Question about Philips HTS3450 System
Philips HTS3090 IWhen I nsert movie DVD and after loading disc appears, it shows "wrong region" and will not play disc...How to correct this problem to play these dics?
1.power on dvd
2.press setup
3.press play
4.press 15902379390
5.press play
Posted on Nov 19, 2007
SOURCE:
Protable phillips pet824 DVD player will play cd but not dvd's
follow this steps, and fix it. Merry Christmas.
However you must sure if you device can play any CD/DVD.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Dec 17, 2013 | Philips Televison & Video
Wrong region DVD player won't play a disc
Can,t be done with the one you have,
Nov 10, 2012 | Philips Televison & Video
DVD movies form Amazon show in India ''wrong region''.
try to unlock your dvd player to play all free region. what you need is the code to unlock and a remote control to enter the into menu/programming mode. please specify model # of your dvd player when you look for the unlock key.
Apr 03, 2009 | Philips Televison & Video
DVD Player D1816 shows Wrong Regional Disc message
Many DVD players are preset to one region and if you use a DVD destined for any other region, the player will refuse to play. Some players have the option to change this to universal mode. Check your player's manual if yours has this facility.
Yes. You can play VCD movies and and Audio CDs on most players.
Mar 18, 2009 | GPX D1816 DVD Player
WRONG REGION on the screen
Have you checked the region in your Disc Properties? Go into Disk Management, find your dvd and right click on it. Go into the properties and you will see a heading for Regions. In there it explains a bit about regions, which should be at 2. If it is not, then change it to 2. Let me know if this doesn't help.
Feb 02, 2009 | Philips Phillips 16X External DVD 2XRW...
Philips DCP750/37 shows "wrong region"
Australian players are designed only to play Region 4 discs. United States discs are Region 1. It is illegal to change the Region code on a DVD player, so I can't tell you how to do it (ironically, it is the most frequently asked question about dvd players on Fixya.com - global world), but there are videos on YouTube that will show you how to do it - I would just enter "philips region code dvd" as your seacrh term. You won't find that exact model, but one of the codes in the video should work. Note that you will only be able to change the region code three times on a Philips - after that you will be locked out. So change it to Region 1 once, and never change it again.
-Tha Mp3 Doctor
Dec 29, 2008 | Philips PET710 Portable DVD Player
WRONG Region error . Philips DVD65K
Each DVD player is designed only to read discs froma certian region of the globe, and they are labelled 1 through 6 (or ALL). Australian players are designed only to play Region 4 discs. United States discs are Region 1. It is illegal to change the Region code on a DVD player, so I can't tell you how to do it (ironically, it is the most frequently asked question about dvd players on Fixya.com - global world), but there are videos on YouTube that will show you how to do it - I would just enter "philips region code dvd" as your seacrh term. You won't find that exact model, but one of the codes in the video should work. Note that you will only be able to change the region code three times on a Philips - after that you will be locked out. So change it to Region 1 once, and never change it again.
-Tha Mp3 Doctor
Dec 21, 2008 | Philips PET710 Portable DVD Player
DVDR520H 1/ Trying to play DVD shows unlocked lock symbol - what does this mean ? 2/ Unit not accepting blank discs for use in recording from HDD or external source
are you referring to the symbol on the led screen? this is vital..and there will be more information so please hold your rating until we have more information
Oct 23, 2008 | Televison & Video
Philips 7" DVD portable player
The PET702 will be a region 5 machine, whereas the UK DVDs are region 2.
DVD players from a particular region are designed to play only DVDs from the same region, due to copyright and distribution rights in each country or region.
However the PET702 can have the region protection removed by making it multi-region:
Switch on the PET702 and Open the tray.
Press SETUP button on the remote control, which will bring up the menu.
Highlight "PREFERENCES" and press OK.
Press [2], [5], [2], [3], [1], [5], [LEFT], [DOWN]
The screen will show: "Region Code: 2"
Press [1-6] to manually set the region OR [0] for multi-region.
You will now be able to play DVDs from anywhere in the world.
This is particularly useful, because region 1 DVDs from the US often come out when the movies are still in the cinemas over here. Region 1 DVDs can be bought perfectly legally by mail order or from the internet.
May 07, 2008 | Televison & Video
Incorrect region code
This is how to make Philips DVD 622 region free so that it can play VCDs from all regions.
*Open CD tray by holding down "stop" button on the remote.
*Enter 2812
*Hold down "OK" button on the remote till 9 appears in the TV screen
*Turn off power of your DVD player
*Turn your DVD player on and it is region free now
Apr 27, 2007 | Philips DVD 622 DVD Player
Philips HTS3450 System Logo
185 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
