Need parental lock password for nintaus n 9800
Forgot password to leappad ultra tablet unable to access parent user account
Forgot Parent Lock code on LeapPad Published 07/10/2013 01:47 PM ' Updated 06/15/2015 04:11 PM
I forgot my Parent Lock code, how can I access parent settings on the LeapPad3, LeapPad Ultra, or LeapPad Platinum?If you forgot the four digit parent lock code you set up for the LeapPad3, LeapPad Ultra or LeapPad Platinum, you may retrieve the code with these steps:
1. Using a computer or other device connected to the internet, go to www.leapfrog.com
2. Click "Log In/Register" (or "My Account" if already signed in) on the top right of the page.
3. Sign in with the email address used to set up the LeapPad.
4. You'll land on the "My Account" page.
5. Click "Account Information". Directly beneath the orange "Edit" button you will see the Parent Lock code information for any LeapPad3 or LeapPad Ultra set up using this account.
Answers others found helpful
Apr 19, 2014 | LeapFrog LeapPad Ultra Learning Tablet -...
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
I need the code for rca xl100
Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you forget your password, press the following buttons on the remote,
one by one: MUTE, DISPLAY, CLEAR, and RESET (you must be in the
password entry screen). Parental controls will then unlock and you can
re-enter a password via Lock Parental Controls.
If you need the manual please let me know.
Feb 06, 2011 | Televison & Video
I need to cde to unlock my playstation 2 t watch r rated movies.
To reset the parental lock password or disable the parental lock, follow these easy steps
Step 1
Turn on your PS2 and choose the menu screen where you would normally enter the password. Instead of entering a password, go to the DVD setup menu. Go to "custom setup" and choose "parental controls".
Step 2
When you are asked for the code or password, press the select button on your controller and enter the number "7444". Now set the parental lock to "off".
Step 3
Press "reset" on the front of the game console to save your settings. When the system reboots, you should be able to view your previously censored games or DVDs. You will also have the opportunity to choose your own password, allowing you to turn the parental lock on and off, either manually or automatically by game or movie ratings.
Jul 11, 2010 | Sony PlayStation 2 Slimline Console
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Parental Control Lock password Spectra KT2313
default passwords are often 1234 or all zeros that would be a good starting point
Sep 08, 2017 | Spectra KT2313 Combo
Mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
How do you reset forgotten parental control password?
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
Nov 29, 2007 | JVC AV-36260 TV
Lost parental password
GET TO YOUR SON THE PASSWORD HE ENTER AND WHEN ENTER IN THE PARENTAL AREA SET IT OFF.
Jun 07, 2007 | RCA F27664 27" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
