Question about Dual XDVDN9131 Navigation system with DVD player,LCD monitor
Panel won't close - Dual XDVDN9131 Navigation system with DVD player,LCD monitor
Dishwasher won't start
The technicians data sheet is attached to the bottom of the machine behind the kick panel.
May 21, 2013 | Dishwashers
I have a 2006 vw passat my sunroof won't close all
pull down the panel that is directly in front of the sun roof and manually close it.
May 10, 2013 | Cars & Trucks
Left rear window won't close
see the diagram and troublershooting and fix it. God bless you
Mar 30, 2013 | 2000 Hyundai Accent
Windows won't close completely
Have to remove the inner door panel, to see the problem
Nov 20, 2012 | 2000 Mercedes-Benz CLK
I start the dishwasher and it does nothing and lights do not turn on either
When your dishwasher won't start, it could be a problem with your electrical panel or the door might not be closing properly.
Check your household electrical panel for a tripped breaker or blown fuse. Also check to make sure the door latches closed properly.
For additional troubleshooting steps you can take and things you can do, read Dishwasher won't start for more suggestions. I hope this helps!
Aug 02, 2012 | Kenmore Dishwashers
Trunk won't close in 1999 cl500
ck latch may be jammed if ok ck striker latch is in lid striker is in rear panel .
Aug 01, 2012 | Cars & Trucks
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front load dryer will not turn on. the light is on inside the dryer, but the panel won't light up
Sounds like the door is not closing completely. Check the connectors that tell the unit the door is closed.
May 27, 2011 | Dryers
Driver's door won't open inside or out. Power locks work but inside and outside handles dont release latch. Can I get door panel off in the closed position, otherwise any way to open door
Hey, You need to remove the panel otherwise u can't reattach the metal sticks that move the locks, but i think it's hard to remove it in a closed posision when u don't brake it
May 16, 2011 | Saturn Vue Cars & Trucks
Dual XDVDN9131 Navigation system with DVD player,LCD monitor Logo
15 people viewed this question
Top Dual Televison & Video Experts
Jonathon summesfield
Are you a Dual Televison and Video Expert? Answer questions, earn points and help others
