Question about Kitchen Ranges
Kenmore electric range 7909083461 not reaching temp
Free standing electric range not reaching temp as indicated on dial. Sears Service tech states the problem is due to improper supply voltage of 208. Tech says needs to be 240. The rating plate where I found the model number states that the appliance operates at either 120/240 or 120/208. Electrician states the problem is with the appliance not the voltage as the building ( multi-story condos 300+ units all wired the same with same voltage) is wired correctly per the Electrical engineers specs and was approved by the local utility. Electrician states 208 is a common voltage in multi-story residencial/commercial buildings and is not the problem as the appliance itself lists 120/208 as an acceptable input voltage.
So who is correct, I'm leaning towards the electrician myself
  • 473 Answers
The technician is right.  The electrician should know that amperage X voltage = wattage.  So if you lower the voltage then you lower the wattage.  The element is like a light bulb, the higher the wattage the brighter or hotter it will be.  208 volts is at the minimum so the element won't be as hot as it should be.  208 volts is just enough to make it work.  Would appreciate a solved rating for expert advice.
Posted on Oct 17, 2007
  • indian01 Jan 16, 2011
    So, how do you supply the proper voltage?
    What are the steps needed and at which device/panel?
Kenmore Convection free standing range F2 code oven not working
Actuall because Sears/Kenmore has so many manufacturers we really need you model number to translate your F2 code to the manufacturer. However.... most F2 Codes are pretty common and all point to a bad temp sensor. Most temp sensors read 1,000 to 1,100 Ohms at 70 Deg F if they are functioning. See this link and note the very bottom sensor by GE will read differently.
You also did not mention if this was a gas or electric range. If you need more assistance, please provide a model; number and I will help you.
Oct 01, 2010 | Whirlpool WFW8300SW
Kenmore electric free standing range--door is sprung. How to fix.
Usually the door is ok it is generally the hinges. So order both left and right u will need a model number and here is a good parts number 1-877-262-1479 they are fairly simple to install look it up on and us can see a picture and get a good idea how they are installed
May 31, 2009 | Kenmore 99123 Electric Kitchen Range
Kenmore oven error code f10
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
May 27, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Electric Oven will not turn off
It's the EOC. However, I replaced my EOC on my Kenmore electric range and it still does not work. I had a Sears tech come out and check the stove. The temp probe was fine and he told me it was the EOC. After I told him it was already replaced, he said, "there's nothing more to do." I'm currently looking for a new stove.
Sorry, but try to replace your EOC and check the temp probe for resistance.
Apr 05, 2009 | Kenmore 96112 / 96114 / 96119 Electric...
Electric furnace runs but won't shut off on heat setting
I would insist that Sears either have a Senior tech come out and fix it or return it to the state it was prior to them touching. Then call some one else. Have them involve the Goodman rep in your area.
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Oven won't reach proper temperature and hold
If the element glows its ok , if you have replaced the sensor with a new one it can only be the control board. in some cases you can adjust the temp. through the control , it should list directions to do so in the manual. Good luck
Dec 30, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Decible level for a Kenmore model 16625691 ultra dishwasher
Nov 12, 2008 | Hobart AM14-253 Free-standing Dishwasher
Kitchen Ranges Logo
296 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
