Question about Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum
Performance indicator light
Whe I tun the vacuum on the performance indicator light goes on and will not suction?
Check to make sure the bag isn't being sucked into the air filter. open the access door where the bag is and you'll see the air filter at the bottom. to check, leave the door open while you would see the performance indicator light on, and then pull up the bag. this is one of many solutions i'm sure to the performance indicator problem.
Posted on Nov 29, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
You have a clog somewhere. check hose,wands. also check you have a new bag and clean filter.
Posted on Feb 05, 2008
No suction and performance indicator light is on
You probably dnot have a proper seal. When you change the bag make sure you close the vauum body tight. Any leaking of air will cause the vac. to lose suction. Vacuum simply means no air. Turn the machine on then listen or try to feel if there is any air escaping. Hope this helps, Chris
Feb 07, 2011 | Kenmore Vacuums
My Kenmore bagless intelliclean vacuum is making a loud noise mainly when it is vacuuming on the highest setting (when the light is red). We have taken it apart and cannot find a clog. It has also lost...
This might help, it was posted on a previous problem but is the same issue you are having it seems: "Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk."
Dec 27, 2010 | Kenmore Progressive Bagless Upright with...
I have unscrewed all the screws and can't get bottom off.
Mar 10, 2010 | Kenmore Progressive Bagless Upright with...
The performance indicator light will not go out. I have cleaned the bag, filter and hose. there does not seem to be enough suction.
you are clogged somewhere ...
no suction?
performance indicator says no suction?
find and remove the clog.
id be looking in the hose about 4 inches from where the dirt enters the brush but dont limit your looking. The entire system should be checked for a clog. Remove it and you willbe back in business.
I have 'trash picked' more than 100 vacuums this summer, off the curb. 90 were clogged. I cleaned then and turned them into $.
Oct 13, 2009 | Vacuums
No suction....performance light stays on...filters replaced
Probably a clog..
Get hose off and straighten it out and look inside.. If not - check both ends where hose connects in the units..
Hope this helps !!
Jul 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Loud noise from Kenmore Progressive Bagless Inteli-Clean
Jul 04, 2009 | Kenmore Progressive Bagless Upright with...
Lack of suction
I use a broom handle..works very well
Nov 26, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
The dial regulating suction does not seam to work the vacuum works constantly on the full power and the light indicating overheating stays on.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This would depend on the brand and model number you have – without knowing the model or brand of vacuum you have it would be hard to give an accurate answer – the over heating light could indicate some type of clog or blockage and may have nothing to do with the dial to regulate the suction – that merely is a height adjustment …. As this does happen to most vacuums that the overheating light comes on – if there is no problem have it looked at from your local vacuum dealer or repair shop would be the best advice that I could give you.
Apr 15, 2008 | Vacuums
Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum Logo
1,558 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
