Question about 2004 Mustang Factory Wiring Diagrams
Tie rod end threads stripped at the tie rod end
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
If you can get it apart, use a retreading die. Matco make a good set.
Posted on Feb 14, 2015
Have anyone out there ever change inner tie rods on a1995 honda odyssey?,if so simply explain,THANKS
Procedure on replacing the inner tie rod ends:
1) Raise and safely support the vehicle.
2) Remove the front wheel/tire assembly.
3) Clean the steering rod between the steering boot and outer tie rod end lock nut with a suitable penetrating lubricant and a clean cloth or shop towel.
4) Loosen the outer tie rod end locking nut 1/8 turn.
5) Loosen the steering boot clamp(s), and slide the small clamp off the boot.
6) Carefully loosen the boot and slide outward off the steering rack and onto the shaft to expose the inner steering rod mounting fastener.
7) If necessary, position the inner steering rack shaft in or out to allow for additional access.
8) Relieve the steering rod nut locking tab from the inner steering rack shaft, then loosen the steering rod ball socket nut 1 turn.
9) Matchmark the tie rod end to the threaded shaft.
10) Remove the cotter key and castle nut from the outer tie rod end threaded spindle, and using a tie rod end removal tool, remove the tie rod from the steering knuckle.
11) Hold the tie rod with a wrench, and remove the outer tie rod end from the threaded rod, counting the number of complete turns it takes to remove the tie rod end from the shaft. Write the number of turns on a piece of note paper.
12) Remove the tie rod end lock nut from the threaded steering shaft.
13) Slide the steering rack boot off the shaft.
14) Remove the inner steering rod ball socket nut from the inner steering rack shaft.
To install:
1) Inspect the tie rod end for looseness, and the steering rack boot and tie rod end boot for cracks deterioration or damage and replace as necessary.
2) Clean steering rack shaft and apply a light coating of Genuine Honda Power steering fluid as necessary.
3) Apply a medium strength locking agent to the threads where the inner steering rod ball socket mounts. Use a new locking washer and a new stop washer, and install the inner tie rod onto the steering rack shaft.
4) Tighten the inner tie rod end fastener by 58 ft. lbs. (78 Nm)
5) Peen the lock washer over the nut or onto the flat surface of the steering rack shaft.
6) Apply silicone grease to the outer circumference of the inner tie rod end ball socket, and onto the groove just outside of the socket.
7) Apply silicone grease to the inside of the small end of the steering rack boot, and slide the boot over the steering shaft and onto the rack and install the boot clamps. If the boot has air hose fittings make sure they are installed as removed.
8) Apply a light film of an anti-seize compound onto the threaded tie rod end, and install the tie rod end lock nut.
9) Install the tie rod end onto the tie rod, turning it in exactly the number of turns it took to remove it.
10) Install the tie rod end following the tie rod end installation procedure.
11) The balance of installation is the reverse of the removal procedure.
12) Check the front end alignment and adjust as necessary.
Sep 10, 2012 | 1995 Honda Odyssey
Replace the tie rod on a 1998 sienna
1 PUT ON YOUR EMERGENCY BREAK, LOOSEN THE WHEEL NUTS ON THE FRONT WHEELS,JACK UP THE CAR AND REMOVE THE FRONT WHEEL. WITH SOME YELLOW PAINT ,MARK THE THREADS WHERE IT SCREWS INTO THE TIE ROD END SO YOU KNOW HOW FAR TO SCREW THE NEW ON ONTO. TAKE OUT THE COTTER PIN AND REMOVE THE CASTLE NUT FROM THE ROD. USE A PRY BAR TO SEPERATE THE BOLT FROM THE TIE ROD END. ONCE SEPARATED YOU SHOULD BE ABLE UNSCREW THE OLD TIE ROD END OFF THE SHAFT..TAKE THE NEW ONE AND SCREW IT BACK ON ONLY TO THE YELLOW PAINT MARK THAT YOU MADE ON THE ROD EARLIER. THEN JUST REASSEMBLE THE SAME WAY YOU TOOK IT APART. MAKE SURE YOU TORQUE THE NUT TO 50 LBS.AND BE SURE TO USE A NEW COTTER PIN ON THE CASTLE NUT..
May 04, 2011 | 1998 Toyota Sienna
I can't get the tie rod ends off of my 1990 Oldsmobile Regency.
grab the tie rod end very tite with vice grips. loosen clamp on tie rod near ball joint fit wrench or more vice grips on ball joint. try to turn the tie rod it would help to soak the threads awhile with w-d 40 or heat the tie rod where it screws in the bal joint with a propane or some type torch. before removing the tie rod count the number of turns it takes to get it out so when you put it back your front end will still be aligned. i believe it would be smart to knock the tie rod end loose before anything else. remove cottre pi and nut from bottom of tie rod end. you can use a tie rod separator that looks like afuning fork or just crawl under the ****** and beat the hell out of the tie rod bolt,not always easy,use heavy hammer.dont beat the bolt if you plan to reuse the tie rod end cause you'll never get a nut back on it. most rental shops have tie rod seperators auto zone loans them usually. good luck from sunny austin fx
Feb 24, 2011 | 1990 Oldsmobile Regency
How to replace the tie rod end
Tie rod ends are replaceable, whether the steering system is rack and pinion or parallelogram steering system.
f42-02.gif Parallelogram steering system mounts. Figure A - behind front suspension; and Figure B - ahead of front suspension. f42-04.gif A rack and pinion steering system. Tie rod ends are threaded to provide a means of adjusting toe. When a tie rod is replaced, measure the old tie rod assembly before disassembling it. An approximate toe-in adjustment can be made to the new one prior to installation. When removing the old tie rod end, count the number of turns it takes to remove it. Then, turn the new tie rod end onto its threads the same number of turns.
