Need to get a new bulb formy tv but not sure what number is right?
I need to order a new replacement bulb for my kf e50a10 sony wega tv. But I wasn't sure if there was a difference between the kf e50a10 bulb and the kfd e50a10 bulb? I looked them both up and they both look the same. So can Iput either one of them in my tv or only the kf e50a10 one?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Take the sample out when you go to purchase the new ,cause then you can be sure all values are correct and that it looks the same or take a picture with the values and send to your supplier.
Posted on Dec 28, 2013
Testimonial: "That would be easiest, but I don't have a local repair shop in my area who carries those parts. They said that they could try to order it but the only one that they have on they're order form in the kdf e50a10. And there's no returns on ordered product that they don't usually carry. Its a bit of pain."
ctf1800
  • 4402 Answers
SOURCE: No Picture/Sound
can you go to the error menu?
im assuming it's the lamp however the error menu will tell me more
If the standby light blinks five times repeatedly, that's indication of a "Lamp driver error". The probable cause listed is, "lamp driver faulty". Its also possible that the internal antenna used to detect the presence of high voltage has become mis-positioned. The lamp driver provides the high voltage. If no high voltage is detected, it is assumed that the lamp driver is faulty.
Otherwise, it is assumed that the lamp is bad and the LAMP LED lights
the part number for the lamp is XL2000U. Its available for $200 at http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do. Use the Part or Accessory Number to locate the part.
Posted on Jan 17, 2008
ctf1800
  • 4402 Answers
SOURCE: Sony Grand Wega KDF-E050A10
Authorized sony repair center told me the problem was the Q Box. Ever heard of this? Part runs about 300 bucks. TV is out of warrenty as it is 2 years old. Do you think it is worth it to fight sony and get them to replace the part or just fix the TV?
Part Number is A1167541A, service rep called it a Q Box in the diag, however the web says its the b block assmy.
read this if you think it's the same problem
Posted on Feb 01, 2008
  • 556 Answers
SOURCE: replace bulb sony KF-60XBR800
When you are in front of tv grasp the right side of the front grill and pull it off, the lamp door is right behind it. Unscrew the cover and remove it, you will need the allen wrench provided with the new lamp to remove the old lamp just unscrew it and pull it out.
Posted on Sep 15, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Posted on Oct 17, 2009
phil_frye
  • 295 Answers
SOURCE: STk for Sony Wega
Actually if you can remove them from their heat sinks and wipe off the heat sink goop, the actual part number will be listed on them.
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
I need LAMP DOOR Cover Mine got warpped from heat
Contact someone from sony, call or send them an email asking where you could purchase this replacement panel.
Jan 27, 2015 | Sony Replacement lamp for Grand WEGA or...
Dear sir, The diagnosis by you on the problem is correct. Confirm by sony that we have an optical block and bulb problems. Need to replace both. Where can I get a replacement parts for optical and...
Please confirm tv model number as question shows it is Sony KF-E50A10
Model number info is very important to provide you correct and helpful info.
Thanks.
Mar 18, 2011 | Sony Grand WEGA KFE50A10 50" SDTV LCD...
Is the KF-50WE610 blub compatible with the kf-e50a10 bulb
Unfortunately it is not. The bulbs of the two models are completely different sizes and shapes. You can buy the correct parts for your television here:
http://www.partstore.com/Model/Sony/Sony/KDF60XBR950.aspx
Feb 24, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Hi My sony wega KF-E50A10 Lcd projection TV turn purplish ) Purple) when on . What could be the problem and it is due to lamp that need to replace. Id the part no for the lamp F9308-750-0(XL 2400) from...
michaeltong8,
Your problem is with the TFT panels in the optical engine and is an expensive fix. The KF series has a documented problem with the panels but the time to get relief from Sony has passed. Your only option now is to replace the optical engine. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, where to get the parts necessary and how to perform the repair.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Feb 08, 2011 | Sony Grand WEGA KFE50A10 50" SDTV LCD...
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Replace bulb sony KF-60XBR800
Sep 15, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
52"wega sony ,model no. kf-e50a10
most likely the lamp shattered. Very common just replace the lamp
Apr 21, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
