive Officer / Chairman Alice Hsu, Chief Operating Officer M. Jeannie Vogler, Senior VP of Global Sales & Marketing Mailing Address Apex Digital Inc. 301 Brea Canyon Rd. Walnut, California 91789 Customer Service Email: customerservice@apexdigitalinc.com OFFLINE OPTIONS Customer Service / Technical Support 866-4APEXGO (866-427-3946) Toll-Free 909-230-4829 Fax 24 Hours a day Accessory Store Orders 866-930-1236 24 Hours a day
Oct 29, 2009 | Apex Digital AT2702 27" TV
GE JASRM24912 Remote Control Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
