Question about Kenwood DNX-6190HD Car DVD GPS Navigation and Bluetooth
Remove bluetooth paired devices?
I can't remove a paired device from the list. There are 5 from previous owner. Remove option grayed out. I tried resetting and doesn't help.
    New Friend:
On the paired device list screen, just wait it out for about 10 minutes or so and the list of devices will eventually become enabled (device names will turn from being greyed out to white). You can then select a device and then hit the remove button. After that, as you go back to the main Bluetooth setup screen, you may notice that the register new device button is stilled greyed out. Just wait a little bit and that should become enabled too. Good luck. I found all this out by accident as I was troubleshooting the same problem on my unit.
Posted on Feb 17, 2014
Blue tooth speaker wont turn back on.
Unable to connect to a device?
Before attempting any of the following steps, make sure that you are running the latest software version on your SoundLink Wireless Mobile speaker. Click here to visit the software update center and update your speaker. If you are still having difficulty connecting to a device after updating the software, continue to the troubleshooting steps.
Unable to connect with a previously paired device?
Please try the following to resolve this issue:
Perform a product resetTo perform a SoundLink speaker reset, following these steps:
  1. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly
  2. Press Power to turn the SoundLink speaker back on
Clear the pairing list on both the SoundLink Wireless Mobile speaker and the source
  1. On the SoundLink speaker, press and hold the Bluetooth button for approximately 10 seconds until you hear a tone. The SoundLink speaker clears all Bluetooth devices from its memory and becomes discoverable
  2. Clear the list on your Bluetooth device. For more information, please refer to the manufacturer of the device
  3. Perform a product reset. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly. Press Power to turn the SoundLink speaker back on
  4. Try pairing the device again by following these steps:
    1. With the Bluetooth device and the SoundLink speaker both turned on, press and hold the Bluetooth button on the speaker for three seconds to make the speaker discoverable. The Bluetooth indicator will slowly fade on and off approximately once every second to show the speaker is in discoverable mode
    2. Set your Bluetooth device to "Discoverable." This will allow your device to discover the SoundLink speaker
    3. On your device, locate the Bluetooth device list. Select "Bose SoundLink" from the list
    4. If your device asks for a passkey, enter digits 0000 and press OK. Some devices also ask you to accept the connection. Your Bluetooth device indicates when pairing is complete. The SoundLink speaker indicates pairing is complete when the Bluetooth indicator stops fading on and off and remains on
Be sure the SoundLink speaker is within 30 feet of the Bluetooth deviceThe system is designed to operate at a range of 30 feet. However, performance can be diminished by obstacles such as walls or metal, and may also be affected by other Bluetooth devices. Try moving the SoundLink speaker closer to the Bluetooth device.
Be sure the source's Bluetooth function is OnMany Bluetooth enabled devices have an option where the Bluetooth feature can be turned On or Off. This option may be set to Off to save the battery life of the device. Be sure this option is set to On. If the Bose product is paired to the Bluetooth enabled device, it should automatically reconnect when its Bluetooth function is turned on. If the Bose product doesn't automatically reconnect, manually select the Bose product within the Bluetooth list on the device.
Manually connect the SoundLink speaker in the device listSome devices will pair to a device but not automatically connect. Go to the pairing list of the device and check if this is the case. If it is, try connecting to the SoundLink speaker.
Oct 20, 2013 | Just Wireless Bluetooth Headset Wireless...
I have my bluetooth on and have tried to receive files via bluetooth from other phones and from pc and i can pair with other device but not receive files.It says paired but not connected.Is there something...
Sometimes this happens because either you or the other person changes the pairing keys or remove your mobile from his paired list.
It can be solved by unpairing and then pairing again wwith the other device.
Go to settings in your wildfire, Wireless and network, bluetooth. Long press on the device name and select unpair. Also remove your wildfire from the other device's paired list. Then scan for bluetooth devices and pair again. This should solve this problem.
Also, when some device sends you a file via Bluetooth, there is a notification asking permission to receive file. Make sure you click on it and select accept.
