Question about GE JVM1190SS Microwave Oven
Washing machine always spinning when plugged, stops when unplugged.
There are no error codes, all it shows are hyphens. Pressing the buttons has no effect, including the On/Off. It doesn't spin if the door was already open. I have tried looking for a PCB replacement but it's discontinued and out of stock everywhere so repair is my only option. Can it be a stuck power relay?
  • Carlos
    Carlos Dec 28, 2013
    I don't understand why this was posted under microwave question, I clearly stated it was a washing machine related question.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Yes it actually can but the scary part is it being dicontinued... this means you'll have to fix it yourself... do an internet search by your model number and see what shows up
Posted on Dec 28, 2013
BIKER T
  • 909 Answers
SOURCE: self start when door closes
if electronic control, one of two things come to mind. 1)your toutch pad is defective.replace it. 2)you electronic board has a leaky component.not very likly though. believe it or not, ive seen it start before by itself then i noticed a large quantity of bugs inside the glass which i realised triggered the microwave 0ff.
Posted on Jul 23, 2007
SOURCE: DEMO MODE
Had the same problem- we unplugged it and plugged it back in. All is well!
Posted on Jun 02, 2008
kel1guy2002
  • 3740 Answers
SOURCE: my GE microwave started running by it's self. It
It sounds as if you key pad is sticking. PF means that there is an input power problem but could be caused by the sticking keypad.. As far as the unit starting bu itself, the only thing that can cause that is the keypad.. Try running your fingers flat across the panel several times both vertically and horizontally and see if the pad malfunction clears. It will probably repeat in the future but you could get lucky and have a one time instance. The keypad itself is just a bit over $75.00 if it has failed. Good luck.
Posted on Jan 12, 2010
  • 1416 Answers
SOURCE: Team, I have a GE JVM1630 BK01 Microwave Oven,
hello,
There is no reset button for this type of problem to be properly solve.
this type of problem can be view from two angle here below
1) From the wall power supply connection
2) from the oven wires connection to the panel or unit control
What this could indicate from your explanation is that there has been a bring of wire from the power control connected to the element (heater), what you are to do to solve this problem carefully, is to carefully unscrew the oven then trace the wire from the main power supply down to the control switch (panel or unit) after you most have unplug it from power supply to see if there is any of meant wires around if you are un able to trace any loose/bad wire then couple it back to it position and trace the problem to the main power supply from the wall mean that a partial contact from the wall unscrew it with a screw driver (technician tools )fix it up and then couple it back with this the problem of continuous will be solve.
thank you and thanks for using fixya.
Posted on Sep 11, 2010
  • 8909 Answers
SOURCE: Door is stuck and will not open. Tea was heated
Door catches.
One of the latches may have broken off or got stuck and is not lifting the dother latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Posted on Dec 30, 2010
How can i reset
Have you tried unplugging the microwave, waiting for 10 seconds and then plugging back in and pressing the start button rapidly followed by the stop/open door button?
Mar 02, 2016 | Sharp Microwave Ovens
I have have a 10 year old Kenmore Hood/Microwave combo built by Whirpool. I'm getting an F6 error code. What is the error code trying to tell me?
F6 —Microwave Relay Failure: Check the microwave relay.
The F6 error code which is flashing on your microwave refers to a faulty relay. However, I would suggest that you first try to run a diagnostic (which you may not be able to, but it is beneficial if it works). Here is how:
The microwave oven may be provided with a self diagnostic routine that can be operated through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door.
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed.
If you want to try to fix it your self, Always remember Electricity is dangerous and should be treated with respect.
Microwaves are very dangerous, they can still shock you even unplugged!!
Use a metal ( not the shiny chrome type ) screw driver with a insulated handle to short across ( touch both at the same time ) the terminals of the high voltage capacitor to discharge it. With the microwave unplugged.
Hope that helps.........
Jul 10, 2008 | Whirlpool Microwave Ovens
GE microwave with error code of PF and won't heat anything up
The "PF" on any appliance indicates a power failure. So if you lost power in a recent storm, this would cause your problem. Pressing the cancel button should clear up your problem, and put you back in business. If not, unplug the unit, plug it back in and try the cancel button again. If trouble persists, your board is probably at fault.
Jul 20, 2014 | GE Microwave Ovens
Magic chef mco160s microwave control panel not working
That would be a defective membrane keypad.
If it's still available, and you or someone you know might want to replace it, here's a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag in or on the microwave here.
Jan 08, 2013 | Microwave Ovens
Microwave does not work at all. Shows "PF" in display.
"PF" on the display is an indication that your oven experienced a power interruption. Normally, the error code can be cleared by pressing the CLEAR/OFF button. You may have to reset the time. This is accomplished by pressing the CLOCK button, entering the time on the keypad, then pressing CLOCK again. If this does not clear your problem, please let me know. I hope this helps you.
Jul 26, 2011 | Hotpoint RVM1435 Microwave Oven
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
Wash cycle wont finish start button does an 8 flash cycle
Hi, these machines get corrosion in the door safety switch. I would start there.
A little cleaning of the contacts might get that machine going. How about a repair manual?
I have a few:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZmJjMzhhMmYtNTI1Zi00MDExLThiNTMtYmE0NzQ3OTdmNGFi&hl=en
Take care
Apr 11, 2010 | Microwave Ovens
Galanz (french for ''****'') microwave is sporadically beeping
maybe, just maybe, there is an error code showing....and, most microwaves beep when a button is pushed too...LIVE WITH IT!
Jul 06, 2009 | Microwave Ovens
I have SE code on Samsung SMH7177STE Microwave any advise how I can fix that ?? thank you
The -SE-error is a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jan 23, 2008 | Samsung MW1080STA Microwave Oven
Error code of F-3.
F3H —Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
If my attachment made it, it shows a common way to do this....
Good Luck!
Microwaves are very dangerous, they can still shock you even unplugged!! These pages are to help give you indications of what might be wrong and some safe "how to check" or repair help.
Oct 29, 2007 | Kenmore 62702 Microwave Oven
GE JVM1190SS Microwave Oven Logo
18 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
