Question about Hamilton Beach Coffee Makers & Espresso Machines
Locking cap Replace part
How do i get fuel cap off ford explorer
First of All ,What kind of Gas cap is it?, is it a locking Cap? or factory Screw on? If locking cap then You Need the Key. if Factory cap Just Push Firmly and turn Counter Clock wise, some times the Gear mesh wears out on older caps from frequent use so You have to Push in a little Firmer than Usual when turning
Jan 08, 2014 | 2003 Ford Explorer
Removing tank filler cap
buy the bulldog door lock kit. this kit has all items to unlock automotive doors of all types. the kits also come with a key for locking gas caps. it works on all types of locking gas caps, even the locking gas cap on a motorcycle tank. i have used this key on honda, yamaha, kawasaki, and suzuki.
Jul 28, 2012 | kawasaki Ninja Zx7r Zx9r '94 To '04
I changed my gas cap yesturday and my engine light went on today. would that have anything to do with it?
Hello: Yes if it is not designed for your truck it will cause the engine light to come. (the evap system) If you put a locking gas cap on that could be the problem. If you want a locking gas cap you will have to get a GM on
Aug 28, 2011 | 2007 Chevrolet Equinox LS New Cars
1997 expedition someone stole my gas cap the other day and i was woundering if i can just use anyone from any car to replace it?
  • I don't recommend using a gas cap not intended for your vehicle. If the cap does not seal right you can throw a check engine light and have some driving issues.
  • In a pinch many gas caps will work but an OEM spec manufactured one is $10 average.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 15, 2011 | 1997 Ford Expedition
I have a sign says "check fuel cap " what is that mean ,should i take to the dealer
remove fuel cap and reinstall it, tighten for 3 clicks your PCM recognized a small leak in your fuel system usually caused by a loose fuel cap. If the problem persists replace the fuel cap
Jan 01, 2011 | Honda Odyssey Cars & Trucks
I need a locking fuel cap for my 2000 xj8?
The door to access the fuel filler compartment locks as part of the central locking system. If it is working properly, the fuel door is locked whenever the car doors are locked. However, if it doesn't lock when you lock the car, and you don't want to repair the central locking system (or part thereof), you will have to buy an aftermarket locking gas cap, since Jaguar doesn't offer one. You can find aftermarket gas caps at many online stores and catalog stores such as J.C. Whitney. Good luck.
Feb 17, 2010 | 1998 Jaguar XJ8L
Check light engine comes on ,just sometimes
Replace the gas cap with stant locking gas cap. The locking gas cap provides security and quality.
Aug 04, 2009 | 2001 Isuzu Rodeo
Yamaha V-Star 1100 Gas Cap is Stuck
shoot wd40 into locking mech and press down hard on cap while turning key.....Tim
Jun 01, 2009 | 2003 Yamaha V Star 1100 Classic
Check fuel cap is on,i have an aftermarket locking gas cap
The stock cap was designed to complete a circuit to put out the light when it was properly in place. The replacement cap apparently is built without the needed configuration to satisfy the system.
May 07, 2009 | 2004 Ford F150
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
jason
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
