Question about Canon LBP 800 Laser Printer
Canon lbp 3150 printer service Error Code: E100 0000 solutations
SOURCE: service error in canon pixma ip 1200??
there this orange light blinking and says it full
Posted on Oct 07, 2008
SOURCE: regarding service error 5100 in canon ip1880 printer
1. Try to reset the ink counter by iptool software (sometimes it help)
2. Unplug the usb cable and then turn off and on your printer for a few times.
service error 5100 seems like indicating of mecanism exhausted or out of buffer ram in the printer. You should reduce the amount of pages to print at one time.
Good luck.
Posted on Feb 09, 2009
komguy
  • 2306 Answers
SOURCE: service error 5100
5100 means the carriage is not moving properly, or there is grease or ink on the encoder strip The encoder strip is the clear strip with black lines behind the carriage that runs all the way across the printer. You can clean the strip with a Q-tip just damp with water.
Posted on Jul 28, 2009
SOURCE: service error canon LBP 1210 Laser
You must restart your printer. then problem solve
Posted on Oct 25, 2010
mariolands
  • 2296 Answers
SOURCE: how to reset canon pixma
The waste ink absorber is full and is triggering error 5B00. To reset the error you need to replace the ink absorber. You may find a cheaper ink absorber kit on Ebay or Amazon.
Posted on Feb 03, 2011
Cannon printer error 100000
Error code E#100, ERR 100 or E100-0000 is a laser scanner unit error.
Solution 1:
  • Turn off the printer, wait 10 minutes, and then turn it on again.
Solution 2:
  • Flip open the top of the printer.
  • Look for a small shutter that holds the laser: carefully force this open with your hands and force the laser out into the center of the tracking cradle.
  • After you move the laser, unplug the printer for a few minutes.
  • Plug the printer back in.
Solution 3:
  • If the same error occurs, it's necessary to contact a service representative.
Fix your printer
Oct 22, 2014 | Canon LASER SHOT LBP-2900 Printer
Canon lbp 1210
It means your printer needs a service due to ink leakage or some kind of internal damage.
Contact Cannon support to get the printer serviced.
Sep 04, 2014 | Canon LASER SHOT LBP-1210
Error code e000 0000
If Error code is E000 then may be major cause:
+ The thermistor has an open circuit or short curcuit
+ The heater has an open circut. The thermal fuse has blown
+ The power supply PCB has a fault
+ The engine controller PCB has a fault
To Fix Error code E000 of Canon LassetJet LBP-3300 printer, you can try the following:
+ Check connector of the fixing film unit
+ Replace the fixing film unit
+ Replace the power supply PCB
+ Replace the engine controller PCB
This is not a job for a novice. Get a service technician to service the unit.
Apr 23, 2014 | Canon LBP3300
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Solution 1:
Solution 2:
Solution 3:
+1-855-517-2433(Toll Free)
Nov 25, 2013 | Canon LASER SHOT LBP-2900 Printer
Fixing unit error
"Solution 1:
Solution 2:
Solution 3:
+1-855-517-2433(Toll Free)"
  • [img src="http://i.fixya.net/fixya20/uploads/Avatars/15X15/avatar13.jpg" alt="Mark Pelkey" width="15" height="15">Mark Pelkey
  • Go to solution
Nov 12, 2013 | Canon LASER SHOT LBP-2900 Printer
There's an error 5100 appear on my printer canon mp770. I need some help,please.
Problem You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution Try the following:
If this doesn't work then the printer may need repair.
Canon Printer Error 5100
Oct 19, 2012 | Canon LASER SHOT LBP-2900 Printer
I have a printer Canon LASER SHOT LBP 1210 but i can't set up page size Legal thats mean 8.5"x 14.00". Would u pls give me solution how can I get print in the legal size print.
I am Canon LBP 1210 User. canon LBP 1210 laserjet printer not supporting legal size printing. When I give a legal size page printing, there is no response from the printer.Please give a solution.
Aug 22, 2010 | Canon LASER SHOT LBP-3000 Printer
How do I fix this?
please have the check on fuser for damage. Could be a thermistor, thermo switch, or faulty heaters. To clear error, service morefunction/clear/error/ok/ exit service mode and cycle power.
fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
Fuser error codes cannot be reset by power cycling the machine eventhough that is what the display tells you to do. In order to reset thefuser error code you must enter the service mode & reset the code.To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneousley)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
Afterclearing error stay at the machine to see if it comes to ready. Thefuser assy can reach 139 degrees C.(Water boils @ 100C) The error canonly be cleared through the service mode because a technician shouldinspect the fuser to verify there is nothing faulty that could possiblystart a fire. If you enter the service mode & clear the error,power cycle the machine & during warm up the machine throws a codeagain- turn it off, unplug it & call a tech for fuser repair.
Good Luck!!
Aug 10, 2008 | Canon LASER SHOT LBP-5200 Printer
Canon LBP 800 Laser Printer Logo
94 people viewed this question
old marine
old marine
