Question about Breville Coffee Makers & Espresso Machines
Water poured accidentally into grinder. coffee maker is not working error code 001
Water was poured into the grinder bin by mistake. Cleaned and dried. It makes brewing noise and stop after a while with 001 display. We cannot do nay setting all the panel lights are on but not working properly. How Can we fix this?
SOURCE: Coffee grinder
Mine had a piece of the top/bean lid broken off and lodged in the groove preventing the lid from going down far enough to release the safety switch which is on the right (as you look at the front) in the bottom of the groove. Note that there is another safety switch in the body of the grinder above where the ground coffee comes out that must be working as well.
MLK
Posted on May 21, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Posted on Jan 07, 2009
Noggin
  • 944 Answers
SOURCE: cuisinart grind and brew coffee maker
here is the link to the manual; http://www.cuisinart.com/share/man/34_man.pdf ask again if you still haven't figured it out :)
Posted on Mar 15, 2007
SOURCE: E2 error code
In reading the manual for this coffee pot, it needs to have the descaling procedure run. The manual lists running a mixture of 6 cups water and 6 cups vinegar in a normal brew cycle...twice to clean hard water deposits from the machine. It says to make sure to remove the filter basket. Once the procedure is complete, unplug the unit and replug in to remove the E2 code.
Posted on Sep 01, 2008
skrbin
  • 121 Answers
SOURCE: Sunbeam 10 cup coffee maker starts and stops brewing spuradically
check water heater
Posted on Feb 16, 2009
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
My gaggia platinum is showing an out of service error code [1] and i don't know what to do. Called the service centre all i get is "leave a message".
On my machine remove water tank, remove crip / coffee bin, remove mach and wash. Tip machine on its side (turned off) using a small screw driver go around the coffee grinder and clear it completly, you will need a touch. Re assemble. First run with no beans and wait for the fill bean message, fill with beans off you go. Its only happend twice both with cheap beans
Nov 11, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
Our bean grinder has stopped grinding. It spins but the beans do not grind. The machine works fine on the ground coffee option.
Did you put water in the grinder by mistake? If the grinder is wet it won't grind anymore,have to cleaned the blades physically .
OR are you using the beans from the fridge? It's a NO NO.
Jul 30, 2010 | Saeco Magic De Luxe 30092 Espresso Machine
Poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Poured water into the bean hopper by accident
I wouldn't recommend it. Grinder needs to be opened up from the top where the ceramic blades are and that section needs to be cleaned out. The coffee in there will compact and mold quickly. Just unscrew the top screw by the hopper. There should be a rubber circular housing you can remove. From there set the grinder setting to the coarses setting (all the way to the right, and not 1.) Look at the blades and there should be markings in red and blue, align the red with red or blue with blue until the top blade easily detaches. Clean inside the that area and **** out all the coffee. Replace top blade, set red to blue so it locks the blade in place, replace arm and hopper.
Feb 21, 2009 | Saeco Vienna SuperAutomatica Coffee...
Water accidently poured into coffee dispenser
If the machine is still working, then you are fine. If you can hear the grinder spin, but nothing is happening, then the water caked-up the grinder. It needs to be taken apart and cleaned. It is best to have this cleaning done by a professional. See the authorized service provider list and bring it in for service.
Jan 27, 2009 | Gaggia Syncrony Compact Coffee...
My cuisinart coffee maker just recently started not using all the water I've poured into the reserve. Up 'til today it was leaving the last two cups in the reserve, but today, out of the six cups I poured...
This is a real problem with these coffee makers, and there's not much that can be done. However, there is a work around: before brewing, just hit the button to brew 1-4 cups. It'll still brew a whole pot, it'll use all the water, the coffee will taste no different, and you can still program it however you'd like. Cheers!
Sep 21, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Coffee Makers & Espresso Machines Logo
1,069 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