Some vehicles have tie rods that appear to be the same on both ends. The difference is in the threads. One end has left hand threads and the other has right hand threads. It is possible to install the entire shaft backwards (which will work). Mark the tie rod to identify the inner or ourter end before removing it.
Before tightening tie rod clamps, check to see that they are in good condition and are positioned properly so they can be clamped tightly. Before doing a front end adjustment, spray penetrating oil on the threads of the tie rods. Do this during the steering linkage inspection so the lubricant has time to soak in.
Nov 12, 2010 | 2002 Dodge Stratus
How are the tie rod ends connected to the rack unit at the opposite end of the tie rod from the wheel ? The Tie rod is free to turn. Is this normal ??
The inner tie rod is threaded onto the rack. There is a tool called an inner tie rod end tool, than will help make it a lot easier to remove. The tool can be found at any good parts store or tool store. The shaft of the inner tie rod will spin. It has a ball that is pressed into a socket. The socket is the part that has the threads onto the rack.
The way you tell if they are back is by grabbing the tire at the 3 and 6 position and pushing/pulling. If you feel any movement than look carefully at the inner tie rod and the outer tie rod to see which one is letting the wheel move.
Sep 27, 2010 | Oldsmobile Silhouette Cars & Trucks
TYROD
to change a tierod on 2001 malibu, jackup and remove front tire, next locate the nut holding tierod on tire side, remove cotter pin and loosen but do not remove the castle nut from the tie-rod end ball joint stud. then install a small puller and break loose the tie-rod end from the steering knuckle. remove nut and detach tie-rod end. (I forgot to mention before taking tie-rod end off of vehicle,loosen the tie-rod end jam nut and mark the position of the tie-rod end on the threaded portion of the tie-rod. you can also count the number of turns to take off so you can put it back on.) make sure the new tie-rod end is aligned with the mark you made on the threads of the tie-rod. have the alignment checked or adjusted after you have installed tie-rod end. if in doubt you can go to any auto parts store and buy a haynes manual for your vehicle, they are based on a complete vehicle teardown. the cost is only about 20.00.
Nov 23, 2009 | 2001 Chevrolet Malibu
How to remover tierod
You remove the concerned front-wheel.
Jack up the car front and support it on jack-stands.
Remove and tie-up the brake caliper to more expose the tie-rod end.
loosen the jam-nut, then mark the position of the tie-rod end in relation to the threads.
Remove the cotter-pin from the tie-rod nut.
loosen but don't remove the tie-rod end ballstud and disconnect the tie-rod end from the steering knuckle-arm with a puller. OR
With a medium-size hammer, hit the end of the steering-knuckle where the tie-rod was inserted.
Pull out the tie-rod.
Nov 14, 2009 | 1997 Chrysler Concorde
How to install tie rods on a 1993 del sol
Instructions Things You'll Need:
  • Lug nut wrench
  • Jack
  • Jack stands
  • Wrench or pliers
  • Tie rod puller
  • Marker or paint
  • Pen and paper
  • Anti-seize compound
  • Torque wrench
    Remove the Tie Rod End
  1. Step 1 Purchase tie rod ends that are specific to your Honda model and year, for tie rod ends vary from model year to model year. The tie rod ends often come with nuts and cotter pins (glorified bobby pins).
  2. Step 2 Loosen the lug nuts on the front tires, but don't remove them. Jack up your vehicle, then support it securely on jack stands. Remove the tires.
  3. Step 3 Use a wrench or piers to loosen the outer tie rod's locking nut, but do so by only 1/8th of a turn. Mark the tie rod end's position on the threaded portion of the tie rod with paint or a marker.
  4. Step 4 Take out the cotter pin or key and use a wrench or pliers to loosen and remove the castellated nut from the outer tie rod end's spindle.
  5. Step 5 Separate the tie rod and the steering knuckle with a tie rod puller.
  6. Step 6 Grasp the tie rod with a wrench while you screw off the tie rod end. Make sure you keep track of the number of turns it takes to remove it, and write that number down. It'll help you when you install the replacement tie rod end.
    Replace the Tie Rod End
  7. Step 1 Put a coat of anti-seize compound on the threaded portion of the tie rod end, and screw on the lock nut for the tie rod end.
  8. Step 2 Screw on the tie rod end, making sure you do it in the same number of turns as it took to remove the original tie rod end (see Section One, Step 6).
  9. Step 3 Slip the tapered end of the tie rod end into the steering knuckle and tighten the castellated nut to 29 to 35 foot pounds. If your tie rod end doesn't come with a castellated nut, tighten that nut to 32 foot pounds.
  10. Step 4 Install the new cotter pin and tighten the tie rod end's lock nut. Repeat Sections 1 and 2 for the other tie rod end.
  11. Step 5 Reinstall the tires, tighten the lug nuts and get the Honda aligned.
Oct 28, 2009 | 1994 Honda Civic Del Sol
Tierod Ends have stripped its threads
you have to go to the car shop to thread the tie rod ends . If not any more possible then replace tie rod ends.that is you can do it and if you have equipment to do it .But if you cant then you have to go to a car mechanic shop to let them do it.
Aug 11, 2009 | Ford Laser Cars & Trucks
I,ve disconected the tie rod end and slid the inner boot down the tie rod but can't figue out how to get the tie rod out?
If it is the inner tie rod you are working on it need to be threaded out on some you can get with a wrench but most you will need an inner tie rod tool. Look at your replacement tie rod you will see the threads and two flat spots that is where the wrench goes. Please rate.
Dec 13, 2008 | Pontiac Sunfire Cars & Trucks
2004 Mustang Factory Wiring Diagrams Logo
37 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
