Question about Arrow T50P ARROW STAPLE GUN
The staple gun is not shooting the loaded staples
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
smartr10U
  • 1305 Answers
SOURCE: How to load Arrow T25 Staple Gun
at the back end of the handle, there is a retainer spring loaded clip. Push it in, then push it downward toward the base of the stapler, the clip should then release the spring, pull the rod with the spring completely out, slide a row of staple in where the rod came out, ONLY ONE ROW, then insert the rod with the spring back in and push it firmly in, and lift it upward to engage the lock. and fire away... Hope this gets your working
Posted on Jun 08, 2009
  • 384 Answers
SOURCE: How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Posted on Jul 07, 2009
  • 2527 Answers
SOURCE: arrow staple gun will not shoot it seems it is
You likely have i staple jamed in it see if you can get something that fits into the end where the staples come out and pull the bent staples out this is common even on bigger models
Posted on Nov 23, 2010
SOURCE: how to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Posted on Jan 07, 2011
My gun will not shoot staples
The most common cause of the gun not firing is loading it with the wrong staples. Look at the packaging for the staples and see if it lists the gun. Staples are NOT universal and are make for specific staple guns.
It "sounds like" it is jammed. You may have to pull out the staple with needle nosed pliers. e`1
How to Load Staple Gun
How to Troubleshoot Staple Gun Hunker
Oct 04, 2017 | Staples Tools & Hardware - Others
Electric tacker shoots, staples do not eject
jl open up the slide ,there is a spring end that pushes the staples into the head ,that sticks in the rail a small screwdriver will release it,it will get stuck again but now you know the prob.
Jan 07, 2013 | Duo Fast Duofast Carpet Pro Electric...
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Directions for Arrow JT-21 staple gun
The jt 21 is that little red one, I have one in my shooting box, only takes the jt staples, and operates just like any staple gun. Feed it from the back.
Feb 20, 2010 | Hand Tools
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Won't shoot staples. Proper loading instructions please.
Make sure the staples you are using are compatable with your gun they should be type 53 or JT21 staples and they are not longer tham the gun is capable of taking I think the maximum capacity for this gun is 5/16 or 8mm.
Turn the gun upside down and pull back the carriage, the staples are laid in the empty chamber in the gun itself not on the carriage points facing in the direction they fire ie points facing you .
Push back the carriage this should slide over the strip of staples until the carriage clicks shut.
You should now be ready to fire, try and keep pressure down on the gun as the recoil can make the gun bounce and you will leave the staples proud.
Hope this helps.
Sep 02, 2009 | Omega Easyshot Staple Gun & Desktop...
Has staples loaded but does not shoot staple. I pulled out the follower and cannot tell if there is a jam, but looking at the "output" of the stapler seems to have a staple...
I think you just answered your own question. I have had one single staple stuck at the "output" where the staple shoot out and it drove me insane for a few until I slowed my roll, took a deep breath and said, I have got to be smarter than a piece of metal here, and took a calm slow looksy. Sure enough, it was one loan staple causing a backup of the rest. I have also had issues with overloading staples which eventually makes the spring pushup rod become less forceful as it pushes the staples up for firing. Not an issue until you get towards the last dozen staples or so, which can also lead to the last staple not quite getting that millimeter push ahead, to shoot out correctly. These staple guns are like babies. Have to treat them nice and pamper them and heaven forbid you ever drop that stapler cause if dropped more than likely it will never quite be the same again. Telecom Tech 16 years.
Jun 17, 2009 | Arrow T25 Staple Gun
(DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
Jun 06, 2009 | Staples Tools & Hardware - Others
LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Nov 08, 2008 | Powerfast Stanley TR110 Light-Duty Staple...
Got it loaded now it won't shoot
I have a similar staple gun and I figured out I was loading it wrong. If you are loading it where the spring is, like I did, it won't work. there should be another area close to that spring opening that you put the new staples in.
Oct 02, 2008 | Black & Decker 5700 Powershot Forward...
Arrow T50P ARROW STAPLE GUN Logo
82 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
