Question about KitchenAid KSRD25FK Side by Side Refrigerator
Our 1992 KitchhenAid side by side refrigerator model ksrb25qa has given up the ghost. We would like to purchase a new refrigerator with the same dimentions as the old refrig. We need the same size dimentions for two reasons; 1) to be able to slip it in to the built in space from which the old one was taken. 2) so that we can re-use the wood panel kit from the original refrig. doors. They were expensive and they match our cabinets perfectly. doors 35.5 wide (combined) doors 63.5 high freezer door(on left) has 14.5 X 14.5 water & ice opening refrigerator over-all hight 69.5 aluminum handles fro top to bottom Would you please advise me as to what new refrige could fill that bill? Many thanks, Katherine
  • wakelyk May 18, 2009
    Thanks for the recommendation of the black kitchenaid. I checked out the website but there is no indication as to whether we can re-cycle our wood panel kit.
    -Are you sure this refrig, will accomidate the wood panel facade?
    -Also, is there a refige. you might recommend that is less expensive & will answer our needs?
    Thanks again,
    Katherine
    Our 1992 KitchhenAid side by side refrigerator has given up the ghost.
    model- ksrb25qa
    cereal# sb4922016
    manufactured Nov. 1992
    File# lr5010
    We would like to purchase a new refrigerator with the same dimensions as the old refrig.
    We need the same size dimensions for two reasons;
    doors 63.5 high
    refrigerator over-all height 69.5
    aluminum handles fro top to bottom.
    Novelist:
  • 130 Answers
Http://www.epinions.com/Refrigerators--side_by_side--kitchenaid
click this link directly and check out the fridge models.the number four fridge unit near to matches your unit.if a bit difference then you can modify your wooden unit a bit not very much difference will be their.
thanks.keep updated.please do rate the solution.thank you for using fixya,
Posted on May 18, 2009
    Brigadier General:
  • 3,917 Answers
Hi Katherine,
There are many models which fit in the exact size and shape and requirement as you have mentioned. I would advise to stick to KithcenAid products as you have already been using them . There fore I would recomend to have a look at the bellow mentioned model which have similar specification with good style and performance in the link bellow:
Kitchenaid KSRS25RVBL Black :
http://www.rainbowappliance.com/KSRS25RVBL.html
Note: being black in color it might push your budget a bit but worth spending. As a technicial guy I have not come across any problems with this model,
Thank You
How to reinsert ice maker into 1992 Model TS25AF
You unscrew the srews holding the ice maker into the refrigerator. There may be 2 or 3. Then you should unplug any electrical connection, and saw on another site you need to remove the arm and install it onto the new ice maker. Then replace the new ice maker into refrigerator. There should be a different piece that's actually connected to the water input and then sends the water into the Icemaker.
Aug 31, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hi There, I require desperate assistance for my fr...
Throw it away and purchase a new one
Apr 14, 2017 | Refrigerators
Leak on bottom of freezer on ge profile side by side 13 years old
maytag has several great models and absolytly worth it remeber u get what u pay for . and any fridge u buy get the extened warranty that way no worries for awhile
Mar 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a hotpoint refrigerator hss25gfpjww...symptoms I was having are ghost noises and water not working...the ice does work. I have replaced the water filter and the motherboard and the ghost noises have...
I have a GE. Same 2 problems. I still have the ghost, but I fixed the water. There is a coiled up tubing inside the refrigerator behind the vegetable drawer. It was frozen. I took the drawer out and turned the rerigerator off and left the door open for about 4 hours while we watched tv. Tried to run the water with no success. Just about to give up when all of a sudden water flowed. It happened 1 more time, but not for about 6 months now.
What's the ghost noise solution?
Jan 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Low and high side of the A/C system and type of refrigerant?
Hello, and thank you for your question.
The High side & Low side valves are located in the engine compartment, and can be found on the aluminum lines running from the condenser to the firewall (a bigger tube, this is the HIGH side), and from the firewall to the condensor (in front of the radiator), & back to the compressor (this is the LOW side/a smaller tube). Regarding the refrigerant, you may have a dilemma. Most LCs in 92 came with R-12 freon, and is very expensive to purchase, and, in some places, a license is needed to purchase it. Your system *** may *** have been retrofitted with the "new" style (the "enviromentally friendly" type R-134A) refrigerant. To determine this, look under the caps on the abovementioned tubes. If the metal fittings are small & threaded, you have the original system. If the fittings are large, and are screwed onto a smaller fitting, and are grooved at the center of the upright stem, you have the newer style. You would also have rather large caps with a "H" ans an "L" imprinted on them. If you need to add refrigerent, add whatever refrigerant required into the LOW side, until the bubbles seen in the sight glass adjjacent to the radiator (on the Low side tube) disappear.
Oct 03, 2008 | 1992 Toyota Land Cruiser
My Kenmore side by side stopped cooling
I think your compressor has given up the ghost. Yes it is possible that it could be a relay problem but not likely.
Jul 07, 2008 | Kenmore 53642 / 53644 Side by Side...
Tri coloured ghosting
maybe...it might need service mode aligning be a tech
Jan 02, 2008 | Televison & Video
KitchenAid KSRD25FK Side by Side Refrigerator Logo
140 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