May 31, 2011 | HTC Wildfire Cell Phone
Paired backberry 8520 with parrot ck3100 but contacts will not syn with parrot. tried to transfer contacts to parrot but message just says refer to handsfree maunal .have looked into this with no luck...
Hello chicks,
Pairing both devices from the Parrot Product:
Select Setting / Advanced Settings / Pair with phone / Other phones
* From the phone:
* Select MENU / OPTIONS / BLUTOOTH / ADD DEVICE / SEARCH
* The phone will search for available devices
* Select the Parrot Product name from the list, and enter the PIN code '1234'
* The phone will pair with the Parrot Product and auto connect
Sending contacts via Bluetooth For all contacts sending
* From the phone:
* Select MENU / MANAGE CONNECTIONS / BLUETOOTH OPTIONS
* Select the Parrot Product from the list of paired devices and go to OPTIONS / TRANSFER CONTACTS
May 07, 2011 | RIM BlackBerry Curve 8520 Smartphone
I can not pair my phillipson bluetooth #BCK08A to my blackberry curve. How do u pair them together?
Make sure you are in "pairing mode" by holding down the Multi Function Button (MFB) until the red and blue flashing alternately. When the device is off, holding down the MFB for about 5 secs will turn the device on; however, don't release the button and continue to hold until red and blue flashes. Then, you are in pairing mode.
May 06, 2011 | Philips Cell Phones
I dont have the code to my bh-602
According to the manual it is 0000
I added an excerpt of the manual here :
Pair the headset
1. Ensure that your mobile device is switched on.
2. To pair the headset if it has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light flashes blue quickly.
To pair the headset if it has been previously paired with another device, ensure that the headset is switched off, and press and hold the power key until the indicator light starts to flash blue quickly.
3. Activate the Bluetooth feature on the mobile device, and set it to search for Bluetooth devices. See the user guide of your device for instructions.
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your device. In some mobile devices, you may need to make the connection separately after pairing. See the user guide of your device for details. You only need to pair the headset with your device once. If pairing is successful, the headset appears in the menu of the mobile device where you can view the currently paired Bluetooth devices.
Mar 21, 2011 | Nokia bluetooth headset bh-602
I am using samsung s3653 corby mobile. how can i delete paired bluetooth devices. please help me
Try this:
    1. Click Bluetooth.
    2. Click Devices.
    3. Select the device you want to delete from the Bluetooth Devices listing.
    4. Click the Delete Pairing button.
    5. Click Delete or "Disconnect and Delete".
If this helps, please rate. Thank you
Jan 20, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
I have a new phone I am trying to pair & have lost the instructions. Have tried 0000 & 1234
I assume you are talking about paring your bluetooth head set with your phone. It would help if you list the make and model for both of your phone and bluetooth device.
But in general, you put your phone in discovery mode to search for new devices, then you can power up your bluetooth device in pairing mode, usually by holding the power button for a long time while powering on the device util it starts flashing. After a few seconds, both devices should find each other. The phone should prompt you if you want to pair with the device found.
Sep 17, 2009 | Cell Phones
Blackberry won't pair with sony bluetooth
Can you try these steps even if you have already failed - so it is clear exactly where your problem lies and how your blackberry is behaving.
Turn on your Sony device and activate the bluetooth feature, set it to pair or search for a device (if this is a headset, it will search automatically, once it is turned on)
On your Blackberry choose the bluetooth option and enable
At your next prompt, when asked ensure your bluetooth device is in pair mode - Say Yes
It will go through a searching for devices screen
Here you will find a list of bluetooth devices in your range that can be paired - (these devices should include your sony)
If at this point you get a message stating no new devices found - Say Ok
Do you see a list of previously paired devices which includes your Sony?!
Let me know how you get on with the above, and what if any error message you receive.
May 15, 2009 | AT&T Blackberry Curve 8300 Smartphone
Kenwood DNX-6190HD Car DVD GPS Navigation and Bluetooth Logo
431 people viewed this question
Top Kenwood GPS Experts
Michael Galve
Michael Galve
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
