Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Need gasline size
I have a weedeater (poulan) featherlite leaf blower which needs the gas lines replaced and the 3/32" line I purchased is too large ID
  • 1,040 Answers
The best way to get the correct size lines is to take a piece of the old lines to your local outdoor power & equipment store, or sometimes your local auto parts store will carry them, and let them match them up. You may have two different size lines, so make sure to get pieces of both.
Jim
Posted on May 29, 2009
  • Jim Parker
    Jim Parker Jun 03, 2009
    Did this solve your problem?
    Jim
How to spool the cutting wire
please see instructions on replacing the line on page 14 of the manual.
Make sure you buy the correct line size. Incorrect line size will cause lot of grief and frequent replacement.
http://www.poulanpro.com/ddoc/PPOO/PPOO2009_USen/PPOO2009_USen_PP025-545177327_952711878.pdf
Sep 02, 2014 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
Need to replace both fuel lines on My BVM200 LE leaf blower, 1 large and 1 small fuel line, can You tell what size they are??
On your blower, it looks like the small line supplies fuel to the carburator which will be connected to the fuel filter in the tank, and the large line looks like the fuel return line.
http://www.ereplacementparts.com/poulan-type-gas-blower-parts-c-16962_31724_131359.html
Jul 19, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
I am needing a repair kit for gas tank on the weedeater featherlite 1500 where do I get repair parts at?
I have a Weedeater Featherlite SST and need to replace the fuel lines but do not know where they go is there a diagram that will show me this?
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
Looking for featherlite fl150 gas lines, where can I buy them? price?
You can get a fuel line kit from PartsStore.com. It lists for $7.95 so even with shipping charges it would be inexpensive. Here is a link that will take you directly to the ordering page: http://www.partstore.com/Model/Electrolux/Poulan/FL1500.aspx
Hope this helps!
Oct 10, 2009 | Poulan Featherlite Gas Blower, with Low...
The filter in the gas tank came off.
The filter should only fit in the end of one of the lines (probably the larger diameter one) The smaller line usually goes from the tank to the primer bulb and the larger one goes to the carburator. The filter just sticks in the end of the fuel line.
Jul 01, 2009 | Poulan Featherlite Gas Blower, with Low...
How do I get the engine cover off of my gb1 22v weedeater so that
You have to take the one side off to access the fuel tank and lines
you will need a hex head wrench or allen wrench some would call and some patience and note that every hole has a hex head.
Even if you are mechanically inclined it is a pain as you need to know and watch how it comes apart and goes back is crucial to your and its success.
Hope this helps?
May 24, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
How to you repalce a fuel line on a weedeater gb1/22v leaf blower
When replacing fuel line, make sure that you have the correct size lines. Depending on the size of your engine, the lines may vary in size. The primer bulb line will sometimes be larger in diameter than the fuel line to the carburetor. The primer bulb line will be the shorter of the two. When replacing the fuel line, make sure you have enough line to go from the bottom of the tank up to the carburetor. Give yourself a couple extra inches to work with. Cut one end at an angle, this makes it easier to feed down through the hole. Continue feeding the line until it comes out of the gas cap hole. Then cut the end of the line square again and attach the fuel filter that goes on the end of the line. Place the filter back in the tank, then adjust the line so that the fuel filter lays comfortably at the bottom of the tank. Then attach the other end of the line, (where you inserted it), to the carburetor, cutting off any extra line you may have.
Mar 27, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
216 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
