Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi 43uwx10b My blue, green, and red colors are all out of wack. Can I replace the two stk 392-110 convergence things by my self and where are they.
    Genius:
  • 1,694 Answers
1)Replacement requires skilled soldering technique.
2)The IC's are on the largest heatsink on the chassis.
   Chassis will need to come out==skill and/or experience needed.
3) Possible bad fuse device in power supply,check any/all.
4) Re-check alignment.
PS.Name brand IC's last longer than generics.
Posted on Oct 18, 2007
Hitachi 53udx10b screen is dark, very blue and red. there is a red wave across the top of the screen. there is a blue "ghosting" of any text on screen.
The tv have a problems known as a convergence picture problems,it is dead.Tv set have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead to causes all these problems.Now the tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set convergence pictures promblems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Hitachi 43UWX10B 43" Rear Projection...
My hitachi model 43uwx10b has magic focas problem's red,green,blue and yellow are moon shaped across the screen
The two STK CONVERGENCE CHIPS AND ANY BAD RESISTORS AROUND THEM WOULD HAVE TO BE REPLACED.
Typical cost for all the parts on EBAY or Suburban Electronics would be under $25.
SD TECH
Feb 13, 2011 | Hitachi 43UWX10B 43" Rear Projection...
Tv out of focus all of a sudden
Ur tv have a problems it call convergence,it dead.U must have soldering tools,solders,and know how to solders to solved convergence problems.U must replaced 2 STK convergence ICS and some or all it resistors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence repair it ur self.The shop will cost $300-350 for the parts and labors.
May 16, 2010 | Hitachi 43UWX10B 43" Rear Projection...
It appears the television has a convergence problem. I am pretty sure the red color does not line up with the blue and green. Is there a way to adjust the red manually? The magic focus does not fix the...
No not adjustable,Ur convergence it dead.Must replaced the 2 convergence ICS,and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit to repair it ur self.The shop well cost U $300 for parts and labors.
Feb 06, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Manual Convergence adjustment on Hitachi 43UWX10B
I would guess you missed a open resistor--there are only about 12 of them--how did you check them?
This set (43uwx10b) has a tiny blue micro switch on the front of the chassis---if you engage it from the front the set will go into the DECAM or convergence mode--let me know the CLU number on your original remote and I will scan and paste instructions---98% of the time if the set is wacked out and will not adjust one of the resistors is gone---ONE OF THE CHIPS GETS THEM.
SD TECH
Oct 31, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Need service manuel free download site or codes for circuit board to reset to manufacture settings if possible on convergence problem
You can get a free manual if you buy a kit from www.TvRepairKits.com . They will typicaly email one to you if you just ask.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 20, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi TV, has red ghost lines outlining image on screen! Help!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
43UWX10B problem with green
if you have a 2 IC convergence chassis they dont control the green , However if you have the 3 IC chassis the green is controlleed by the third IC these are usually STK4275 or simallar single amp ICs. Which type chassis does your hitachi have? Its possibly related to the digital convergence board if all resistor near the ICs are good. Do you have the service manual? I can post a link where you can get the full service manual if you need one
Mar 29, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
